| andyrint |
 andyrint L Plate Warrior
| Nobby the Bastard |
| yen_powell |
 yen_powell World Chat Champion
| stinkwheel |
| andyrint |
| jeffyjeff |
 jeffyjeff World Chat Champion
| stinkwheel |
 Posted: 17:57 - 14 Mar 2021 Post subject: |
Just check the terminals are a good fit on the bulb and are free from corrosion. Might be worth squirting some WD40 in the light switch and wiggling it back and forth a few times too. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| WD Forte |
 WD Forte World Chat Champion
| jeffyjeff |
| andyrint |
 Posted: 02:09 - 15 Mar 2021 Post subject: |
| jeffyjeff wrote: | I would try bypassing the headlight relay (assuming the Keeway has one) |
I don't know either - can't find a wiring diagram for it
| jeffyjeff wrote: | Does it flash at regular intervals like a headlight modulator? |
Not sure what you mean by 'headlight modulator' but the flashing is regular and increasing frequency with engine rpm
| stinkwheel wrote: | Just check the terminals are a good fit on the bulb and are free from corrosion. Might be worth squirting some WD40 in the light switch and wiggling it back and forth a few times too. |
Headlight terminals look ok - there is no light switch. Lights come on when engine starts up. only high/low beam switch.
| jeffyjeff wrote: | Good call. I'll bet you could also verify that by switching your multimeter to AC volts and placing the test leads across the battery. A reading over 0 volts AC would indicate a failed diode. |
This is worth a shot although - to my mind - doesn't explain why the flashing usually stops after a few minutes. I'll try it tomorrow and update you all.
Big thanks to everyone that's contributed - this has been driving me nuts lately! |
| Easy-X |
 Easy-X Super Spammer
 Posted: 03:17 - 15 Mar 2021 Post subject: |
If I were to guess I'd say it's some sort of weird earthing issue where the headlights are somehow finding ground via the ignition system. Once warmed up some other path is found by the magic electricity piskies  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| MCN |
 MCN Super Spammer
| andyrint |
| Robby |
 Robby Dirty Old Man
| jaffa90 |
 jaffa90 World Chat Champion
| MCN |
 MCN Super Spammer
| WD Forte |
| WD Forte |
| andyrint |
| jeffyjeff |
| andyrint |
| jaffa90 |
| andyrint |
| jaffa90 |
The last post was made 5 years, 89 days ago. Instead of replying here, would creating a new thread be more useful? |
