Honda CG 125 93
ReignDespair
PostPosted: 15:02 - 28 Mar 2021    Post subject: Honda CG 125 93 Reply with quote
Looking for some advice. I'm new to bikes, and I need to change my engine oil. Would anyone have any recommendations for me?
I also have an issue where my back break light is sticking. Any advice in regards to this also.
Thanks in advance.
Signature here:
Easy-X
PostPosted: 15:06 - 28 Mar 2021    Post subject: Reply with quote
First off, more a Workshop thread than General.
If you're starting from scratch and know nothing about bikes you're probably best off getting the relevant Haynes manual for your model. Google can be a wonderful thing for finding answers but only if you know what question to ask Smile
Back brake - is it a drum on a '93? Probably there's a little pull switch attached to the pedal via a wire link. You could try loosening it up (i.e. giving the link a little more slack) or maybe the switch is just old.
F18
PostPosted: 15:09 - 28 Mar 2021    Post subject: Reply with quote
Starting point would be to look in the handbook for that bike's specifications (oil).
As for brand (and tweaking the grade +-) you'll get 100 different answers having started an 'oil thread'.
Stickiness (oo, err missus) can often be resolved with petrol. If you mean light staying on or staying off when it shouldn't, then it will be the relevant switch, front or rear at fault (if all adjustments are in order).
Summer is just around the corner
WD Forte
PostPosted: 15:15 - 28 Mar 2021    Post subject: Reply with quote
Motul 5100 4T 10W-40 will probably do nicely
buy and RTFM
bikers smell of wee
ReignDespair
PostPosted: 15:16 - 28 Mar 2021    Post subject: Reply with quote
@Easy-X Yeah, I probably should have posted under workshop.
@F-18 thanks for the information. I read some old posts about honda CG-125, but the thread was 10 years old. Didn't want to Necro, and prices have changed etc. Was just curious if there was a recommended oil to use etc.
I'll check a handbook for guidance.
The back break light; stays on once I push the break down. It will go off if I lift the pedal up. I've seen on a YouTube video that sometimes the switches can stick, and could need lubing?
Thanks guys I appreciate the help.
Signature here:
WD Forte
PostPosted: 15:21 - 28 Mar 2021    Post subject: Reply with quote
thas yer pedal return spring missing or rusty shaft that is
bikers smell of wee
ReignDespair
PostPosted: 15:24 - 28 Mar 2021    Post subject: Reply with quote
Thank you. How difficult would something like this be to replace?
Signature here:
A100man
PostPosted: 12:00 - 30 Mar 2021    Post subject: Reply with quote
Not that hard. Try it if you get stuck post back. But please the spelling is 'brake'. 'Break' means several things but is not a term for your stoppers.
Robby
Dirty Old Man
PostPosted: 12:46 - 30 Mar 2021    Post subject: Reply with quote
Brake light switches get sticky. Spray a bit of WD40 into it and operate the brake a few times and it should free off.
Any 10W40 bike oil will do. Whatever is cheapest. A CG doesn't need anything special.
The last post was made 5 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.09 - MySQL Queries: 13 - Page Size: 58.77 Kb
