Anyone in Luton or nearby got a chain splitter?
DukeRed
PostPosted: 23:42 - 05 Apr 2005    Post subject: Anyone in Luton or nearby got a chain splitter? Reply with quote
Title says it all.
Can't bring myself to spend 40+ quid on a splitter I'll use once in a blue moon.
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
sickpup
Old Timer
PostPosted: 00:57 - 06 Apr 2005    Post subject: Reply with quote
Angle grinder + cutting disc
DukeRed
PostPosted: 01:31 - 06 Apr 2005    Post subject: Reply with quote
Can't angle-grind a chain on though Smile .
Git
PostPosted: 01:56 - 06 Apr 2005    Post subject: Reply with quote
A splitter doesn't put a chain on either, it's just mullers the old one off
Splitter/riveter tool Smile
yes, that was nit picking..sorry Mr. Green
PostPosted: 02:38 - 06 Apr 2005    Post subject: Reply with quote
Put the chain on by hand, push the rivet through and hit it with a hammer type object until it's in as much as you can get it. Then ride the bike gently to the nearest bike shop, be worth phoning them before before hand just to check that they'll be able to finish putting the new chain on (won't take long at all). Small amount of cash/beer or free if you're lucky.
Did that on my ZX6R quite happily with what must have been about 4 or 5 miles ride to the bike shop.
DukeRed
PostPosted: 03:07 - 06 Apr 2005    Post subject: Reply with quote
Cheers will try that Thumbs Up .
sickpup
Old Timer
PostPosted: 09:57 - 06 Apr 2005    Post subject: Reply with quote
and yet so accurate.
WildGoose
White Van Man
PostPosted: 17:54 - 06 Apr 2005    Post subject: Reply with quote
i believe mine is back in my hands after doing the rounds once again, buggered if i can remember what all the bits do tho Razz
Kris
PostPosted: 17:57 - 06 Apr 2005    Post subject: Reply with quote
I've got one but doubt I'm anywhere near close enough to you Razz
Sowwy
www.prisonplanet.com
DukeRed
PostPosted: 18:11 - 06 Apr 2005    Post subject: Reply with quote
WildGoose, Kris. Cheers but a bit too far to go on a unriveted chain.
Patto
PostPosted: 00:11 - 07 Apr 2005    Post subject: Reply with quote
Don't risk it if it comes off the damage can be very costly especially
if you eat tarmac.
I just changed my chain and sprockets on me Gixxer easiest way is forget about the splitter they don't work to well anyway
just find the rivet link (its obvious which one it is as it doesn't have nice pressed rivets) grind the heads flush with the plate and then using a BIG flat blade screwdriver jam it through the back of the plate and wack the driver with a copper mallet , Job done
use a split link of good quality it will be fine , we used to race top fuel drag bikes with split links no problem but if you want it rivetted then take it to your friendly bike shop and get it riv linked.
Patto
The last post was made 21 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 68.03 Kb
