Chain tension
ThunderGuts
PostPosted: 07:55 - 21 May 2021    Post subject: Chain tension Reply with quote
So the spec for my bike (VFR800X) says 30-40mm of tension. However, I am mechanically minded . . . I don't like to see undue stress on anything. When I set the tension to 35mm (yes, I did find the tightest point on the chain for setting this) and then sat on the bike and reached down to feel the chain, it felt just a bit too taut. I then slackened off to 40mm and it was still fairly taut but with a small amount of up/down movement. To me, this now seems acceptable (just about though!). The manual says not to ride with 50mm or more of slack (makes sense as if the suspension unloads over a bump don't want the chain jumping off the sprocket).
My question; why would the manual advocate 35mm or even 30mm if it's making the chain tension when the suspension is compressed so blinkin' tight? The adjustment is made on the side stand but otherwise unloaded - I have double checked this as I know there's some variation between different bikes. To me, having the chain really taut when sat on it is just going to accelerate wear on the output shaft of the gearbox.
Anyone else found this or have a different view?
TG.
to v or not to v
PostPosted: 09:21 - 21 May 2021    Post subject: Reply with quote
sorry i dont know the answer to your question but i do know that its a lot easier to find neutral on my bike with a taut chain.
jaffa90
PostPosted: 10:34 - 21 May 2021    Post subject: Reply with quote
I`ve always checked for chain slack when loaded, the KLR650 had a 50mm slack when unloaded, as said before watch them chains wag about on them MOTO GP bikes in action. (bollocks to the handbooks).
MCN
PostPosted: 11:40 - 21 May 2021    Post subject: Reply with quote
If the OEM says set slack between 30 and 40 mm (unloaded) then that is the setting.
There's no need to over think this.
I continuously got the same argument from operators when I set up a system with no load.
They would cry that it needed load for set up.
I had to inform them that the setting I adjusted was OEM and that is the setting for the operational designed limits for the equipment
Write to the OEM and find out what they suggest?
PostPosted: 12:44 - 21 May 2021    Post subject: Reply with quote
Remember that spec will be for setting up a brand new chain which doesn't have tight and slack spots.
You're happy with 40mm. Mr Honda is happy with 40mm. Everyone is happy. Very Happy
pepperami
PostPosted: 14:13 - 21 May 2021    Post subject: Reply with quote
I have no idea if it has any bearing on the matter.
One variable on chain tension with the rider on board is the weight of the rider.
Heavier rider = suspension is pushed further down = more tension on chain.
jaffa90
PostPosted: 18:17 - 21 May 2021    Post subject: Reply with quote
Yes that is correct, me a heavier rider stiffens the suspension a bit Whistle and if you have a pillion even more.
Also remember our lovely pot holes we have in the u.k.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:44 - 21 May 2021    Post subject: Reply with quote
One would think that the tension prescribed by the manufacturer of the fucking bike who spent fucking millions developing it would take into account the maximum length that would be possible due to the geometry of the rear end.
Just an idea. Not saying that people who weren't involved in the development of said bike don't know more than the people who did but.... yes, actually I am.
Triumph Sprint ST 1050
Nobby the Bastard
Harley Gaydar
PostPosted: 19:20 - 21 May 2021    Post subject: Reply with quote
Ffs it's like saying the manufacturer didn't take into account the swinger geometry when fitting the shaft in a shaft drive and so you should fit a shorter one if you are a fat bloater.
MCN
PostPosted: 12:25 - 23 May 2021    Post subject: Reply with quote
But the more Macki Dees one shoves in one's pie-hole has a direct tangentially opposite volumetric contuberance on the hypotamuss of the perpindracula.
If OEM 'proven' methods and specifications are ignored then it's a complex matter to set up motorcycle drive chain tension. (For sum folke.)
PostPosted: 23:08 - 23 May 2021    Post subject: Reply with quote
Dunno though. They spring most of them for an 8 stone wet-through Japanese person. They generally specify too much air in the tyres too.
Nobby the Bastard
Harley Gaydar
PostPosted: 23:17 - 23 May 2021    Post subject: Reply with quote
I would imagine that the assumed weight would put the swingarm at it's maximum possible length of the chain when loaded. Why have suspension that could go past this?
chickenstrip
I just so wish that actually meant something Laughing
Islander
PostPosted: 11:53 - 24 May 2021    Post subject: Reply with quote
Adjust it the way the manufacturer tells you to and stick to the range they give you. If it's 30-40mm and 40mm works best for you then all is good.
Don't worry about checking the slack when it's loaded - unless that's how the manufacturer tells you how to do it.
In short, don't overthink it. adjust it and ride it. Thumbs Up
MCN
PostPosted: 13:50 - 24 May 2021    Post subject: Reply with quote
If the chain is adjusted to spec then tight when you sit yer big fat arse on the bike then the chain adjustment has not been done properly.
redeem ouzzer
PostPosted: 14:07 - 24 May 2021    Post subject: Reply with quote
I've yet to see a handbook yet that tells you to measure the tension under load.
Set as per manual, job done.
If I set my 1100 to the recommended 25-35mm slack under load rather than as specified by the manual it would flap around and take chunks out of the rubber buffer and also possibly the swing arm.
Be a REAL MAN!
jaffa90
PostPosted: 00:47 - 25 May 2021    Post subject: Reply with quote
OK, i`ll try again, you need chain slack when loaded, i don`t mean 25mm,30mm,40mm. I mean not tight. On any new bike i check for the above and then note the chain slack when unloaded which may be up to 50mm on trail type bikes or bikes with long swing arm travel.
https://www.bikechatforums.com/viewtopic.php?t=303698
Islander
PostPosted: 09:45 - 25 May 2021    Post subject: Reply with quote
Or you could just do what the engineering designer and manufacturer (who frankly knows a lot more about what's right for the bike than you do) suggests and adjust it within their set parameters. Rolling Eyes
Honestly you must spend more time overthinking and faffing than riding.
doggone
PostPosted: 09:55 - 25 May 2021    Post subject: Reply with quote
The worst thing done by those guessing and/or inexperienced is overtightening.
So follow what it says in the manual and if you don't have one try to look one up.
If that still can't be done it wants to still have a little bit of movement when shocks are well compressed e.g. Lie over the seat and check it, this will often seem rather slack when no weight is on it.
Overtight chain will wear much faster or even let go completely, and risks damaging other parts of the drive like gearbox and bearings.
ThatDippyTwat
PostPosted: 12:22 - 25 May 2021    Post subject: Reply with quote
Viffers are really picky about chain tension, you can feel it if it's wrong. It's largely a given that anyone that finds it's chuggy until 4K has set the tension on the sidestand. Funnily enough it's silky smooth when you set it, on the centre stand, to recommended 15-25mm (about 1" tops) and isn't otherwise.
The last post was made 5 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 108.5 Kb
