Electrical Problem
Spike_R
PostPosted: 22:31 - 05 Apr 2005    Post subject: Electrical Problem Reply with quote
i noticed my front light was out, then i switched to low beam and that blew aswell, all my dash bulbs have gone pop along with my high beam indicator. what would the problem be?
Derbi supermoto with cr500 engine, niceee
Git
PostPosted: 22:35 - 05 Apr 2005    Post subject: Reply with quote
The first thing I thought of if lots of bulbs blow is an overcharging problem perhaps.
Spike_R
PostPosted: 22:41 - 05 Apr 2005    Post subject: Reply with quote
its something to do with the rectifier regulator i think Neutral
Git
PostPosted: 22:50 - 05 Apr 2005    Post subject: Reply with quote
Your thinking sounds good to me, if the regulator/rectifier is pumping out too many volts this will indeed kill bulbs.
Have you put a volt meter across the battery with the engine running to see what the volts are like?
Spike_R
PostPosted: 01:16 - 06 Apr 2005    Post subject: Reply with quote
the battery connector was loose will my rectifier now be dead or should it work as normal?
i am going to buy a 30pence dash bulb and put it in tommorow then ride around if its ok i'll put all my main bulbs in ...
hope i dont need a new one !
Git
PostPosted: 01:45 - 06 Apr 2005    Post subject: Reply with quote
Not sure if it's dead or alive really, job for volt meter is the way I would play it.
If I'm honest I have never really heard of a loose battery connection knocking out bulbs Confused
Fingers crossed that was the fault.
Spike_R
PostPosted: 17:11 - 06 Apr 2005    Post subject: Reply with quote
i wired the battery up but its still killing bulbs, the rectifier must be dead Sad
PostPosted: 19:11 - 06 Apr 2005    Post subject: Reply with quote
Probably the voltage regulator part of the reg/rec.
Some bikes have a ballast resistor connected in paralell with the headlamp bulb (noteably older CG125s and H100s) if these fail or become disconnected, they will pop bulbs. I doubt your bike has one though as they are pretty old fashioned, I have only ever seen them on 6v direct lighting setups.
As Git says, get a voltmeter accross the battery terminals and measure the voltage with a few revs on. If it is going much above 14.5 volts, the regulator is shot.
Patto
PostPosted: 20:10 - 07 Apr 2005    Post subject: Reply with quote
Other than wear and tear only two things kill bulbs , over voltage and vibration , so check out them volts, if it is over voltage expect
to see 16-17v at 2500rpm +
Bulbs start popping at around 17-18v dependant on its
susceptibility to vibration oh and how much right hand the bike gets.
duff regulator + mucho right hand = loads of volts and blown bulbs
and if your real unlucky blown condensers , cdi box = (walking)
Can you tell I am talking from painful experience
Patto
The last post was made 21 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 60.59 Kb
