Spark plug - isolator switch?
splicker
PostPosted: 10:19 - 17 Jun 2021    Post subject: Spark plug - isolator switch? Reply with quote
Hi all,
I'm just looking at adding a battery isolator switch or kill switch to my ride as an anti-theft measure.
I noticed most are either wired to the battery or the ignition wires, but surely the bike can still be started with kickstart?
My question is would it be safe to add an isolator switch to the ignition coil wiring? - if spark plug has no power then the bike won't run no matter how you try to start it, right?
Easy-X
PostPosted: 10:26 - 17 Jun 2021    Post subject: Reply with quote
Don't mess with the high tension side of things!
What I'd suggest you look for is an existing kill switch or safety interlock on the bike and wire up an extra hidden switch to that. Whether it needs to be in series or in parallel entirely depends on the model of bike... which you neglected to mention Wink
to v or not to v
PostPosted: 10:36 - 17 Jun 2021    Post subject: Reply with quote
wouldnt it be easier to just disconnect the battery?
Moto Guzzi V7.
davebike
PostPosted: 11:22 - 17 Jun 2021    Post subject: Reply with quote
In the LT wiring yes would work that is how immobilisers work as well as intercepting the feed to the starter relay
as said don't mess with the High Tension side of the coil 15k + volts
Dave
NC750Xdct + others at work !
[email protected]
splicker
PostPosted: 13:34 - 17 Jun 2021    Post subject: Reply with quote
So not a good idea to add a switch to either of these wires then?
PostPosted: 16:58 - 17 Jun 2021    Post subject: Reply with quote
Very unlikely to have them start it and ride away. Most are just pushed or dragged. Waste of time and added failure point.
Tdibs
PostPosted: 17:41 - 17 Jun 2021    Post subject: Reply with quote
Yep, it will just be pushed, spend the money on a extra chain.
Easy-X
PostPosted: 18:47 - 17 Jun 2021    Post subject: Reply with quote
Or if you must mess with the electrics then get an immobiliser with a remote key fob, way cooler and no chance of someone seeing where the hidden switch is.
davebike
PostPosted: 07:47 - 18 Jun 2021    Post subject: Reply with quote
Those wires you used green arrows to are LT 12v or less yes you can switch
It the thick wire to the plug you must not fiddle with it carries 15,000 to 30,000volts you need a switch that is for that voltage
very complex very expensive and very dangerous HT can jump 15mm in dry air !
A well-made home made immobiliser is good but no replacement for locks and chains
Dave
[email protected]
xX-Alex-Xx
PostPosted: 08:41 - 18 Jun 2021    Post subject: Reply with quote
Just get an alarm with an immobiliser and vibration/tilt sensors. The alarm I had on my Gixxer was from Scorpio and that had a microwave based motion sensor that would beep as you even got close to the bike and would set the alarm off if you were there too long. Had an FM based remote as well that would go off if you were within about half a mile of the bike too.
DILLIGAF
The last post was made 5 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 61.69 Kb
