Chain adjustment Help
Quote Me Happy
PostPosted: 16:40 - 06 Apr 2005    Post subject: Chain adjustment Help Reply with quote
I was doing some general maintenance on my bike and came to adjusting the chain. The problem I'm having is getting a nut undone. It's firmly wedged. I'm sure this is a common prob so any tips on how to loosen it up a bit?
Cheers Very Happy
sychosis
PostPosted: 16:42 - 06 Apr 2005    Post subject: Reply with quote
Try tightening the nut first, sometimes this works on the most stubborn, I've had to do it to a couple of bolts on my gixxer, they loosened off quite nicely after that.
Bikes owned: Aprilia RS 125 GP1 2003 (Now sold), Suzuki GSX-r600 1997 (streetfightered), https://www.bikepics.com/members/sychosis/
psy?cho?sis (si-ko-sis),n. pl. psy?cho?ses (-sez) ,A severe mental disorder, with or without organic damage, characterized by derangement of personality and loss of contact with reality and causing deterioration of normal social functioning.
Quote Me Happy
PostPosted: 16:44 - 06 Apr 2005    Post subject: Reply with quote
Really? how strange Mr. Green Thanks will try when it stops raining Sad
mr.z
PostPosted: 17:09 - 06 Apr 2005    Post subject: Reply with quote
WD40 will also help, as will giveing it a firm tap with a hammer ideally a mallet on a sockett on the nut.. be carefull not to overdo it though because you can imagine what heppens if you do!
Get yourself a tube of copper slip and apply liberaly allong the threads, this will stop it happening next time you want to adjust it Very Happy
If the nut/bolt is a fairly big one then i tend to put a ring spanner on it and then get the afformentioned mallet and knockeing it at the other end of the spanner to turn it, 99% of the time works but you need space and to do it carefully Smile
Quote Me Happy
PostPosted: 17:19 - 06 Apr 2005    Post subject: Reply with quote
Thanks Zero. Have tried the mallet trick but no joy. Will spray some magic WD40 on it and try again Thumbs Up
sychosis
PostPosted: 10:43 - 13 Apr 2005    Post subject: Reply with quote
Did you manage to get your chain sorted?
Git
PostPosted: 10:50 - 13 Apr 2005    Post subject: Reply with quote
If you are using a small lever like a spanner or ratchet to undo the nut you may, or are suffering because of it. What you need is a 2ft long breaker bar or such like tool, get a bit of force behind it and off she should spin.
The last post was made 21 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 51.97 Kb
