 ..... Quote Me Happy
 Posted: 16:40 - 06 Apr 2005 Post subject: Chain adjustment Help |
I was doing some general maintenance on my bike and came to adjusting the chain. The problem I'm having is getting a nut undone. It's firmly wedged. I'm sure this is a common prob so any tips on how to loosen it up a bit?
Cheers  |
| sychosis |
 sychosis Crazy Courier
 Posted: 16:42 - 06 Apr 2005 Post subject: |
Try tightening the nut first, sometimes this works on the most stubborn, I've had to do it to a couple of bolts on my gixxer, they loosened off quite nicely after that. ____________________ Bikes owned: Aprilia RS 125 GP1 2003 (Now sold), Suzuki GSX-r600 1997 (streetfightered), https://www.bikepics.com/members/sychosis/
psy?cho?sis (si-ko-sis),n. pl. psy?cho?ses (-sez) ,A severe mental disorder, with or without organic damage, characterized by derangement of personality and loss of contact with reality and causing deterioration of normal social functioning. |
 Posted: 16:44 - 06 Apr 2005 Post subject: |
Really? how strange Thanks will try when it stops raining  |
| mr.z |
 mr.z World Chat Champion
 Posted: 17:09 - 06 Apr 2005 Post subject: |
WD40 will also help, as will giveing it a firm tap with a hammer ideally a mallet on a sockett on the nut.. be carefull not to overdo it though because you can imagine what heppens if you do!
Get yourself a tube of copper slip and apply liberaly allong the threads, this will stop it happening next time you want to adjust it
If the nut/bolt is a fairly big one then i tend to put a ring spanner on it and then get the afformentioned mallet and knockeing it at the other end of the spanner to turn it, 99% of the time works but you need space and to do it carefully  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
 Posted: 17:19 - 06 Apr 2005 Post subject: |
Thanks Zero. Have tried the mallet trick but no joy. Will spray some magic WD40 on it and try again  |
| sychosis |
 Posted: 10:43 - 13 Apr 2005 Post subject: |
Did you manage to get your chain sorted? ____________________ Bikes owned: Aprilia RS 125 GP1 2003 (Now sold), Suzuki GSX-r600 1997 (streetfightered), https://www.bikepics.com/members/sychosis/
| Git |
 Git Brolly Dolly
The last post was made 21 years, 182 days ago. Instead of replying here, would creating a new thread be more useful? |
