4 stroke chinese scooter
rkleinbergs
PostPosted: 01:58 - 21 Jun 2021    Post subject: 4 stroke chinese scooter Reply with quote
Hi, I'm new to this forum and I was wondering, how to make my 2020 Znen ZN50QT-34 (F11) 139QMB 50cc 4-stroke scooter faster?
I don't really want to put a big bore kit on it, cuz it's kinda expensive and time consuming. The scooter is stock and has all factory restrictors on it, which make it go 53 km/h.
pepperami
PostPosted: 07:50 - 21 Jun 2021    Post subject: Reply with quote
Put a turbocharger on it Thumbs Up
Nobby the Bastard
Harley Gaydar
PostPosted: 08:32 - 21 Jun 2021    Post subject: Reply with quote
Put it in the back of a van.
Triumph Sprint ST 1050
GSTEEL32
PostPosted: 08:37 - 21 Jun 2021    Post subject: Reply with quote
Drill 40kg of weight out of the frame.
Here is a good example of creating more space for airflow near the headstock:
https://drivetribe.imgix.net/USri9Er1QF-0UsViK-PeSQ?w=742&h=557&auto=format,compress&fit=crop&crop=faces&dpr=1&q=75
GettinBetter
PostPosted: 09:10 - 21 Jun 2021    Post subject: Re: 4 stroke chinese scooter Reply with quote
rkleinbergs wrote:
... and has all factory restrictors on it....
Err.... remove all some of the factory restrictors.
Lets face it, you're not gonna do much with 50cc.
Fat Angry Scotsman
PostPosted: 10:09 - 21 Jun 2021    Post subject: Re: 4 stroke chinese scooter Reply with quote
Before you flounce, might as well give the honest answer and the hard truth.
Hard truth = doing any kind of engine modification will do nothing to increase power after you've removed the factory restriction(s).
Honest answer = removing weight to improve your power to weight ratio is the only option. Go on a diet.
wr6133
PostPosted: 10:17 - 21 Jun 2021    Post subject: Reply with quote
Remove restrictions first, won't make much difference though.
After that the only answer is a big bore kit. Unless you are a total spaz you can fit this in an afternoon https://ebay.us/oqFLJg
struan80
PostPosted: 11:28 - 21 Jun 2021    Post subject: Reply with quote
How old are you? Are you not able to get a 125?
WD Forte
PostPosted: 11:30 - 21 Jun 2021    Post subject: Reply with quote
If you're 17+ why the hell did you buy a 50????
50's are shite dont waste time and money it
If you're 16 live with it until you're 17
Meanwhile use that time wisely practising all the things that keep you alive on two wheels
then get a 125
bikers smell of wee
xX-Alex-Xx
PostPosted: 12:15 - 21 Jun 2021    Post subject: Reply with quote
Yeah but what's the best way to make the van faster? Put it in a bigger van, or take the scooter out of it?
DILLIGAF
Nobby the Bastard
Harley Gaydar
PostPosted: 12:20 - 21 Jun 2021    Post subject: Reply with quote
push it off a cliff with the scooter in it.
PostPosted: 12:57 - 21 Jun 2021    Post subject: Re: 4 stroke chinese scooter Reply with quote
What a convenient name they've given it. Laughing
Anyway... the easiest and cheapest way to go faster is to sell your Znen thing and use the money to buy something that's faster.
ThunderGuts
PostPosted: 13:38 - 21 Jun 2021    Post subject: Reply with quote
As all of the above. Don't bother trying to make it faster. - it's simply not worth it Remember it's not just the power either, the transmission needs to be able to deal with it and the brakes need to be able to haul you down from a high speed. That's assuming straight lines; introduce corners and the increased speeds (even just slightly increased) would probably test the capability of the suspension too.
It's far easier to simply buy something faster with all of these requirements designed in already.
TG.
rkleinbergs
PostPosted: 13:58 - 21 Jun 2021    Post subject: Reply with quote
I could do it, but it won't ship to my country :/
rkleinbergs
PostPosted: 14:00 - 21 Jun 2021    Post subject: Reply with quote
then get a 125
In my country you can get a 125cc license when you're 16. I'm planning on doing it, when I turn 16.
GettinBetter
PostPosted: 14:20 - 21 Jun 2021    Post subject: Reply with quote
rkleinbergs wrote:
...In my country you can get a 125cc license when you're 16. I'm planning on doing it, when I turn 16.
Ok fair enough. So where are you?
...and how long before you're 16?
rkleinbergs
PostPosted: 15:00 - 21 Jun 2021    Post subject: Reply with quote
I'm from Latvia, and I turn 16 in 1 year
Easy-X
PostPosted: 15:04 - 21 Jun 2021    Post subject: Reply with quote
A year might seem like an eternity and granted a 50cc scooter won't make that fly by, figuratively or literally, but what are the penalties in your locality if stopped by the police doing over 45kph on such a scooter?
tl;dr is it worth it?
WD Forte
PostPosted: 15:05 - 21 Jun 2021    Post subject: Reply with quote
Ahh !
I assumed you were here in the UK
OK, the above still applies though, just wait until you're 16.
learning to keep it well serviced and in optimal condition would also be good practise.
bikers smell of wee
rkleinbergs
PostPosted: 15:20 - 21 Jun 2021    Post subject: Reply with quote
I think it's worth it. If you go over 85 km/h, they can take away your license, but I live in a rural area, so there are not many cops. I want to make my scooter accelerate faster. After 20 km/h it's quite fast, but it stops at 53 km/h.
slowasyoulike
PostPosted: 16:54 - 21 Jun 2021    Post subject: Reply with quote
If the Znen is anything like the other Chinese horrors I have seen, e.g. Baotian, then the 125 versions use the same brakes and suspension as the 50cc jobs. Even if he puts an 80cc kit on, it will only be going from probably 4 to 6BHP so it'll be nothing worth losing sleep over.
OP - these Chinese 4-stroke peds are usually only restricted by their abject lack of power, but if it has been nobbled it'll most likely have a washer tack welded into the neck of the exhaust or a ring in the variator that stops it from opening fully. Have a read of this:
https://www.tuningmatters.com/how-tos/beginners-guides/derestrict-50cc-scooter/
I would go the route of throwing a cheap top end kit on as suggested earlier... it might run just fine with the stock carb, but be prepared to do some re-jetting if it doesn't.
rkleinbergs
PostPosted: 17:27 - 21 Jun 2021    Post subject: Reply with quote
I was planning on swapping out the transmission, exhaust, and air filter and maybe changing the jets aswell, so I can get the best performance out of the scooter. At first I didn't want to put a big bore kit on it, because I thought it meant taking out the engine and changing out the crankshaft. I don't know a lot about scooters, because I am more used to older mopeds and motorcycles.
PostPosted: 18:42 - 21 Jun 2021    Post subject: Reply with quote
I have no idea what the second hand market is like in Latvia but over here no one wants modified stuff. Especially learners parents. Laughing
I would say don't do anything you can't reverse when you come to trade it/sell it when getting you big boys bike or you will be left with a pile of pretty valueless metal.
Triumph Trophy Launch Edition
rkleinbergs
PostPosted: 22:49 - 21 Jun 2021    Post subject: Reply with quote
How fast would it go with a 72cc kit on it? Do I have to replace the head, or can I use the original one? The scooter is pretty new, it has 1100 km.
I just want the bike to go around 70-80 km/h and accelerate a lot faster, because right now it sucks ass.
Weisse Schlange
PostPosted: 00:12 - 22 Jun 2021    Post subject: Reply with quote
Burn it.
Hing Oan
The last post was made 5 years, 75 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 126 Kb
