Unknown part in KLE500
andyp17
PostPosted: 13:28 - 12 Aug 2021    Post subject: Unknown part in KLE500 Reply with quote
Hello
I am an owner of a KLE500 (approx. 1991) and I found an unknown part near the battery - directly in the wiring harness. Does any one know what this could be and where I can buy a spare part?
Thanks for your help!
KR
Andreas
Nobby the Bastard
Harley Gaydar
PostPosted: 13:34 - 12 Aug 2021    Post subject: Reply with quote
I reckon it's a flasher unit.
Triumph Sprint ST 1050
andyp17
PostPosted: 13:51 - 12 Aug 2021    Post subject: Reply with quote
Thanks for your reply. But isn't it too small for a flasher unit? Also the connection terminals look different on a flasher unit...
ThatDippyTwat
PostPosted: 14:10 - 12 Aug 2021    Post subject: Reply with quote
It's a Diode. Part 21061
https://www.fowlersparts.co.uk/parts/view/21061-1003
Nobby the Bastard
Harley Gaydar
PostPosted: 14:12 - 12 Aug 2021    Post subject: Reply with quote
Could be a rectifier if the 2006 kle is anything to go by.
WD Forte
PostPosted: 15:55 - 12 Aug 2021    Post subject: Reply with quote
twenty fookin quid for a fookin diode?
you can buy a 20A 45V schottky diode ofn that Ebay for less than a quid
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 16:51 - 12 Aug 2021    Post subject: Reply with quote
ThatDippyTwat wrote:
Thats exactly what I was looking at but wasn't sure because OP said 1991 and theres only 2005-06 on fowlers website...
And half wave rectification sucks balls and cock.
ThatDippyTwat
PostPosted: 19:41 - 12 Aug 2021    Post subject: Reply with quote
It's common to a lot of dirt oriented kwaks, which is how I know what it is.
2 diodes are not as good as 4, bigger umbers innit.
andyp17
PostPosted: 22:33 - 12 Aug 2021    Post subject: Reply with quote
Thanks for your replies. Btw my KLE is an 1993 one.. Smile
I have the problem, that my battery is drawn when the motorcycle is off. I replaced the battery, generator and the rectifier but nothing solved the problem. I also checked cables and other electric assemblies. Nothing helped...
So my mechanic meant that I should replace this diode. He said it could be damaged and allows a little current flow in the wrong direction. So my battery could be drawn.
My question: can this be the cause of my problem. And is there a way to measure the diode to prove if it is damaged??
Thanks for your help!!
KR
Andy
bikenut
PostPosted: 07:35 - 13 Aug 2021    Post subject: T Reply with quote
Get an exact wiring diagram for your bike and study it....
Is it a blocking diode in the electric starter circuit/system ?
A digital multimeter has a diode test function usually...
nuts about bikes
davebike
PostPosted: 07:48 - 13 Aug 2021    Post subject: Reply with quote
as said a diode but not for charging it is part of the starting/safety system allows the bike to start with the clutch in but in gear I think
Any 5amp 20volt diode will do with two male 1/4" spades
Dave
NC750Xdct + others at work !
davebike1@gmail.com
bikenut
PostPosted: 14:35 - 13 Aug 2021    Post subject: T Reply with quote
A digital multimeter usually has an ammeter function as well so you can/could measure the "leak" and go from there...
Has an alarm system been fitted to the bike...
Get an exact wiring diagram and study... else get dizzy...
nuts about bikes
The last post was made 4 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 69.82 Kb
