| jimster |
 jimster Spanner Monkey
| Nobby the Bastard |
| arry |
 arry Super Spammer
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| jimster |
 Posted: 20:38 - 13 Aug 2021 Post subject: |
Thanks! I didn't have any impact cement so I've tried the contact adhesive (which I guess will be good enough for the MOT) and will redo it if needed in future with the proper cement stuff  ____________________ Current: Yamaha Diversion XJ900
Previous: Yamaha Diversion 600cc, Piaggio Zip 50cc, Honda CG125-W, Siamoto Caddy 50cc moped |
| Easy-X |
 Easy-X Super Spammer
| WD Forte |
 WD Forte World Chat Champion
| photoman |
 photoman Two Stroke Sniffer
| MCN |
 MCN Super Spammer
| Freddyfruitba... |
| WD Forte |
| Howling TerrorOutOfOffice |
 Posted: 11:44 - 15 Aug 2021 Post subject: |
I use hairspray on rubber grips. Epoxy resin on ridgid plastic ones.
I wouldn't use white spirit to degrease, it'll leave an oily residue. Use a high flash-point solvent like carb or brake cleaner. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jimster |
 Posted: 16:33 - 18 Aug 2021 Post subject: |
In the end I used a small amount of contact adhesive on both sides, the throttle side (where it is rubber to plastic) stuck, the other non-throttle side (rubber to metal) didn't.
So I redid the non-throttle side with the bar generously slathered in a massive layer of contact adhesive, including on the side of the grip.
I squeezed the grip on, smushing a horrific amount of adhesive all over the bike, with visual appearance disturbingly similar to a highly aroused elephant having vigorously released.
Once I had finished cursing and cleaned it all up, and left it for a couple of days to fully dry, the grip holds fine.
So for future reference to myself, start by using a small amount and if that doesn't hold, use a medium amount (not several gallons) of contact adhesive, or I'm sure hair spray works too if done properly! ____________________ Current: Yamaha Diversion XJ900
The last post was made 4 years, 362 days ago. Instead of replying here, would creating a new thread be more useful? |
