Handlebar Grip Glue
jimster
PostPosted: 19:05 - 13 Aug 2021    Post subject: Handlebar Grip Glue Reply with quote
Hi all,
The heated handlebar grips on my bike are loose - on both sides. I've read conflicting reports of how to reattach them (after cleaning with some suitable cleaner like white spirit).
Any views on (i) hairspray vs (ii) contact adheisve (which I have a tube of handy so would be ideal if this worked!) vs (iii) gorilla glue?
Current: Yamaha Diversion XJ900
Previous: Yamaha Diversion 600cc, Piaggio Zip 50cc, Honda CG125-W, Siamoto Caddy 50cc moped
Nobby the Bastard
Harley Gaydar
PostPosted: 19:29 - 13 Aug 2021    Post subject: Reply with quote
I use impact cement and then don't try a d use the bike for a couple of hours.
Triumph Sprint ST 1050
arry
PostPosted: 20:00 - 13 Aug 2021    Post subject: Reply with quote
I sorted mine with contact adhesive and it lasted as long as I kept the bike for.
Wouldn't hesitate to use it again.
Andy_Pagin
PostPosted: 20:07 - 13 Aug 2021    Post subject: Reply with quote
I used Gorilla Glue last time, about a year ago. Works well and you get plenty of time to twiddle things into place before it sets. The downside is it expands a lot, so you need to keep an eye it as it sets, especially on the throttle side.
jimster
PostPosted: 20:38 - 13 Aug 2021    Post subject: Reply with quote
Thanks! I didn't have any impact cement so I've tried the contact adhesive (which I guess will be good enough for the MOT) and will redo it if needed in future with the proper cement stuff Smile
Easy-X
PostPosted: 23:45 - 13 Aug 2021    Post subject: Reply with quote
If you've got very, very clean metal (thinking on the clutch side) and fresh rubber grips you could probably get away with no glue at all, friction does a surprisingly good job.
Superglue seems a bit extreme - I often see this specified in instructions - as it gives you almost no working time. I usually go with old skool rubber cement; it's pretty shite as glue TBH but the aforementioned friction effect goes up by several orders of magnitude. And easier to remove later down the line. If that didn't cut it I'd try contact adhesive.
WD Forte
PostPosted: 01:26 - 14 Aug 2021    Post subject: Reply with quote
hair spray
bikers smell of wee
photoman
PostPosted: 07:42 - 14 Aug 2021    Post subject: Glue Reply with quote
Oxford Products suggest using superglue if you fit one of their aftermarket heated grip sets. On one of my K75's I did just that and they never shows any signs of moving. You just have to make sure the areas the glue is to be applied is absolutely grease free of the glue wont take.
MCN
PostPosted: 10:23 - 14 Aug 2021    Post subject: Reply with quote
Contact impact same animal.
https://en.m.wikipedia.org/wiki/Impact_glue#:~:text=Impact%20glue%2C%20contact%20glue%20or,wood%20on%20cement%2C%20etc).
I use evostik contact/impact adhesive/glue.
The clue is supposed to be applied to both surfaces, allowed to dry to tack, then glued surfaces pressed together. (Impact/contact).
But it works eventually in close-fit jobs if allowed time for the volatiles to evaporate.
Hair spray won't work for heated grips as the elements are wrapped around a hard sleeve.
Hair spray works on rubber grips. But I'd still use evostik. Cool
Freddyfruitba...
PostPosted: 11:52 - 14 Aug 2021    Post subject: Reply with quote
Indeed. I used it as directed on my last bike, and for the following two years (ie until I flogged the bike) I had to put up with a 5mm gap between the end of the right-hand grip and the switch block Crying or Very sad
WD Forte
PostPosted: 19:10 - 14 Aug 2021    Post subject: Reply with quote
L'oreal Hair spray.
Because you're worth it
bikers smell of wee
PostPosted: 19:11 - 14 Aug 2021    Post subject: Reply with quote
I use my own special sauce.
PostPosted: 11:44 - 15 Aug 2021    Post subject: Reply with quote
I use hairspray on rubber grips. Epoxy resin on ridgid plastic ones.
I wouldn't use white spirit to degrease, it'll leave an oily residue. Use a high flash-point solvent like carb or brake cleaner.
jimster
PostPosted: 16:33 - 18 Aug 2021    Post subject: Reply with quote
In the end I used a small amount of contact adhesive on both sides, the throttle side (where it is rubber to plastic) stuck, the other non-throttle side (rubber to metal) didn't.
So I redid the non-throttle side with the bar generously slathered in a massive layer of contact adhesive, including on the side of the grip.
I squeezed the grip on, smushing a horrific amount of adhesive all over the bike, with visual appearance disturbingly similar to a highly aroused elephant having vigorously released.
Once I had finished cursing and cleaned it all up, and left it for a couple of days to fully dry, the grip holds fine.
So for future reference to myself, start by using a small amount and if that doesn't hold, use a medium amount (not several gallons) of contact adhesive, or I'm sure hair spray works too if done properly!
The last post was made 4 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 82.07 Kb
