| cc123 |
 cc123 Geez a joab?
 Posted: 12:12 - 07 Apr 2005 Post subject: Freeing up stuck bolts |
How??!!
I've got a bolt on the footrest hanger which is loosened off using an Alum key but it's done and won't come lose.
I've also got 2 screws on the mudguard (star shape) that also won't budge. Any tips??? ____________________ Old bikes >>> https://www.bikepics.com/members/cc123/ |
| bikefreedom |
 bikefreedom Nitrous Nuisance
| map |
 map Mr Calendar
 Posted: 12:34 - 07 Apr 2005 Post subject: |
Wd-40 good to start with.
There is a trick where you go to tighten first (this is supposed to crack loose any gunge/rust) before undoing.
Use good quality allen keys. Or get the bits to fit into a ratchet set (more leverage).
The star shaped ones will need a TORQ (or is that torx) set.
If you haven't got then the bits can be got from the likes of B&Q, Halfords, etc to put into a ratchet.
If WD-40 fails get an impact driver onto it.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| bikefreedom |
 Posted: 12:40 - 07 Apr 2005 Post subject: |
A very good idea about the impact of a driver  |
| gsxrpeak |
 gsxrpeak Trackday Trickster
 Posted: 15:44 - 07 Apr 2005 Post subject: |
buy yourself an impact driver, best tool you will ever have! hit the top with a hammer! will undo the most stubborn of screws, bolts, and so on.. |
| Mr.Everready |
 Mr.Everready World Chat Champion
| swampy |
 swampy World Chat Champion
 Posted: 18:36 - 07 Apr 2005 Post subject: |
You can also try tapping the head of the bolt/screw firmly with a hammer, as this can also sometimes break the seal.  ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
"Faster, faster, faster, until the thrill of speed overcomes the fear of death..." Hunter S Thompson |
| Scotsman37 |
 Scotsman37 World Chat Champion
| mchaggis |
 mchaggis World Chat Champion
 Posted: 21:12 - 07 Apr 2005 Post subject: |
If you're worried about chewing up Philips head screws trying to undo them, a tip I'd give is to use a straight bladed screwdriver instead. That and squirting it with 3 in 1 penetrating oil and leaving overnight - it helps, but not always. Being able to use a ratchet to undo them is pretty useful too. ____________________ I must not be a troll...
Mmmm, Guinness
The last post was made 21 years, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
