Any tips to reduce engine vibration YBR 250
flimbar
PostPosted: 10:16 - 08 Oct 2021    Post subject: Any tips to reduce engine vibration YBR 250 Reply with quote
Hi there
I just bought a 2010 YBR 250, 8k miles, immaculate condition, but the engine is hellishly viby, so much so that my partner gets white finger and cannot take it above 60 mph as the vibes effect her vision.
Shame because she loved her YBR 125 so thought it would be the ideal upgrade to be able to ride at motorway speeds.
I know singles are inherently viby but we test rode 2 other YBR 250s and one of similar age and mileage was much less viby even at high speed.
The one we bought was the cleanest example but from a dealer that doesn't allow test rides, and sitting on it revving the engine I kind of optimistically convinced myself it was no worse than the others.
Anyway, is there anything that can be done to help with engine vibes, any sort of tuning?
If it is relevant at all the gear shift is more difficult on this one than the others we test rode.
Many thanks for any tips.
Yamaha YBR125 > Suzuki SV650S > Suzuki DL650 V-Strom > Honda CBR600F > Honda ST1300 Pan European
Nobby the Bastard
Harley Gaydar
PostPosted: 10:40 - 08 Oct 2021    Post subject: Reply with quote
Should have just taken it straight back to the dealer and told them it's broken.
Edit, has anyone messed with the timing of the balance shaft?
Engine mounts tight?
Triumph Sprint ST 1050
flimbar
PostPosted: 12:04 - 08 Oct 2021    Post subject: Reply with quote
Thanks for the suggestions, I'll check the engine mounts, no idea how to check balance shaft timing, will do some research.
Evil Hans
PostPosted: 12:38 - 08 Oct 2021    Post subject: Re: Any tips to reduce engine vibration YBR 250 Reply with quote
I bet it doesn't.
It might affect her vision though.
flimbar
PostPosted: 12:43 - 08 Oct 2021    Post subject: Re: Any tips to reduce engine vibration YBR 250 Reply with quote
Evil Hans wrote:
I bet it doesn't.
Well spotted, I usually get that right, thoroughly ashamed Embarassed
pepperami
PostPosted: 13:43 - 08 Oct 2021    Post subject: Reply with quote
Well I’ll state the obvious, something is not right?
My friend has one and he joined our little tour of Wales (Wales failed, breakdowns & weather) last year .
No mention of being particularly excessively vibey? and at times we were traveling above 60mph without any issues.
Check the stuff Mr Knobby said.
MCN
PostPosted: 17:00 - 08 Oct 2021    Post subject: Reply with quote
I'm assuming your partner is using the YBR250 then.
Possible quick fix is some doughheid has blinged the beast and fitted non OEM bar ends.
Bar ends serve two important porpoises.
1st to prevent the bar from 'apple-coring' you if you fall off and you/someone hit/s the end of the bar.
And as a vibration absorber.
With enough mass in the bar end engine vibration felt through the bars is dampened.
Sometimes they get called Bar End Weights. Makes you wonder why? Rolling Eyes
https://www.bikesmedia.in/reviews/importance-of-motorcycle-handlebar-end-weights.html
Nobby the Bastard
Harley Gaydar
PostPosted: 17:02 - 08 Oct 2021    Post subject: Reply with quote
Thats a good point.
Does she spend every ride clamped hard against the tank and going crosseyed?
The last post was made 4 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 58.27 Kb
