Freeing a seized caliper.
pepperami
PostPosted: 19:58 - 28 Jan 2022    Post subject: Freeing a seized caliper. Reply with quote
Just seeking some ideas and constructive input please Thumbs Up .
I’ve managed to get the front caliper off ‘Project Scrappy Hyosung ‘.
I had to free the hose as the bleed nipple is seized solid, and I don’t want to snap it off.
After much jiggery pockery, I got the caliper mounting bolts to move and was able to remove the bolts without any damage.
The caliper still refused to let go of the disc Shocked .
After an hour of swearing, pulling, and much wiggling, it finally let go.
Now comes the really hard part , (for me anyway).
Getting the pistons out of the caliper body??
Any constructive hints, tips, or advice would be very much appreciated Thumbs Up
Thank you Smile
Kawasaki Jimbo
PostPosted: 20:17 - 28 Jan 2022    Post subject: Reply with quote
I used a slide hammer thing, worked a treat.
Motorbike Brake Piston Removal Tool 12pc Universal Adapters Frozen Pistons
WD Forte
PostPosted: 20:20 - 28 Jan 2022    Post subject: Reply with quote
Never had it happen to me personally
so not a job I've had to do luckily
I do recall some one screwing a grease nipple in the bleed hole
capping the union off with a 10mm bolt and using the grease guns pressure to push the piston out.
I've heard of some using compressed air.
Meself, I'd probably end up welding a bar to the presumably fooked pistons
heat the caliper body and yank twist and swear at em.......
( I do like a good swearing)
You can buy internal grabby things for pulling them out but
no idea if they'll do any serious pulling though.
Soaking them in some antirustoprene type jollop first may help
bikers smell of wee
PostPosted: 20:38 - 28 Jan 2022    Post subject: Reply with quote
A full size grease gun can generate 5,000-10,000 psi. I think it's safe to say, if that doesn't work, it is scrap.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:26 - 28 Jan 2022    Post subject: Reply with quote
As previously said, the slide.hammer kit is the way to go but if the bleed nipple cannot be undone, why bother?
New calliper.
Triumph Sprint ST 1050
pepperami
PostPosted: 21:27 - 28 Jan 2022    Post subject: Reply with quote
10,000 psi Shocked , yer I’ll go with that!
Thank you Thumbs Up
pepperami
PostPosted: 21:32 - 28 Jan 2022    Post subject: Reply with quote
New calliper.
People said that before I managed to get the caliper off the disc.
I’ve got lots of time on this one.
Bleed nipple work starts tomorrow.
virus
PostPosted: 21:43 - 28 Jan 2022    Post subject: Reply with quote
I have 3 approaches:
1) blast an airline in at high pressure with a rag in the caliper to catch the pistons (dont use your fingers, it hurts)
2) greasegun FTW
3) throw the fucker in the bin and put a different caliper on
own: 81 xs1100g...
WD Forte
PostPosted: 21:49 - 28 Jan 2022    Post subject: Reply with quote
Good point on the nipple
if it's seized don't go mad on it
soak in anti yer jollop of choice for a day then start with heat
and moderate back and forth to try and get it to move
If it shears off, its not 100% bad but the job just got worse
and getting the remnant out with fooking the threads gets harder
I've had about a 45% success rate doing these
tacking a nut over a rounded off one worked
vewy vewy carefuwwy drilling with larger and larger bits to
then pick out the remaining thread worked for me once.
And of course, I fucked up a few too.
bikers smell of wee
pepperami
PostPosted: 00:09 - 29 Jan 2022    Post subject: Reply with quote
You must be in the Pepperami School of bike maintenance Wink Laughing .
PostPosted: 02:05 - 29 Jan 2022    Post subject: Reply with quote
As Stinkwheek said, grease gun FTW.
Another way I have got things free is to dump it in an utrasonic cleaner for a really good soak. I don't know if it's the cleaner getting the shit out or the vibes freeing it up but it has worked in some cases where I have been on the point of giving up. I do have a biggish ultrasonic bath though.
Triumph Trophy Launch Edition
bikenut
PostPosted: 09:11 - 29 Jan 2022    Post subject: T Reply with quote
Sirzed caliper, single piston .
Remove from stiue but don't disconnected hydraulics.
Bucket of very hot water.
Place caliper in water and count to ten then pump a few times, piston moves. Remove from water, lube piston with fluid.
Wood and g clamp, press piston back in, then repeat process. Repeat, repeat, repeat.
When confident piston is freed off, pump piston out.
Multi pistons, clamp off pistons except the one you are freeing. Don't pump out till all are free.
If piston etched or corroded, use grips. If not, don't use grips, use expanding pliers on piston internal wall, the void or saucepan cooking area wall.
For solid piston, excersize till free ( pump and clamp ) then pump out. Some pistons are plastic.
You could use heat gun hair driers...
Small rotary wire brush and drill/Dremel lubed with fluid to clean caliper seal groove and outer " land"..
nuts about bikes
Robby
Dirty Old Man
PostPosted: 18:26 - 30 Jan 2022    Post subject: Reply with quote
I just pump the brake lever until the piston comes out.
xX-Alex-Xx
PostPosted: 20:23 - 30 Jan 2022    Post subject: Reply with quote
Guessing that's not an option as the first post states the hose was released as the bleed nipple was locked solid.
DILLIGAF
mentalboy
PostPosted: 20:46 - 30 Jan 2022    Post subject: Reply with quote
Yeah, that's the sensible way to do it, if everything else works.
In this case I got to thinking how much can it possibly be for a replacement caliper for a Hyosung?
Removing the bleed nipple should be priority, what use is it to spend time, skin and cussing over stuck pistons only to get them working and find that you fuck the caliper body trying to get the nipple out?
Make mine a Corona.
Robby
Dirty Old Man
PostPosted: 21:40 - 30 Jan 2022    Post subject: Reply with quote
I have never come across a caliper that fucked, and decent replacements tend to be expensive. Piston could well be pitted beyond use, and new seals are likely needed, but the caliper body is less likely to be fucked.
Lack of bleed nipple isn't a problem. Most of the air will go back up the line to the reservoir, the little pocket left in the caliper isn't going to be a problem when all you need to do is pump out the piston.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:59 - 30 Jan 2022    Post subject: Reply with quote
So, you fit a nice new seal and piston and you're still left with a calliper you cannot bleed because the the bleed nipple is siezed.
I don't see the point.
pepperami
PostPosted: 22:27 - 30 Jan 2022    Post subject: Reply with quote
At least give me the chance to work on it and see if I can get it to budge?
If I f*gk it up, at least all I have wasted is my time.
pepperami
PostPosted: 15:22 - 31 Jan 2022    Post subject: Reply with quote
got the bleed nipple out of a very crusty brake caliper without destruction taking place ,yay!.
I used the world’s tiniest blow-torch to put some heat on the nipple only and not the caliper.
Then a 8mm six sided socket on the nipple.
Firm but not fierce pressure and lots and lots of knocking.
Voilà Out it came, no damage.
Happy Pepperami is happy!
WD Forte
PostPosted: 15:26 - 31 Jan 2022    Post subject: Reply with quote
That's a good start
Scoosh some jollop down the hole and refit it with gentle to moderate
force
PICS!
bikers smell of wee
pepperami
PostPosted: 16:20 - 31 Jan 2022    Post subject: Reply with quote
WD Forte wrote:
PICS!
I’ll try guv, I just find it so hard to do this picture nonsense.
I will try Thumbs Up , won’t be very interesting though?.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:27 - 31 Jan 2022    Post subject: Reply with quote
Congrats.
WD Forte
PostPosted: 17:13 - 31 Jan 2022    Post subject: Reply with quote
Yew must have a light then boi.
Do they have cameras in Norfolk yet?
I know they're still waiting on the electricity.................
Razz
bikers smell of wee
WD Forte
PostPosted: 19:38 - 31 Jan 2022    Post subject: Reply with quote
Av yew got a an Android phone boi?
if so, getting pics to your PC is easy
plug a USB cable from phone to to PC
and the phone will often give you options
like charge only or file transfer.
failing that, swipe down after plugging the phone in and you'll of get these options that way.
The phone will then show up on explorer and the pics will be in
typically: Phone name/DCIM/Camera
Copy em to a desktop or other folder then show them to the world!
Igmur is free and easy to use for sticking em up on the interweb
bikers smell of wee
virus
PostPosted: 21:18 - 31 Jan 2022    Post subject: Reply with quote
Congrats on getting it done, for future reference though you warmed the wrong part. The idea is to use a blowtorch to heat the outer component (caliper in this case) so it expands slightly to release the thread on the internal (nipple). Obviously be careful doing this on calipers as you can melt rubber component/fuck up paint or other surface coatings etc.
Im a fan of putting in in the oven at a low heat to get it up to temp then use freeze and release spray on the internal part to rapidly cool it. I should note that Mrs Virus is not a fan of this method.
own: 81 xs1100g...
The last post was made 4 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 3.27 - MySQL Queries: 13 - Page Size: 129.57 Kb
