Cx500 - firing on one cylinder
Jay2903
PostPosted: 14:55 - 31 Jan 2022    Post subject: Cx500 - firing on one cylinder Reply with quote
I’ll try and keep it short.
I’m trying to get an 81 cx500 running has been sat up a good while. Got to the point where it fires up but fires only on the left cylinder. (Right pipe cold). Carbs are clean, fuel in the bowl. When I spray some cleaner though the inlet it fires.
I took the manifolds off, the attached videos show what’s going on ?
WD Forte
PostPosted: 15:18 - 31 Jan 2022    Post subject: Reply with quote
Not unusual for on old neglected CX
When it's running stick your hand over the non running inlet and remove it a few times to see if it fires on that cylinder at all
If it does, remove the crabs and clean em proper
You might want do that anyway they look a bit mingy
Use an inline fuel filter too, that tank has probably got 40 year iof crap ready to flow in the carbs the tank strainer wont stop
bikers smell of wee
Jay2903
PostPosted: 16:58 - 31 Jan 2022    Post subject: Reply with quote
I cleaned them as best I could. Sprayed cleaner and blew out every jet and passage way. When it wouldn’t fire on both cylinders I took them back off and double checked that right one blew everything out again. Nothing I can see blocked. I’m using an auxiliary tank with fresh fuel.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:00 - 31 Jan 2022    Post subject: Reply with quote
Have you swap the carbs over to see if the issue follows it?
Triumph Sprint ST 1050
WD Forte
PostPosted: 17:03 - 31 Jan 2022    Post subject: Reply with quote
CX carbs are handed and held together as a unit
L,R swapping isn't really an option
Is this going to be on of them cool cafe racers?
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 17:08 - 31 Jan 2022    Post subject: Reply with quote
Shocked What is this madness?
Judging by the carb madness you've described, best thing for it.
blurredman
PostPosted: 17:09 - 31 Jan 2022    Post subject: Reply with quote
Mine (and all) cx's are buggers to start if left for more than a few weeks.
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 52k.
Easy-X
PostPosted: 17:14 - 31 Jan 2022    Post subject: Reply with quote
I couldn't download those vids but have you checked the spark plug for that side?
kgm
PostPosted: 17:18 - 31 Jan 2022    Post subject: Reply with quote
Mine is fine. I keep it with the fuel tap off, then when using it turn it back on and drain a little fuel by opening the drain screw on each carb. Starts first time nearly every time.
WD Forte
PostPosted: 17:36 - 31 Jan 2022    Post subject: Reply with quote
Always a good start that
dry no fuel, wet no spark generally speaking
I assumed he had a spark but forum info innit?
we can only get as good an idea wtf is going on as the poster allows us .
As its an AC CDI system well known for shitting the bed
a full stator and CDI box check would be one of my first tests
bikers smell of wee
blurredman
PostPosted: 19:05 - 31 Jan 2022    Post subject: Reply with quote
I've heard of that. But i've never bothered. Mine runs up fine enough if I just let it crank long enough, and keep on the throttle until 2nd cylidner kicks in..
Jay2903
PostPosted: 19:24 - 31 Jan 2022    Post subject: Reply with quote
Can anyone see the clips ? Was hoping that would shed some light. I haven’t really got any experience with cv carbs. When I wind the throttle open the left one moves a little and the right one sort of flutters. Shouldn’t they moving up and down more and evenly ?
WD Forte
PostPosted: 19:26 - 31 Jan 2022    Post subject: Reply with quote
All mine would start fine if used regularly but leave the feckers
a fortnight or so and they'd do the one cylinder trick and you have to
wait bit for no2 to kick in
Never bothered me enough to start fiddling with drain screws
bikers smell of wee
Jay2903
PostPosted: 21:07 - 31 Jan 2022    Post subject: Reply with quote
I had this thing running for a good while on a few occasions no luck , you see what I mean about those slides ?
bikenut
PostPosted: 15:56 - 01 Feb 2022    Post subject: T Reply with quote
Your videos took Thier time !
Anyways just watched them...
Can't remember if the valves are inclined or not, will go to CMSNL for a look-see next.
From memory valve clearance adjustment is via screw abnd lock nut ?
You say bike been standing idle for some time...
Valves ( and clutches, brakes, cables etc. ) Can and do stick, open usually.
By its nature, left standing, a valve or too can be left open, humidity can end up in cylinder and valve seats/faces etc. And cause poor sealing...
Plugs are deeply recessed, are/where the "water drain holes" clear...?
Compression test after valve clearance check.
Where any valve clearances rather wide, particularly on the "fluttering dash pot piston" side, the piston that flutters ?
Off to CMSNL for a look-see...
nuts about bikes
bikenut
PostPosted: 16:16 - 01 Feb 2022    Post subject: T Reply with quote
1980 ( A) and 81 ( B) for UK, exploded view suggests valves are inclined...
Check valve working clearance.
Tight, then adjust.
Slack, by how much...
Was that valve sticky/stuck and now bent, or lots of crud between seat in head and valve face ??
Compression test then report back.
Better safe then sorry...
Bikes that have been resting for some time need a very gentle sympathetic and cautious " reawakening". I stuck valve can wreck an engine in one turn...very quickly !!!
Some people think one turn of an engine is enough, it AINT !!!!!!!
nuts about bikes
bikenut
PostPosted: 09:51 - 06 Feb 2022    Post subject: T Reply with quote
Hi jay, how you getting on with the cx ?
You got your shed ?
You know of CMSNL so know the valve clearance adjustment method now ?
Much more basic and simple compared to the dohc bike you had eh !
nuts about bikes
Jay2903
PostPosted: 01:36 - 09 Feb 2022    Post subject: Re: T Reply with quote
You got your shed ?
Sheds pretty sweet, cheers Thumbs Up
I spoke to the guys on the cx 500 forum. theres a factory fitted idle jet that I missed when cleaning that was blocked. Bit of a pain to get out but cleaned it up and now it fires on both cylinders and idles fine.
Took it for a ride and it’s fine up until 4K rpm then acceleration drops of quite suddenly. I thought it might be another carb issue but those guys reckon it’s the stator.
Did some checks and one of them is out of spec. The “low speed source coil” which seems a bit counterintuitive I would’ve thought it’d be the high speed.
Gonna take another look this week.
blurredman
PostPosted: 05:45 - 09 Feb 2022    Post subject: Reply with quote
You can get the same symptoms of high speed coil breakdown with spark plug cap issues, indeed.
What did your stator readings come to?
bikenut
PostPosted: 08:29 - 09 Feb 2022    Post subject: T Reply with quote
This is were those red neon plug caps come in so handy...
A stator resistance check both cold and hot, an AC voltage checks when cold and hot.
Increased revs means increased "rate of change" meaning Increased activity bolts output, but you will see falling AC voltage, down to about 28 volts, then misfire...
If you have access to a mega tester, test the coil insulation breakdown, even heat related make and break contact...
nuts about bikes
blurredman
PostPosted: 11:06 - 09 Feb 2022    Post subject: Reply with quote
They post this on the CX forum all the time, but it's a handy image...
I have a few markings myself though which are barely just about within margin, and one or two are a little out but the whole system working fine for me still at the minute. 90k miles on my original stator here...
https://www.cx500forum.com/attachments/correctedstatorchart_zps6ab4572d-jpg.20258/
Jay2903
PostPosted: 12:43 - 09 Feb 2022    Post subject: Reply with quote
Stator readings (cold) -
1 - 5 = 107.7
2 - 5 = 88.2
3 - 5 = 197.7
4 - 5 = 104.6
6 - 5 = 91.1
7 - 5 = 196.4
9 - 5 = 285
9 - 8 = 79.3
blurredman
PostPosted: 14:30 - 09 Feb 2022    Post subject: Reply with quote
Oh dear.
Until the stator is rewound (or replaced) you'll be limited to slow speed.. Embarassed
WD Forte
PostPosted: 16:25 - 09 Feb 2022    Post subject: Reply with quote
I dumped all that AC CDI bollox for the later TI systems on my CXs
If I had an AC CDI CX now I'd just get an Ignitech DCCDIP2 for it.
OK Its £150 plus postage but its Plug and play so no dropping the lump whipping the back off with all the associated faffery and cost
so its actually of cheaper and easier
Also, if you do replace the stator, the CDI boxes can fail suddenly with no warning leaving you up shit creek cos they is like well NLA innit
Also 2:
The advance coils at the back of the case can quietly fail
This won't stop the bike but will rob it of some of its 'get up and go'
Ignitechs work on DC so independently of all these elderly systems bar the pulsers.
Linky
https://www.ignitech.cz/en/vyrobky/dccdip2/dccdip2.htm
bikers smell of wee
Jay2903
PostPosted: 19:43 - 09 Feb 2022    Post subject: Reply with quote
Stator readings hot
1 - 5 = 126
2 - 5 = 103
3 -5 = 348
4-5 = 124
6-5 = 108
7-5 = 237
9-5 = 364
9-8 = 99
The last post was made 4 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 3.69 - MySQL Queries: 13 - Page Size: 132.12 Kb
