| Jay2903 |
 Jay2903 Scooby Slapper
| WD Forte |
 WD Forte World Chat Champion
| Jay2903 |
| Nobby the Bastard |
| WD Forte |
| Nobby the Bastard |
| blurredman |
 blurredman World Chat Champion
 Posted: 17:09 - 31 Jan 2022 Post subject: |
Mine (and all) cx's are buggers to start if left for more than a few weeks. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 52k. |
| Easy-X |
 Easy-X Super Spammer
| kgm |
 kgm World Chat Champion
| WD Forte |
| blurredman |
 Posted: 19:05 - 31 Jan 2022 Post subject: |
| kgm wrote: | | blurredman wrote: | Mine (and all) cx's are buggers to start if left for more than a few weeks. |
Mine is fine. I keep it with the fuel tap off, then when using it turn it back on and drain a little fuel by opening the drain screw on each carb. Starts first time nearly every time. |
I've heard of that. But i've never bothered. Mine runs up fine enough if I just let it crank long enough, and keep on the throttle until 2nd cylidner kicks in.. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| Jay2903 |
| WD Forte |
| Jay2903 |
| bikenut |
 bikenut World Chat Champion
 Posted: 15:56 - 01 Feb 2022 Post subject: T |
Your videos took Thier time !
Anyways just watched them...
Can't remember if the valves are inclined or not, will go to CMSNL for a look-see next.
From memory valve clearance adjustment is via screw abnd lock nut ?
You say bike been standing idle for some time...
Valves ( and clutches, brakes, cables etc. ) Can and do stick, open usually.
By its nature, left standing, a valve or too can be left open, humidity can end up in cylinder and valve seats/faces etc. And cause poor sealing...
Plugs are deeply recessed, are/where the "water drain holes" clear...?
Compression test after valve clearance check.
Where any valve clearances rather wide, particularly on the "fluttering dash pot piston" side, the piston that flutters ?
Off to CMSNL for a look-see... ____________________ nuts about bikes |
| bikenut |
| bikenut |
| Jay2903 |
| blurredman |
 Posted: 05:45 - 09 Feb 2022 Post subject: |
You can get the same symptoms of high speed coil breakdown with spark plug cap issues, indeed.
What did your stator readings come to? ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| bikenut |
| blurredman |
 Posted: 11:06 - 09 Feb 2022 Post subject: |
They post this on the CX forum all the time, but it's a handy image...
I have a few markings myself though which are barely just about within margin, and one or two are a little out but the whole system working fine for me still at the minute. 90k miles on my original stator here...
https://www.cx500forum.com/attachments/correctedstatorchart_zps6ab4572d-jpg.20258/ ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| Jay2903 |
| blurredman |
 Posted: 14:30 - 09 Feb 2022 Post subject: |
Oh dear.
Until the stator is rewound (or replaced) you'll be limited to slow speed..  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| WD Forte |
 Posted: 16:25 - 09 Feb 2022 Post subject: |
I dumped all that AC CDI bollox for the later TI systems on my CXs
If I had an AC CDI CX now I'd just get an Ignitech DCCDIP2 for it.
OK Its £150 plus postage but its Plug and play so no dropping the lump whipping the back off with all the associated faffery and cost
so its actually of cheaper and easier
Also, if you do replace the stator, the CDI boxes can fail suddenly with no warning leaving you up shit creek cos they is like well NLA innit
Also 2:
The advance coils at the back of the case can quietly fail
This won't stop the bike but will rob it of some of its 'get up and go'
Ignitechs work on DC so independently of all these elderly systems bar the pulsers.
Linky
https://www.ignitech.cz/en/vyrobky/dccdip2/dccdip2.htm ____________________ bikers smell of wee |
| Jay2903 |
The last post was made 4 years, 151 days ago. Instead of replying here, would creating a new thread be more useful? |
