Throttle Slide not Moving when Screwed in
Effexion
PostPosted: 12:02 - 23 Feb 2022    Post subject: Throttle Slide not Moving when Screwed in Reply with quote
My throttle cable snapped, so I replaced it. The problem is that now it won't work. When the slide is out of the carb if the cable springs as expected, but once I screw it in I get nothing.
The slide is correctly aligned with the groove. Any help would be massively appreciated.
My bike is a Lexmoto Venom 125 (not EFI).
A100man
PostPosted: 14:11 - 23 Feb 2022    Post subject: Reply with quote
If it slides all the way down when you re-assembled it then the cable should be able to pull it back up - unless you've mis-placed the nipple somewhere (oo-err).
steve the grease
PostPosted: 14:59 - 23 Feb 2022    Post subject: Re: Throttle Slide not Moving when Screwed in Reply with quote
First and second sentence -fine.
"When the slide is out of the carb if the cable springs as expected, but once I screw it in I get nothing."
Can you explain a bit more, I can't get anything from this .
What is happening , or not? Have you compared if the cables are they roughly the same length ? Have you installed the cable and when it is out of the bike and you twist the throttle it moves, but when you install the slide back in the carb, you can't get it to go , or what?
Nobby the Bastard
Harley Gaydar
PostPosted: 15:42 - 23 Feb 2022    Post subject: Reply with quote
Are you assuming the notch for the idle screw is the notch for holding the slide in position and vice versa?
Triumph Sprint ST 1050
Bhud
PostPosted: 15:58 - 23 Feb 2022    Post subject: Reply with quote
You will have made a mistake when putting it back together. Slow right down, do it again and don't force anything.
PostPosted: 19:48 - 23 Feb 2022    Post subject: Reply with quote
Is the needle going all the way into the needle jet? Easy to get it in cock-eyed.
The last post was made 4 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.58 - MySQL Queries: 13 - Page Size: 47.1 Kb
