| Effexion |
 Effexion L Plate Warrior
| A100man |
 A100man World Chat Champion
 Posted: 14:11 - 23 Feb 2022 Post subject: |
If it slides all the way down when you re-assembled it then the cable should be able to pull it back up - unless you've mis-placed the nipple somewhere (oo-err). ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
| steve the grease |
 Posted: 14:59 - 23 Feb 2022 Post subject: Re: Throttle Slide not Moving when Screwed in |
| Effexion wrote: | My throttle cable snapped, so I replaced it. The problem is that now it won't work. When the slide is out of the carb if the cable springs as expected, but once I screw it in I get nothing.
The slide is correctly aligned with the groove. Any help would be massively appreciated.
My bike is a Lexmoto Venom 125 (not EFI). |
First and second sentence -fine.
"When the slide is out of the carb if the cable springs as expected, but once I screw it in I get nothing."
Can you explain a bit more, I can't get anything from this .
What is happening , or not? Have you compared if the cables are they roughly the same length ? Have you installed the cable and when it is out of the bike and you twist the throttle it moves, but when you install the slide back in the carb, you can't get it to go , or what? ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of..... |
| Nobby the Bastard |
| Bhud |
 Bhud World Chat Champion
The last post was made 4 years, 173 days ago. Instead of replying here, would creating a new thread be more useful? |
