| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 11:47 - 25 Mar 2022 Post subject: Leakdown Tester Recommendation UK |
In another thread someone suggested using a leakdown tester to check the compression on my VFR750.
I've been having a look around and OTC ones seem to be recommended, but I can only find them for sale in US. There are loads of cheap ones on ebay but they seem like typical chinese quality. Can anyone recommend a decent one for sale in the UK? The only real requirement is that it has a 10mm thread adapter to fit the VFR750 (most of the car ones don't have adapters that small). ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
| MCN |
 MCN Super Spammer
| Zen Dog |
| MCN |
 MCN Super Spammer
 Posted: 20:55 - 25 Mar 2022 Post subject: |
A leak down test is still only a bit more than a Compression test.
If it's what I think it is it's pushing air into the engine and then listening for leakage of the air through the breather. (Ring/ Valve Guide wear)
And the inlet/exhaust system. (Valve wear).
Probably an exercise in futility as more than likely the engine needs to come out the frame for either to be remedied.
And once out we may as well do all of it.
On big engines there may be a saving where whipping the guts out of the beast is not necessary or for a cost-effective reason. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Zen Dog |
 Posted: 17:46 - 28 Mar 2022 Post subject: |
| MCN wrote: | Probably an exercise in futility as more than likely the engine needs to come out the frame for either to be remedied. |
I'm not sure why you think it's futile, I'd rather find out in advance that I needed to take the engine out, than take the engine out and find out I didn't need to.
But it seems like no-one knows where to get them in the UK anyway, so it's a bit of a moot point either way. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| Zen Dog |
 Posted: 19:23 - 28 Mar 2022 Post subject: |
| Kawasaki Jimbo wrote: | Which other thread? |
It was this one - https://www.bikechatforums.com/viewtopic.php?t=333972
Tatters made the suggestion, but he's over in Canada if I remember correctly, so he might just have thought leakdown testers are easier to get hold of in the UK than they actually are.
And no I haven't done a compression test, because I don't have a compression tester either. That's why I thought getting a leakdown tester would be a good idea, since it tells you the same info as a compression tester (and more potentially) and it would be a useful addition to the toolkit.
But I'll just get a compression tester instead. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| MCN |
 MCN Super Spammer
| Zen Dog |
| MCN |
 MCN Super Spammer
| tatters |
 tatters Exxon Valdez
 Posted: 21:10 - 28 Mar 2022 Post subject: |
My experience with compression testers vs leak down tester is that a leak down tester will give a much more accurate indication of top end wear and issues. Plus a lot of compression testers are inaccurate chinese junk. Though l will test with a compression tester first then carry out a leak down test to pin point the suspected issue.
Best analogy l heard of was that a compression tester is like a blood pressure cuff and a leak down tester is like a electrocardiogram.
When a leak down test is carried out the leak percentage is calculated (normally from 100 psi). No matter what air will leak out from the valves/piston 15-20 percent is acceptable any greater than that you then need to then listen for the following for a sizeable air leak.
Air leaking from intake - intake valves
Air leaking from exhaust - exhaust valves
Air leaking from cylinder head or into cooling system - head gasket
Air leaking from oil filler/crankcase - piston rings
I have the OTC tester which was about $150CAD
EDIT: This site gives a good explanation, l must came across it in the past long ago.
https://www.pegasusautoracing.com/document.asp?DocID=TECH00137 ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| sickpup |
 sickpup Old Timer
 Posted: 14:36 - 07 Apr 2022 Post subject: |
I've got one somewhere but god knows where.
Adaptors are easy to get, even Amazon have them. |
| Fizzer Thou |
| MCN |
 MCN Super Spammer
 Posted: 09:30 - 28 Apr 2022 Post subject: |
https://youtu.be/DNKO_qI5b1M
The argument of what to work on still stands.
If getting to detected failed parts negates engine removal then time/cash may be saved.
Butt... The cost of parts versus the benefits in reliability and possibly performance outweighs the those costs.
If you need to take the bastirt out of the frame then do all of it. (Whether it needs it or not.)
Building in reliability is what good engineering practice dictates.
Based on time, cash, abilities. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
The last post was made 3 years, 336 days ago. Instead of replying here, would creating a new thread be more useful? |
