GSX600F carb issues.
Auld Eejit
PostPosted: 18:29 - 27 Apr 2022    Post subject: GSX600F carb issues. Reply with quote
Greetings folks.
We picked up a 94 Suzuki GSX600F for my wife. Unfortunately the previous owner had re-jetted the thing and stuck a set of godawful foam filters on it. I ordered new original jets, o-rings, gaskets etc. Problem is I discovered each chamber has this little black plastic plug like thing the position of which defeats me. On opening the float chamber the thing fell out before I could locate it's position. In fact the only one that didn't fall out looked as if it shouldn't be where it was. I can't locate the part in any of the manual's exploded views or pictures. Hopefully someone knows what to do with the things. The floats themselves are a two part plastic assembly that has has to be split to remove the float needle.
Thanks in advance
A100man
PostPosted: 19:40 - 27 Apr 2022    Post subject: Reply with quote
I think this calls for a photo..
Auld Eejit
PostPosted: 19:55 - 27 Apr 2022    Post subject: Reply with quote
I thought that too so here you go. It also occurs this might require an o-ring, but there wasn't one on any of the parts.
Kawasaki Jimbo
PostPosted: 20:08 - 27 Apr 2022    Post subject: Reply with quote
I don’t think that’s the photo A100man is looking for.
Easy-X
PostPosted: 20:43 - 27 Apr 2022    Post subject: Reply with quote
Is this it?
https://youtu.be/95nlrP-yn2I?t=428
Auld Eejit
PostPosted: 20:46 - 27 Apr 2022    Post subject: Reply with quote
Being as it's a photo of the part I was referring to. I kind of assumed.
Anyway.... I'm nothing if not flexible, here's a couple more.
Auld Eejit
PostPosted: 20:54 - 27 Apr 2022    Post subject: Reply with quote
Easy-X wrote:
Looks like a similar component, but where my bit goes is the puzzle. Thankyou sir. Smile
Auld Eejit
PostPosted: 21:04 - 27 Apr 2022    Post subject: Reply with quote
The parts as best I can tell were seated under the float needle, but one of them was in the port slightly above and left of the main jet. Hence the confusion over where they should be. They're also quite loose in either position which is why I mention o-rings.
redeem ouzzer
PostPosted: 11:17 - 28 Apr 2022    Post subject: Reply with quote
Blanks off the pilot jet main feed so it uses the side feed on the jet tower instead. Available new but not cheap.
Be a REAL MAN!
Auld Eejit
PostPosted: 12:08 - 28 Apr 2022    Post subject: Reply with quote
Thankyou sir. I have all four plugs but they're not particularly secure. Would you know if they're held in place with an o-ring or some other method?
Many thanks again.
redeem ouzzer
PostPosted: 12:11 - 28 Apr 2022    Post subject: Reply with quote
Many thanks again.
They are held in by the rubber serrations alone, so especially with modern fuel, they tend to shrink and try and fall out. If they are slack the bike will run rich. I think it was an attempt to give a more stable pilot mixture but it's a pain in the arse.
Be a REAL MAN!
Auld Eejit
PostPosted: 12:25 - 28 Apr 2022    Post subject: Reply with quote
Many thanks again.
So put simply I have to replace them as the raised section of the plugs are all smooth. Thanks for the advice. I'll have a word with my local bike guys and see if they can get the parts. I'll have a wee gander on the internet as well. I presume they're referred to as main jet blanks or something similar. Many thanks again sir, you're a star. Smile
redeem ouzzer
PostPosted: 12:36 - 28 Apr 2022    Post subject: Reply with quote
Part code 13357-34C00
Be a REAL MAN!
Auld Eejit
PostPosted: 12:43 - 28 Apr 2022    Post subject: Reply with quote
Cheers mannie. I'll get onto that.
A100man
PostPosted: 12:54 - 28 Apr 2022    Post subject: Reply with quote
Nope - genuinely asking for photo of carbs..
..some people Rolling Eyes
The last post was made 3 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.79 - MySQL Queries: 13 - Page Size: 81.83 Kb
