OBD II Bluetooth reader for car
Ribenapigeon
PostPosted: 14:07 - 26 Jun 2022    Post subject: OBD II Bluetooth reader for car Reply with quote
Im thinking of buying one of those OBD port readers that can then Bluetooth the data to a smartphone for my car. Anyone have any experience of them? Ones to avoid, android apps etc.
Cheers
Easy-X
PostPosted: 14:55 - 26 Jun 2022    Post subject: Reply with quote
If you just buy a cheap one off FleaBay then bear in mind they come in two flavours: Bluetooth for Android, WiFi for iPhones. TBH dedicated hand-held readers are fuck all money and much more convenient, depends what you want to do...
I use an app called Torque which unfortunately has morphed into a bit of a beast (as in more options than you can shake a stick at but it does read codes.) It has a virtual dash and I set up coolant temperature and manifold pressure gauges as my car doesn't have those.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:21 - 26 Jun 2022    Post subject: Reply with quote
WiFi ones work on android too. It's more a case of what your software can use.
Triumph Sprint ST 1050
Easy-X
PostPosted: 17:30 - 26 Jun 2022    Post subject: Reply with quote
I wouldn't recommend the WiFi option unless you have to, I have one of those from when I had an iPhone. I still use it on Android but you have to piss about to tell the phone to use mobile data instead of WiFi but still keep the WiFi on and all the while the phone is super upset 'cos it thinks it's connected to a bum WiFi router - Samsung being overly helpful Sad YMMV on other Android brands ofc.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:14 - 26 Jun 2022    Post subject: Reply with quote
I've not had that problem. My Samsung swaps straight to data automatically cause it can't get the internet via wifi and to say that wifi ones aren't for android is clearly wholly incorrect.
Kawasaki Jimbo
PostPosted: 19:03 - 26 Jun 2022    Post subject: Reply with quote
I’ve got a cheap Giveet Car WIFI OBD2 Scanner and the EOBD-Facile app. Connection is easy and the app is free unless you want to upgrade, which I haven’t done.
You can gather sensor and performance data on the move to view later but since my car’s OBD socket is above the pedals I don’t trust it not to fall off and obstruct them. However it did indicate a fault on ignition coil #1 when I had a misfire.
to v or not to v
PostPosted: 19:36 - 26 Jun 2022    Post subject: Reply with quote
i bought a cheap one, off the bay, for a Ford, a few years back. it was easy enough to use, via a phone app. reset the codes too, which was handy.
Moto Guzzi V7.
t121anf
PostPosted: 21:24 - 26 Jun 2022    Post subject: Reply with quote
I use an obdeleven with my car, excellent tool.
Ribenapigeon
PostPosted: 22:50 - 26 Jun 2022    Post subject: Reply with quote
There's a lot on Amazon and Ebay. Im looking at Bluetooth ones. Im just bot wanting to screw the car yo plugging a bad one in. Are they all essentially the same or are there ones to avoid?
Easy-X
PostPosted: 23:35 - 26 Jun 2022    Post subject: Reply with quote
I had the best results with the ultra cheap translucent blue ones.
Ribenapigeon
PostPosted: 23:53 - 26 Jun 2022    Post subject: Reply with quote
Kitbest OBD2 Bluetooth OBDII OBD Reader Car Fault Code Reader Automotive Diagnostic Scan Tool, Mini Bluetooth OBD2 Scanner for Android https://amzn.eu/d/4xUrBAn
This?
Tarmacsurfer
PostPosted: 18:05 - 04 Jul 2022    Post subject: Reply with quote
They're almost all based on the Elm327 chip, they're pretty good as a rule.
I'm immortal. Well, so far.
The last post was made 4 years, 94 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 71.48 Kb
