| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 16:35 - 12 Jul 2022 Post subject: VFR800FI Clutch Lifter Rod |
So, the bite point on the 800 is just before the lever is fully released. It's been like this since I got it. There's no slip at all, but I would like to have a bit more range in the lever travel. It's hydraulic so there is no adjustment. I've checked out all the slave side of things, given it all a clean, flushed the fluid etc. I've also got the 750 to compare it to (which I think is honestly identical). It's all fine.
But it looks like the "clutch lifter rod"(14 on the pic) that goes through the engine to the clutch is sticking out too far on the slave side. You can't refit the slave cylinder flush, the rod pushes it away from the engine, so to refit it I had to use tightening the bolts to get it back flush. I can directly compare this to the 750, and yeah, it's sticking out too far. Given that this means that the clutch is always partly actuated, this explains the symptoms at least.
https://i.imgur.com/dsXCFhL.png
I've pulled out the rod and cleaned it (it was pretty clean anyway) and that didn't make any difference. Clearly I need to get in on the clutch side. Since I'm getting in there (and the clutch has possibly never been changed), I've ordered friction plates/springs/bolts/gasket.
Question is, what am I going to find? What could be causing this? My first thought is crap filling up the rod seat on the clutch side (11 on the pic I think). But what are the other possibilities that I need to look for? Could it simply be worn plates? There were 2 versions of the clutch for this model, I have the earlier version with an extra plate. Could the wrong version have been fitted and this explain the symptoms? ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
| Nobby the Bastard |
| Zen Dog |
| Nobby the Bastard |
| jeffyjeff |
 jeffyjeff World Chat Champion
| Nobby the Bastard |
 Posted: 20:01 - 12 Jul 2022 Post subject: |
Only things I can think of are the bearing (18) not being properly seated in the pressure plate, the rod seat (11) not being properly seated in the bearing or the rod not being properly seated in the seat.
Other things would be missing spacers or simply wrong parts. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Zen Dog |
 Posted: 20:03 - 12 Jul 2022 Post subject: |
| Nobby the Bastard wrote: | Some bikes with that clutch setup do have then and one may have been added at one point.
Did you ensure the slave cylinder was fully retracted before fitting? |
Yeah, it doesn't actually stay fully retracted, as there's a spring that pushes it forward, but you should still be able to push it flush with the engine. On the 750 you can, on the 800 you can't. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| Zen Dog |
 Posted: 20:07 - 12 Jul 2022 Post subject: |
| stinkwheel wrote: | Other things would be missing spacers or simply wrong parts. |
This is what I'm most worried about, as lots of the smaller parts are simply not available from Fowlers/David Silver etc. But we'll just have to see.
EDIT - I wouldn't normally worry about a VFR having the wrong parts or anything, VFR owners are usually sensible types, and the guy I bought it off seemed so. But after seeing state of the scottoiler when I got it (and it had been messed with by someone who clearly didn't understand how it worked) I had a few doubts. Then I recently gave it a service, and the air filter looked like this.
https://i.imgur.com/0vDTt0P.jpg
The black bits are foam off the underside of the tank, but the seeds? I have no idea how the hell they got in there. These are not the floaty, get sucked in, airborne type. And the path air takes to the filter isn't straightforward. Did the guy ride through a wheatfield at high speed? Get handfuls of seeds thrown at him by an angry ploughman? I have no idea. But it does make me worry what I might find. Will the clutch cover be full of turnips? On the upside, the clutch is actually functioning perfectly aside from the bite point, so I'm hopeful it's something simple. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| Zen Dog |
 Posted: 18:08 - 16 Jul 2022 Post subject: |
Right, so I've got the clutch pack apart. I forgot how much of a pain it is cleaning the old gasket off (especially when it gets stuck on the engine side). Anyway, checked all the parts against the service limits (friction plates, spring free length etc.), also it's got the right number of plates and all the parts seem to be correct and in their correct positions. Anti-judder spring and seat all present and correctly orientated. No ball bearing on the end of the lifter rod or in the rod seat.
Literally all I've got at this point is below. With the slave bolted flush on the other side, this is the lifter rod on the clutch side. -
https://i.imgur.com/7yM0GZu.jpg
https://i.imgur.com/6fhPSNn.jpg
And this is an image from the service manual -
https://i.imgur.com/Anc2TgA.png
Assuming the manual isn't showing it with the slave removed on the other end, it's sticking out too far. So, somehow (and it seems unlikely), the lifter rod is 1cm too long? What other possibilities are there?
I have seen mentioned on the VFR forums that the return hole on the master cylinder can get clogged, leading to a build up in pressure that means it doesn't release fully, I did clean this out as part of my initial efforts to sort this issue, as well as flushing the fluid but maybe I didn't do it well enough?
Any suggestions welcome as I really can't think of any other possibilities now.
More pics here in case they are of any use - https://imgur.com/a/pIGBMYr ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| to v or not to v |
 to v or not to v World Chat Champion
| Zen Dog |
 Posted: 00:38 - 17 Jul 2022 Post subject: |
| to v or not to v wrote: | my clutch is hydraulic too and also has a very late release point. are you sure this isnt a symptom of hydraulic clutches? |
I am sure, but only because my VFR750 has a very similar (if not identical) clutch setup, and it's not like this. The clutch begins to bite roughly in the middle, as you'd expect.
I've been thinking about it this evening, and I'm coming to the conclusion that it's most likely to be the return hole on the master. When I cleaned it last time, I just soaked up all the spooge at the bottom, flushed all the fluid until it was clean, and thought that was good enough. But someone mentioned sticking a thin wire down the return hole to clean it out, so I'll try that next, as the only alternative seems to be sourcing a replacement lifter rod on the dubious possibility that it's the wrong one, or finding someone who has the same model as me and getting them to measure theirs. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| Zen Dog |
 Posted: 21:53 - 18 Jul 2022 Post subject: |
Well I put the clutch back together with the slave side off, and then put the slave side back on. It was taking some force to tighten the bolts on the slave to get it flush......... and then there was an barely audible "pfft" from the master up on the handlebar, the pressure disappeared off the bolts and I was able to snug them up easily.
And now it's fixed. So I think the force of the clutch (with its new heavy duty springs) did the job of clearing the return hole on the master for me. At least I know not to waste my money on a new clutch kit next time. And it's all working, so yay. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| jeffyjeff |
The last post was made 4 years, 69 days ago. Instead of replying here, would creating a new thread be more useful? |
