Honda CD200 Swing Arm Replacement
10kovako
PostPosted: 09:37 - 20 Jul 2022    Post subject: Honda CD200 Swing Arm Replacement Reply with quote
Hi all!
I’ve just purchased a Honda CD200 to repair. And have noticed that the metal joining the two sides of the swing-arm a is made out of rust. Can literally poke a hole through it!
After scouring on the internet I have not found replacements available - so this is my last shot, does anyone have one lying around that I could purchase? I’m based in the UK.
Do let me know and thank you in advance!
Let’s do this
A100man
PostPosted: 12:39 - 20 Jul 2022    Post subject: Reply with quote
.. go on show us a picture!
maybe a good welder could repair it?
PostPosted: 13:27 - 20 Jul 2022    Post subject: Reply with quote
Check the frame hasn't gone the same way before you spend a load on it. Those pressed steel frames are rotboxes.
WD Forte
PostPosted: 13:36 - 20 Jul 2022    Post subject: Reply with quote
See?
Even I can bung an image up
Why do so many post asking for help
on here and give the absolute minimun info?
There's no charge for words or pics y'know
Hers a CD200 Benly S/A
https://www.hondatwins.net/attachments/126-jpg.53840/
Typical Honda rot, very common
https://www.hondatwins.net/attachments/007-jpg.53843//
and repaired
https://www.hondatwins.net/attachments/012-jpg.53844/
They're all built to a similar patterns as the early CXs which
often suffered the same way
I must have rebuilt about 8 CX ones over the years for myself and others
bikers smell of wee
Fizzer Thou
PostPosted: 14:00 - 20 Jul 2022    Post subject: Reply with quote
The swinging arm for the CD200T is the same as for the CD185T,which may well broaden your search.
A friend might have one.I have asked him and await his reply Thumbs Up
Always have a 'Plan B'
10kovako
PostPosted: 19:04 - 20 Jul 2022    Post subject: Reply with quote
Sorry all! Didn’t even cross my mind to post photographs. The rust is from where the bike was sat for 20 years with a leak in the roof directly dripping on it. The rest is fine! Do you reckon a welder could fill that in and pass an MOT? Or is the metal too thin in that area?
All of the help is greatly appreciated - so thanks everyone!
Anything else to warn of this bike before I begin to disassemble?
I've had a look for the CD125, and 185 - also nothing sadly.
Let’s do this
PostPosted: 19:15 - 20 Jul 2022    Post subject: Reply with quote
Do let me know!
We can't tell you without seeing it. Bear in mind you can only weld solid metal to solid metal, you can't weld to rust. If you can poke a hole in it with a screwdriver, it's not solid metal. So have a pick and a poke and a wire brush at it. Any bits that fall, flake or crumble off are no good anyway, see what you're left with.
You say the rest is fine but have you actually taken the tank and some bodywork off and looked?
10kovako
PostPosted: 19:17 - 20 Jul 2022    Post subject: Reply with quote
Yes! I've taken side panels off, and the tank. All seems to be in good shape. Was just the drip area that got destroyed! Seat leather also turned to mush because of it!
Let’s do this
PostPosted: 19:36 - 20 Jul 2022    Post subject: Reply with quote
Picture is showing now. Hard to say, it'll certainly need patching.
If it were me, I'd take it off, take pictures from all angles then have a go at it with a rotary wire brush and see what's left at the end. It's certainly not useable as it is.
If it turns into a huge pile of rust flakes, it wasn't fixable. If it's just a few holey gussets and the rest is solid, it may be able to be patched.
Fizzer Thou
PostPosted: 12:26 - 21 Jul 2022    Post subject: Reply with quote
I had a chat with Paully and he mentioned that he has a spare but as he is building up another Benley then he is keeping a hold of it.
But he did say that he has bought a few items from a place in india called Honda Roadmaster.
The only other places that he could suggest is on f/b
https://www.facebook.com/groups/1548487728507335/about/
or cmsnl.com as they have them in stock
https://www.cmsnl.com/honda-cd185t-england_model50480/fork-rrnh-1_52100402000za/
10kovako
PostPosted: 13:21 - 21 Jul 2022    Post subject: Reply with quote
Here's another image after going at it with a hammer! Thank you for the link - sadly second one is out of stock!
Thanks for all the help again - I've sent this image to a welder for a quote. You reckon they'll even want to do anything to it?
Let’s do this
Rob W
PostPosted: 14:46 - 21 Jul 2022    Post subject: Reply with quote
Whereabouts are you based? I run a fabrication workshop, and have blokes that would quite happily mess about on that in there lunch break for a few beer tokens.
I'm in Essex by the way.
Robby
Dirty Old Man
PostPosted: 13:42 - 22 Jul 2022    Post subject: Reply with quote
If the swingarm is that bad, I would recommend getting a really good look at the frame in that area. If it has a cross brace between the footpegs, it's likely to also be fucked.
The last post was made 4 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 78.2 Kb
