Gear gaps.
steveh
PostPosted: 07:44 - 11 Apr 2005    Post subject: Gear gaps. Reply with quote
On my bike there seems to be a slight gap between 2nd and 3rd, ive been told that this isnt a big problem so i was wondering if any of you fellows get it ?
By a gap i dont mean a great space i mean, when i get lazy i often fall between the gears, especialy setting of fast from traffic lights Razz
bit of a pain but is it just me ?
Steve.
PostPosted: 11:50 - 11 Apr 2005    Post subject: Reply with quote
Fairly common, but tends to be triggered by poor clutch adjustment. Might be worth adjusting the gear lever down slightly so you are more likely to lift it properly into position.
Phoenix
Twisted Firestarter
PostPosted: 12:22 - 11 Apr 2005    Post subject: Reply with quote
Bad chain adjustment sometimes causes it too, I was forever getting false neutrals on my fireblade, it's just the gearbox, both of them did it.
Valver
PostPosted: 12:27 - 11 Apr 2005    Post subject: Reply with quote
The last 3 bikes i've owned other than my TL1000R (suzuki gear box Thumbs Up ) have had false neutrals between every gear!!!!! Mad Only ever hit then when not using the clutch though. Thumbs Down Evil or Very Mad
M1ke
Ped Boi
PostPosted: 12:53 - 11 Apr 2005    Post subject: Reply with quote
Does anyone else get a nasty crunch when they change from first into second when reving the knackers off of it?
All my bikes seem to have done it apart from my RS125, normally have to wait for the revs to die down in 1st gear before knocking it up...
Maybe its just my shoddy gear changes.
steveh
PostPosted: 13:33 - 11 Apr 2005    Post subject: Reply with quote
yeah, the dads norton has gaps in every gear, also my chain was a tad slack tightend it up, will see if it does it anymore.
Steve.
simon1221
PostPosted: 20:42 - 11 Apr 2005    Post subject: Reply with quote
Just give the gear lever a good shove when changing gear.
I have been lazy and redlined (false neutral) it when trying to change into 6th at 75mph Shocked
instigator
PostPosted: 20:46 - 11 Apr 2005    Post subject: Reply with quote
I can almost hear ste laughing Laughing
I done it a couple of times on my er5, just when I started using the er5. All sorted now though, might just be becasue I use big steel capped boots to change gear. Rather positive changes I tell you Laughing
Just tried not using the clutch for the first time the other day. Bit overrated Laughing
Valver
PostPosted: 11:15 - 12 Apr 2005    Post subject: Reply with quote
All Hondas i must add!!!!
Claud 14.7 to 1
PostPosted: 11:48 - 12 Apr 2005    Post subject: Reply with quote
I used to get this on my bike, it's common on bikes. It used to do it more harshly, which leads me to believe technique can help overcome it. It needs a fair whack up from 1-2. Quick clutch and quick forceful whack up. Thumbs Up
From 1-2 (unless I'm not revving it hard), I'll use clutchless and it slots nicely in. Again needs a fair amount of force for that particular change.
From my experience a bike gearbox will need different inputs depending on the load and which gear changes. For example 1-2 and 5-6 need a more positive shift on mine. Higher revs also needs a more forceful shift, particulary when doing clutchless. I guess different gearboxes have different characteristics, which you will have to adapt to.
The last post was made 21 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 65.38 Kb
