| The Artist |
 The Artist Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 20:10 - 06 Feb 2023 Post subject: |
I saw a post on another forum about this very thing recently. Rate had gone from 41p/kwh to £1.23.
There was some speculation that they might have started charging that kwh rate and multiplying it by the number of phases serviced (£0.41 x 3 = £1.23) ____________________ a.k.a 'Geri'
| WD Forte |
 WD Forte World Chat Champion
| A100man |
 A100man World Chat Champion
 Posted: 21:12 - 06 Feb 2023 Post subject: |
Cabnyou compare kWH usage with last year.. assuming the metering set-up has not changed they should be similar.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| The Artist |
| doggone |
 doggone World Chat Champion
| The Artist |
| tatters |
 tatters Exxon Valdez
 Posted: 18:04 - 13 Feb 2023 Post subject: |
A utility suppliers three phase meter should be reading and totalling from all three phases. This is required as there will always be unbalance of current draw from each phase, as you mentioned the use of single phase equipment.
I have in the past with PLCs with limited I/O space added metering to three phase equipment using only one current transformer on one phase, and then calculated the other two phases but this only worked as the current draw from all three phases were constantly the same. No way this would be acceptable for buildings main meter. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
The last post was made 3 years, 253 days ago. Instead of replying here, would creating a new thread be more useful? |
