| A100man |
 A100man World Chat Champion
 Posted: 12:19 - 27 Feb 2023 Post subject: Blade fuse holder repair.. help! |
Hi all.
FZ 750 has a broken wire on the ignition circuit close to fuse holder.
I wish to push out one of the terminals and re-fix with a new piece of
'good' wire..
But how the f*ck does one extract a terminal (see pic)..?
Ta ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| jaffa90 |
 jaffa90 World Chat Champion
 Posted: 12:57 - 27 Feb 2023 Post subject: |
| Islander |
 Islander World Chat Champion
| A100man |
 Posted: 13:59 - 27 Feb 2023 Post subject: |
Not this time but thanks. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| A100man |
 Posted: 14:01 - 27 Feb 2023 Post subject: |
| Islander wrote: | There will probably be a small tab that springs out to lock the connector in place when it's pushed home. You'll have to push that tab in somehow.
What I was looking for. It didn't help that I had no glasses with me . I took phone photos but noting obvious. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| A100man |
 Posted: 14:09 - 27 Feb 2023 Post subject: |
| stinkwheel wrote: | Yes, you need a small shimming tool to insert into the connector block to push down the tab as you apply gentle traction to the terminal. If you search for terminal extractor tool, you'll find umpteen sets for extracting any number of different terminal types for much cheapness. Although I find a very fine watchmakers screwdriver usually does the trick. |
I think I should have will give it a go and report back in a few days. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Ste |
 Ste Not Work Safe
| WD Forte |
 WD Forte World Chat Champion
 Posted: 15:09 - 27 Feb 2023 Post subject: |
I find old hacksaw blades make good 'poking tools'
and have made them with a bench grinder and/or Dremel
If the latch doesn't immediately free the terminal, a wee bit of twist often
helps it past the step in the connector body ____________________ bikers smell of wee |
| A100man |
 Posted: 15:56 - 27 Feb 2023 Post subject: Re: Blade fuse holder repair.. help! |
Murican? Everyone carries .22 shells there I guess. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| A100man |
 Posted: 15:57 - 27 Feb 2023 Post subject: |
| WD Forte wrote: | I find old hacksaw blades make good 'poking tools'
helps it past the step in the connector body |
Ah yes I once made myself a 'Bogota rake' with one.. Good enough to open the tank of my XJ550.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
The last post was made 3 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
