| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 19:25 - 28 Mar 2023 Post subject: Firestorm Brakes/VFR750 |
So, I've fitted a Firestorm front end to my VFR750. The forks/mudguard/spindle/spacers/brakes/MC are all Firestorm. The front wheel and disks are from the 750. Thread here - https://www.bikechatforums.com/viewtopic.php?t=333972
Problem is, after fitting it, the brakes are shit. They do stop the bike OK with a good squeeze of the lever, but there's no initial bite. They also don't seem to be fully contacting the disk, even after riding 20-30 miles. I don't know how well you can make it out in the pics, but they still have a ring of light surface rust in places (just from getting slightly damp over the winter). Obviously, my first thought is the lines still have air in them. So I've bled them multiple times at the calipers and the MC banjo, ziptied the lever back (this never seems to work for me but I tried it anyway), and reorientated the MC a load of times to try to get any bubbles to the top. No change. It has a 2-line "race setup" from the calipers and they have an upward path the whole way, so I don't think anything is being trapped there.
So the question is this. Before I get further into bleeding it (pushing the pistons in fully in case there are bubbles trapped behind them etc.), and given the changes I have made, are there any other possibilities? I serviced the MC, cleaned up the calipers, refilled the fluid, fitted new pads, and copper greased the tips of the pads before fitting. Could I have contaminated the disk with copper grease somehow? Is that consistent with the symptoms? Given I've changed the front end, could messing that process up in some way have caused this?
Or do they just need more bleeding? I expected the pads to have bedded in enough to be contacting the surface of the disk fully by now even if they did need more bleeding. The disks really aren't badly grooved or anything. I even rolled the bike down a really long hill near me (we have plenty), using the front brake the whole time (and varying pressure) to see if it would help. It didn't, obviously.
Got any ideas?
https://i.imgur.com/4OEtkAfl.jpg
https://i.imgur.com/NM2rg1Hl.jpg
Full Quality Versions -
https://i.imgur.com/4OEtkAf.jpg
https://i.imgur.com/NM2rg1H.jpg ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '10 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
 Posted: 19:51 - 28 Mar 2023 Post subject: |
I suppose you could check the discs are central and square in the caliper by measuring the distance from the disc to the casting at both sides of the leading and trailing edge of the calliper. You can shim under the caliper mount if it isn't. Even my pretecs needed shimming slightly.
I can't see why it would cause that wear pattern though. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Robby |
 Robby Dirty Old Man
| Bhud |
 Bhud World Chat Champion
| Zen Dog |
 Posted: 22:12 - 28 Mar 2023 Post subject: |
A load of good ideas, I'll definitely check them out.
| Bhud wrote: | - whichever MC you're using has to be man enough for the Firestorm brakes, i.e. shift enough volume of fluid into them
- if there's air in the system then the main giveaway would be the lever (being able to pull it too far back)
- if you can bleed them and make the brakes grab tight, but they go loose again later, then there's a leak somewhere
- if your pads are dirty or greasy, that's no good
Why the copper grease on the tips of the pads? |
To answer your questions -
- It's the standard Firestorm MC.
- I can pull it back just a little further than I'd like, but then it builds pressure normally and is solid. I can't get it back to the bar.
- When I ziptied it, I left it overnight. The lever was still pressurising the system the next day. There's no leak as far as I can tell.
- They shouldn't be. They're brand new. But it's always possible I've messed up. I'll get brake cleaner on them.
- Just because the tips slide backwards and forwards on the inside of the caliper. So I did it because I thought it might help them slide better. It probably doesn't but I couldn't really see a downside. Unless it turns out I've contaminated the pads of course... ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '10 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| Bhud |
 Posted: 22:22 - 28 Mar 2023 Post subject: |
OK cool. A Firestorm MC will be exactly right. There shouldn't be any problem, so there's something wrong. Are the lines good, are the copper washers new, is the bleed nipple hole damaged bubbling, etc. Lots of stuff to rule out.
If you suspect air's in the system then you've got to rule it out somehow. At the same time, rule out leaks. I've got a rough and ready method using zip-tie trick to kill 2 birds with one stone. I bind the brake lever halfway back, pressurising the system. Clean everything using whatever solvent, and dry it to bone dry with a cloth. Come back the next day, get your hands clean and dry, and then, leaving the ziptie where it is, touch your little finger under every banjo, and under the caliper seals, master cylinder, etc. If it's leaking anywhere, it will show on the tip of your little finger.
At least it's something you can rule out, if it's not the culprit. Could be a mechanical issue or quality issue as well, as the others are saying. |
| to v or not to v |
 to v or not to v World Chat Champion
| Nobby the Bastard |
| jeffyjeff |
 jeffyjeff World Chat Champion
| MCN |
 MCN Super Spammer
| trevor saxe-coburg-gotha |
| sickpup |
 sickpup Old Timer
| Zen Dog |
 Posted: 22:10 - 30 Mar 2023 Post subject: |
| stinkwheel wrote: | Are all the pistons moving? |
They were when I serviced the MC, I checked them all. They didn't all operate with exactly the same force (I had to hold some pistons so others would operate), but there's usually one or two like this in my experience. None were seriously reluctant. They all slid back in smoothly too and they're pretty clean, only a couple of little marks. If that's the problem I saw nothing to suggest it, but it'll be getting checked again anyway.
| to v or not to v wrote: | its a doddle with a vacuum pump. took me about 5 minutes to do my front breaks.
i highly recommend getting one. |
I've got one. I've had mixed results. It's good for quickly emptying/filling the system, but it hasn't guaranteed an easy bleeding job, for me at least.
| sickpup wrote: | What brand and rating pads did you fit to it?
You still mates with Bill? does he still have access to a brake tester? |
EBC ones (can't remember if I went sintered or not). And no, not really. I can get it on a brake tester if I need to, but the "ultimate braking force" isn't terrible, I can do an emergency stop but not a stoppie. I reckon it would pass an MOT. But initial bite is terrible, wear pattern is weird. Haven't been able get over there and have a proper look at the bike since starting this thread. Tempted to think Robby's suggestion is most likely but I'm keeping an open mind. Will report back once I've had a look. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '10 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| sickpup |
 sickpup Old Timer
 Posted: 13:34 - 31 Mar 2023 Post subject: |
I've even had brembo pads that I had to lightly file the paint off the edges of the backing because they were binding in the caliper slightly.
Incidentally, Brembo SA pads are great. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeffyjeff |
| MCN |
 MCN Super Spammer
| Zen Dog |
 Posted: 12:29 - 02 Apr 2023 Post subject: |
Well... the thick plottens.
Did some checking of things today. Firstly, and most importantly, it appears I didn't fit new pads. Not doing so was bloody stupid and I certainly intended to, but the general grottiness of them (when they've done 30 miles), and looking back over my order history in various places, I can see no record of buying a new set. I'm blaming my terrible memory, that I DID buy and fit new pads for the 800 and the Striple, that I must have put the old pads back in to prevent accidentally pushing the pistons out when they were in storage (and then forgot), and the fact that this process took months. Still, I'm pretty shocked at the state of the left hand pads, despite having plenty of meat on them, they've lost a load of chunks of pad material. The ones on the right hand side look ok. Sintered EBC pads on order.
Moving on, the pad pins look ok, straight as far as I can tell (checked against a fork tube), and a little corrosion but no ridges or anything. The pads were a bit reluctant to come out, but we'll see if that's still the case when I get the new ones. The pistons on both calipers are moving pretty much as I remembered (all moving, some slightly more reluctant). The most significant thing I found was that the right hand calliper was out of alignment, being too close to the outside of the wheel, so the inner pistons could barely move, and the outer ones had to go further than usual. The left hand caliper is bang on though, despite neither of them having any kind of shims/washers between themselves and the fork leg mounting points, and it being the left hand one that's lost chunks of the pad. Looking at the pics, I think the cause of the misalignment is differing thickness of the right hand pads.
Still, new pads and thoroughly clean and maybe wet and dry the disks to remove any contamination, then we'll see where they are.
TL;DR - I'm a numpty. Though whether it all sorts itself with new pads we'll see.
https://i.imgur.com/6uDhMmTl.jpg
https://i.imgur.com/UxrA9djl.jpg
https://i.imgur.com/tSO1BVhl.jpg
https://i.imgur.com/6uDhMmT.jpg
https://i.imgur.com/UxrA9dj.jpg
https://i.imgur.com/tSO1BVh.jpg ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '10 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| Robby |
 Robby Dirty Old Man
| MCN |
 MCN Super Spammer
| Zen Dog |
 Posted: 18:25 - 06 Apr 2023 Post subject: |
Thoroughly cleaned the disks and fitted the new pads. Brakes are now fantastic, and I'm an idiot.
But if, in the future, anyone should want to know the consequences of fitting old (and almost certainly contaminated) pads to different rotors, please feel free to refer them to this thread.  ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '10 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| dave001 |
 dave001 Banned
The last post was made 2 years, 310 days ago. Instead of replying here, would creating a new thread be more useful? |
