| A100man |
 A100man World Chat Champion
 Posted: 13:06 - 03 Apr 2023 Post subject: who knows about paint? |
Back in the day I recall people talking about cellulose and 2k/ 2pack paints.
I always though that cellulose was solvent based thinned with acetone (came also in rattle cans e.g. Holts 'duplicolour')
2k (isocyanate) is the two part hardener plus colour/lacquer.
I also thought that only 2K was petrol resistant, but then some OEM paint which I thought was cellulose must also have been petrol resistant on my Grandad's austin 1100 for example
Today we also have paints variously called 'Enamel' or 'Acrylic Enamel' in rattle cans these are solvent based but as I understand it water base versions are used in the car industry too. Then we also have 2K 'non-isocynate' cans that don't have a hardener and I wondered if these are fuel resistant? Although I think these are only available as flat (non-metallic) shades.
VHT paint is also tricky. Most are high enough to withstand exhaust temperatures of course but do they have other properties such as being oil/petrol resistant? and then you can also buy brake caliper paint.. which one would hope is brake fluid proof, but what else can it do?
To be honest I am rather confused, not helped by the fact that words such as 'Enamel' are used indiscriminately by various suppliers to mean different things.
Does anyone know of a guide or table that indicates the properties vs chemistry of automotive (spray) paints? ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
| WD Forte |
 WD Forte World Chat Champion
| A100man |
| stinkwheel |
| WD Forte |
 Posted: 18:22 - 03 Apr 2023 Post subject: |
Oh Alkyd, yeah that stuff
top of me head, It's a polyester resin modified by the addition of fatty acids and other components. Alkyds are derived from polyols and organic acids including dicarboxylic acids or carboxylic acid anhydride and triglyceride oils.
I spose you could look it up on say wikipedia but I didnt need to  ____________________ bikers smell of wee |
| stinkwheel |
 Posted: 20:15 - 03 Apr 2023 Post subject: |
I suppose the thing to take from it is if it's any sort of resin, it actually cures rather than dries. It alters its chemical structure at a molecular level to make a solid. As such it will tend to be pretty robust once it's cured.
2k paint does it by reacting the paint with a hardener. The VHT paints do a similar thing but heat causes the chemical reaction. The aklkyd resins do it over time exposed to air.
This will be why they tend to be pretty fuel resistant once cured. It doesn't soften with a solvent because it's not the same chemical that was put on there. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeffyjeff |
 jeffyjeff World Chat Champion
 Posted: 06:48 - 04 Apr 2023 Post subject: |
I once painted the front left fairing on my 2000 VFR using Color Rite 3 stage motorcycle paint; base coat, color coat, clear coat. I did it in my garage, but I was very meticulous about following directions to the letter; wet-sanding, tack cloth, and polishing compound. The finished job came out darn near perfectly. Even in direct sunlight, you could not discern a single flaw in the painted fairing. But...under the florescent light in my garage, the painted fairing took on a sickly green hue; like a whole different shade of yellow. It looked like crap.
I called Color Rite. They said the OE Honda paint formulation was proprietary, and unless and until Honda released the recipe, the paint color that I applied to my bike was as close as they would be able to get to the OE color.
To this day, I avoid metallic colors, if I can. ____________________ History shows again and again how nature points out the folly of men - BOC |
| stinkwheel |
| dave001 |
 dave001 Banned
 Posted: 12:59 - 04 Apr 2023 Post subject: Re: who knows about paint? |
| A100man wrote: | Back in the day I recall people talking about cellulose and 2k/ 2pack paints.
Does anyone know of a guide or table that indicates the properties vs chemistry of automotive (spray) paints? |
you aint going to be spraying water based crap without a booth and heating lamps to cure it
and i would no recomend spraying two pack at home you can get away with it with a resparator if you junk it quick epecily if outside as most of it will go up in the air
but the problem is you dont know when the resperator is failing as ISO`s the most dangerous bit in 2k/two pack paints has no smell at all
with solvent bansed paint you can smell it if you can smell a rag of thinners it toast but before that you could easly be inhaling ISO`s and that you dont want its nasty shit and can do perminat damage
it should really be sparayed with a air feed hood from a clean /filltered air supply
if you doing any home paint id recomend using 1k and see if you can get a local body place to blow some 2k clear in between other jobs there doing
as for a decent finish and petrol proof nothing will come close to a 2k clear
and of your not use to spray clear is the hardest part in sparying to get right
basicly you need to put on a tack coat then heavy on next coats all most to the point of it running but not quite
or it will go on dry like sand paper temp needs to be over 10degs c
and if humidity is to high it wil bloom and go milky
| dave001 |
 dave001 Banned
 Posted: 13:03 - 04 Apr 2023 Post subject: |
| jeffyjeff wrote: | I once painted the front left fairing on my 2000 VFR using Color Rite 3 stage motorcycle paint; base coat, color coat, clear coat. I did it in my garage, but I was very meticulous about following directions to the letter; wet-sanding, tack cloth, and polishing compound. The finished job came out darn near perfectly. Even in direct sunlight, you could not discern a single flaw in the painted fairing. But...under the florescent light in my garage, the painted fairing took on a sickly green hue; like a whole different shade of yellow. It looked like crap.
To this day, I avoid metallic colors, if I can. |
i take was a matalic paint its hard to match without a lot of practice
you need to try and match the gun movments of the original paint
and if you dint use a decent 2k clear the light would hit it different and be rather noticable |
| jeffyjeff |
 Posted: 19:37 - 04 Apr 2023 Post subject: |
Yes, it was metallic yellow, Honda color code Y124P. The Color Rite paint came in rattle cans, and the kit contained all three components. I tried several different combinations of base coat and color coat, but that did not seem to have much of an effect. Ultimately, I found a used OE fairing in very good condition for less than the price of the Color Rite paint kit, and I fitted that.
Here is a link to a posting that I made at the time that has some detail and pictures, for anyone interested.
https://www.vfrdiscussion.com/index.php?/forums/topic/84905-rattle-can-paint-job-queston/ ____________________ History shows again and again how nature points out the folly of men - BOC |
| dave001 |
 dave001 Banned
| stinkwheel |
 Posted: 22:00 - 04 Apr 2023 Post subject: |
You straight-up can't colour match older Japanese motorcycle candy paint finishes, it's impossible. They are multi-coat finishes with various tints and metallics in them and unless you can replicate that with each coat at the correct thickness, it'll land up a slightly different colour, even if you use OEM paint. You can get close but you can't get it exact.
The original finish on my VFR was a 5 coat finish and I believe Kawasakis candy colours they used to do the Z-series had up to 12 coats (all different).
The only way to match it is to use pre-painted parts from the same run or respray the whole bike. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MCN |
 MCN Super Spammer
| Honda434 |
 Honda434 Borekit Bruiser
The last post was made 2 years, 296 days ago. Instead of replying here, would creating a new thread be more useful? |
