and now for something completely different...
to v or not to v
PostPosted: 19:08 - 06 Apr 2023    Post subject: and now for something completely different... Reply with quote
not bikes but watches.
my bronze cased Chinesium watch which im quite fond of has a problem.
one of the holes for the strap pin is either not quite wide enough or not quite deep enough.
after the pin popping out under pressure a few times, there is now a slight channel etched into the bronze. the pin wont stay seated for very long now.
is there an easy way to drill the hole out slightly?
https://i.imgur.com/ezDNVHW.jpg
Moto Guzzi V7.
PostPosted: 20:20 - 06 Apr 2023    Post subject: Reply with quote
Tiny drill bit in a pin vice? Might land up at a slight angle though.
MCN
PostPosted: 23:11 - 06 Apr 2023    Post subject: Reply with quote
It's at the wrong time too mate.
Islander
PostPosted: 23:50 - 06 Apr 2023    Post subject: Reply with quote
Before you go hacking the watch case around, buy a new spring bar - your local jeweller might have them or you can buy them on eBay or Amazon. They do lose tension and distort over time and a new one will probably put things right. Thumbs Up
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p3519243.m570.l1311&_nkw=watch+spring+bars&_sacat=0
https://www.amazon.co.uk/s?k=watch+spring+bars&crid=JLCJWR0BTV04&sprefix=watch+spring%2Caps%2C174&ref=nb_sb_ss_ts-doa-p_3_12
arry
PostPosted: 06:47 - 07 Apr 2023    Post subject: Reply with quote
I was just about to say, it's likely the spring bar that's the issue rather than the case - albeit that hole does look a bit like a Newcastle Lass being passed around a stag do in Benidorm.
Spring bars come in different thicknesses as well as widths. That's a Helmdallr isn't it? 20mm lug width? I might have some spare bars around here somewhere.
MCN
PostPosted: 12:49 - 07 Apr 2023    Post subject: Reply with quote
Two (2) new spring bars.
Both have been under the same type of 'weathering'.
Just sayin'.
And since you're into Watches.....
https://youtu.be/syPHe5by_YA
jeffyjeff
PostPosted: 17:01 - 07 Apr 2023    Post subject: Reply with quote
See if your dentist can drill it out a little. He is an expert at drilling out stuff with a macroscopic drill. Wink
PostPosted: 17:16 - 07 Apr 2023    Post subject: Reply with quote
Point of syntax. Macroscopic means really big. A macroscopic drill would be something like a jack-hammer.
to v or not to v
PostPosted: 18:02 - 07 Apr 2023    Post subject: Reply with quote
have tried new spring bars, including genuine Casio. watch is a SKX007 homage. they just ping off under any kind of pressure now Sad
watch is no longer wearable if i cant drill the hole out a bit.
Moto Guzzi V7.
MCN
PostPosted: 19:07 - 07 Apr 2023    Post subject: Reply with quote
Take it to local watchmaker. They will have tools to fix that.
It is not an uncommon problem.
jeffyjeff
PostPosted: 22:27 - 07 Apr 2023    Post subject: Reply with quote
No shit? Then why do I use the macro lense on my camera to take close-up photos of small subjects like flowers and stuff?
jeremyr62
PostPosted: 07:24 - 08 Apr 2023    Post subject: Reply with quote
Nope. It just means visible to the the naked eye.
MCN
PostPosted: 08:49 - 08 Apr 2023    Post subject: Reply with quote
Ehm.... coz u is ghey?
PostPosted: 09:22 - 08 Apr 2023    Post subject: Reply with quote
Macroscopic is literally the opposite of microscopic.
Macro lenses make things look big because they are very close, not necessarily because they are magnifying it. They can be wide angle or telephoto. Most of them are actually pretty wide angle.
The last post was made 2 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 85.08 Kb
