| CarlW12 |
 CarlW12 Two Stroke Sniffer
 Posted: 10:40 - 20 Apr 2023 Post subject: Ninja 250R chain adjustment |
Hi All,
Recently purchased a 2011 Ninja 250R which I’m loving at the moment. I’ve noticed my chain is slightly slack so wanted to have a go at adjusting it
However, after removing the pin, I can’t seem to loosen the axel nut. It seems as though it budged slightly but won’t seem to give. No idea if the previous owner has overtightened it slightly or not..
I used a torque wrench to check the toque was correct just in case, and then decided to leave it to ask for advice here first
Is there any specific tools that are best for loosening axle nuts I should look at? I was just attempting to use a spanner which I’m assuming might be wrong
Many thanks
Carl ____________________ Carl
A2 Licence Holder
Previous bikes: YBR; GPZ500S; Kawasaki Ninja 250R |
| Evil Hans |
 Evil Hans World Chat Champion
 Posted: 10:53 - 20 Apr 2023 Post subject: |
You might need a socket with a fairly long breaker bar, and just hold the other side with a spanner
https://youtu.be/PxZCoYq2j5w ____________________ Triumph Sprint ST 1050. And it's Red. |
| doggone |
 doggone World Chat Champion
| grr666 |
 grr666 Super Spammer
 Posted: 11:46 - 20 Apr 2023 Post subject: |
It is supposed to be slightly slack to allow for suspension movement. How slack are we talking? ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off.  |
| CarlW12 |
 Posted: 18:42 - 20 Apr 2023 Post subject: |
Thanks for your responses. I think that getting my own sockets etc will be best for the job by the looks of it then
The slack is only slightly over, nothing too crazy. I could leave it a little longer before adjusting which would give me time to get some tools etc together. I’m fairly new to bike mechanics so just learning the ropes with the manual at the moment - want to take good care of my bike and make sure she rides well!
Just hoping that the old owners haven’t tightened the nut too much that I’ll struggle to loosen it off.. fingers crossed ____________________ Carl
A2 Licence Holder
| Nobby the Bastard |
| CarlW12 |
 Posted: 19:27 - 20 Apr 2023 Post subject: |
Yep, was definitely trying to loosen it correctly  ____________________ Carl
A2 Licence Holder
| stinkwheel |
 Posted: 19:57 - 20 Apr 2023 Post subject: |
I'd be using a 1/2" drive breaker bar and socket or a big ring spanner. I think they'll be 24mm.
You can buy big ring spanners with 22 and 24mm on opposite ends which should be good for both the front and rear wheel nuts. I've seen me slide a bit of pipe over the end to get more leverage if required.
I'd go with a 6-sided socket or ring if you can.
EDIT: If you have a torque wrench, you must already have the socket so I'd be buying a breaker bar. Use the torque wrench to put the nut back on again, do not use it to undo the nut, that's not what they are for. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
| CarlW12 |
 Posted: 21:47 - 20 Apr 2023 Post subject: |
Ok, I’ll have a look around for a big 6 sided spanner or breaker bar then to use for the future. In hindsight, the spanner I was trying to use didn’t seem to have enough grip and was smaller in size… no wonder it wasn’t loosening  ____________________ Carl
A2 Licence Holder
| Bhud |
 Bhud World Chat Champion
| MCN |
 MCN Super Spammer
| redeem ouzzer |
 redeem ouzzer World Chat Champion
 Posted: 11:39 - 21 Apr 2023 Post subject: |
Ha ha ha at your age son I was rebuilding race bike engines in my shed, not messing around trying to adjust the chain on a 250.
Kids eh?  ____________________ Be a REAL MAN! |
| Easy-X |
 Easy-X Super Spammer
| CarlW12 |
| MCN |
 MCN Super Spammer
| CarlW12 |
 Posted: 23:37 - 21 Apr 2023 Post subject: |
I’m beginning to notice that  ____________________ Carl
A2 Licence Holder
| Robby |
 Robby Dirty Old Man
| MCN |
 MCN Super Spammer
 Posted: 18:33 - 22 Apr 2023 Post subject: |
I just tweeked the chain slack on my S1000RR. The axle bolt has flat's on the head on the RH end and the nut is on the LH side. There is a torque for the nut which seems low for the dimension of the axle/bolt (19-20mm) but OEM requires the nut to have medium strength Loctite Thread Lock applied to the thread before making it up. Then torque to 100nm.
I did it this way everytime I adjust the chain.
My point, the nut is always ridiculously Tight AF to loosen on the next adjustment adventure.
Maybe someone applied thread lo ck. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| MCN |
 MCN Super Spammer
 Posted: 19:39 - 23 Apr 2023 Post subject: |
No post exits.
The last post was made 2 years, 277 days ago. Instead of replying here, would creating a new thread be more useful? |
