Water spray out of tail pipe
KingKong
PostPosted: 09:31 - 30 Apr 2023    Post subject: Water spray out of tail pipe Reply with quote
Hello All.
Had a minor run in with a van that ended up putting my bike as a cat N. 4th Dimension took my bike in for assessment. I was offered a third party insurance payout and an offer to salvage my machine for £935. I declined the offer and took my bike back.
Yesterday it arrived in a far worse state than when they collected it after the crash.
Context
I rode the bike home after the collision. Slight vibration from the front. Got home switched it off. A few days later started the bike up and it was all fine.
Now, a few weeks in the possession of the claims company and the bike returns with serious water-logged system spraying water out the pipe on every twist of the throttle. See attached video.
Please can someone let me know what/how they think this is/could have happened?
Kwak 636 (2005)
Past - 2016 Ninja 300 (dark grey); K4 GSXR 600 (sexy yellow); 2002 CBR600FS; 2004 GSXR 1000; 2006 Kwak 636; 2005 Yamaha XVS 1100 Dragstar (facepalm); 2005 Kwak 636; 2011 Yamaha R125.
Nobby the Bastard
Harley Gaydar
PostPosted: 09:32 - 30 Apr 2023    Post subject: Reply with quote
Wow.
All I can think of is the water going in the end can. I really can't see that coming out of the engine and it still actually functioning.
Triumph Sprint ST 1050
MCN
PostPosted: 09:48 - 30 Apr 2023    Post subject: Reply with quote
How ,long did you run the engine for?
IC engines produce water continuously, as a by product of combustion.
Hydrogen and Oxygen when combined can make Dihydrogen Oxide.
You can see it in 'cold' exhaust gas as water vapour (Steam Rolling Eyes ).
KingKong
PostPosted: 09:52 - 30 Apr 2023    Post subject: Reply with quote
Nobby the Bastard wrote:
Wow.
Thanks. Then this leads to the question how did so much water end up in the exhaust if not done deliberately? And is there any harm to this?
Kwak 636 (2005)
Kawasaki Jimbo
Was it hauled away on the back of a low-loader on a very wet day perhaps, with lots of spray whirling about? Unfortunate air flow to get that much down the can and soak the packing though.
KingKong
PostPosted: 09:55 - 30 Apr 2023    Post subject: Reply with quote
The twist of throttle with water spray was within the first minute of ignition. I left the bike on for nearly ten minutes and water gushed out like this a further two times on twist of the throttle/revving the engine.
The bike was presumably sat in their storage for under 30 days.
Kwak 636 (2005)
KingKong
PostPosted: 09:57 - 30 Apr 2023    Post subject: Reply with quote
Was in an actual large size van designed to carry bikes securely.
Kwak 636 (2005)
MCN
PostPosted: 10:18 - 30 Apr 2023    Post subject: Reply with quote
10 mins is not sufficient time to warm up an engine.
Either let it sit for 30mins or take it for a blast.
If it is a water wooled engine it can only hold a certain amount of water.
So when the water stops spraying out the exhaust, either the coolant has been used up or the engine has warmed up and you cannot see the vapour. The water has become steam. (The invisible state Rolling Eyes ).
PostPosted: 10:32 - 30 Apr 2023    Post subject: Reply with quote
I'd probably undo the exhaust at the splitter and seperate one or more of the pipes to let any residual water out.
I also can't see that much water coming from the cooling system into the engine and it still be running so it's pretty much got to be water going up the exhaust.
I'd say as above, it was either on the back of a flatbed and got spray up in there or it got manky and someone's been at it with a pressure washer/hose.
If it's coolant, it'll taste sweet. Up to you if you decide you want to taste it. Wouldn't be stupid to check the coolant level anyway.
Definately water and not fuel?
KingKong
PostPosted: 10:37 - 30 Apr 2023    Post subject: Reply with quote
Will try MCN and Stinkwheel’s suggestions. It was copious amounts of water. Far too much tbh.
Kwak 636 (2005)
Nobby the Bastard
Harley Gaydar
PostPosted: 10:46 - 30 Apr 2023    Post subject: Reply with quote
It wouldn't matter if it was fuel or water, any liquid of that volume in a cylinder would hydrolock it.
KingKong
PostPosted: 11:52 - 30 Apr 2023    Post subject: Reply with quote
Looks like MCN was correct. I started it today and it was absolutely fine. Who knew? Gagged
Kwak 636 (2005)
that_impulse_guy
PostPosted: 13:05 - 30 Apr 2023    Post subject: Reply with quote
it starts and revs and idles. The video shows that.
ergo, not hydrolocked
it idles and revs well(? (sure sounds like it)) ergo not a faulty headgasket (not for THAT amount of spray...that will stop combustion 100%
so you got water inside your exhaust sitting about that somehow got inside from the only hole thats exposed at the back. Maybe someone was a knob, maybe it was "weather".
Take pipe off and go to town emptying it out, or...just check coolant level to make 100% happy happy sure, and Go ride it..it'll come out (the bulk, via revs)/ the rest will evaporate from heat.
Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R
MCN
PostPosted: 13:11 - 30 Apr 2023    Post subject: Reply with quote
As soon as an engine fires up, within seconds it would blast any water that had managed to find it's way into the exhaust.
And it would probably make a big sooty splosh.
dave001 This post is not being displayed because the poster is banned. Unhide this post / all posts.
MCN
PostPosted: 18:35 - 30 Apr 2023    Post subject: Reply with quote
https://youtu.be/3hKI3nW5LMA
KingKong
PostPosted: 19:30 - 30 Apr 2023    Post subject: Reply with quote
Thankfully that’s what happened. Was bamboozled as first time in 12 years of owning over 7 bikes.
Kwak 636 (2005)
KingKong
PostPosted: 20:37 - 30 Apr 2023    Post subject: Reply with quote
Kwak 636 (2005)
PostPosted: 20:44 - 30 Apr 2023    Post subject: Reply with quote
I have also seen a similar effect when someones "mate" at a rally spent the whole weekend pissing into their high level end can.
The best bit about that was the bikes owner had noticed and on the sunday morning he slowly and quietly unzipped said "mates" tent zip, reversed the bike into the opening, then fired it up and started bouncing it of the rev limiter.
Oh how we laughed,..
KingKong
PostPosted: 21:19 - 30 Apr 2023    Post subject: Reply with quote
dave001 wrote:
only thing i can think of if they stored pipe out side in a rain storm pointing up or washed it and shot the presure washer strait up the pipe
like a retard
even if was on a low load or bike was stord out side i cant see that much water getting in the tail pipe
Precisely.
Clearly bike was in bad custody when out of my hands.
Kwak 636 (2005)
xX-Alex-Xx
PostPosted: 10:56 - 02 May 2023    Post subject: Reply with quote
Do you have a drain hole on the exhaust midpipe? Usually just a pinhole but it's easy to get blocked. My 929 used to spit water and vapour on cold/wet mornings until I cleaned it out.
DILLIGAF
The last post was made 2 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 116.62 Kb
