| samu_fa |
 samu_fa L Plate Warrior
| stinkwheel |
 Posted: 19:28 - 07 May 2023 Post subject: |
Might just need to be primed. Fuel wont run out of the tap without a vacuum being applied to the tap. No amount of sitting and waiting will make fuel run into the carbs.
So one thing you could try is opening the drain screws on the carbs that aren't getting fuel and either turning the engine over until fuel starts flowing or applying suction to the vacuum hose on the fuel tap.
It should self prime if you turn it over for long enough. Choke fully on and do not touch the throttle at all as you are trying to start it. With Mrs stinkwheels CBR600 (same motor as yours but more highly tuned) I usually turn the engine over in 10 second bursts followed by a 30 second rest. It can take 3 or 4 cycles of this to fire after a carb rebuild, then it usually picks up on one cyclinder first and the other three follow in the next 30 seconds. If you touch the throttle before it's firing on all 4, it will conk out. That's a bike with a fuel pump too, yours is gravity fed.
Moral of the story, if it's running fine, you don't need to clean the carburettors... ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| A100man |
 A100man World Chat Champion
 Posted: 18:47 - 08 May 2023 Post subject: |
Are you sure you put them back together correctly? I'm thinking about floats upside down for example. ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion |
| jeffyjeff |
 jeffyjeff World Chat Champion
| A100man |
 Posted: 21:27 - 09 May 2023 Post subject: |
| jeffyjeff wrote: | Could you even do that? I'm thinking the floats won't fit if you try to invert them on installation. If the bike indeed has a vacuum operated fuel tap, it probably just needs a little help to fill the carb float bowls. |
In some cases I think you can.. making the tang all wrong. Or did I dream it?  ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
The last post was made 3 years, 53 days ago. Instead of replying here, would creating a new thread be more useful? |
