Suzuki gn 125 exhaust over heating but engine is cold
Gnman123
PostPosted: 11:43 - 08 May 2023    Post subject: Suzuki gn 125 exhaust over heating but engine is cold Reply with quote
Hi hope some one can help me I’ve got a Suzuki gn 125 when started it runs ruff and the exhaust gets red hot within about a minute and back fires the engine remains cool I’ve checked the timing and that’s bang on any help will be much appreciated
Nobby the Bastard
Harley Gaydar
PostPosted: 11:46 - 08 May 2023    Post subject: Reply with quote
Has it been like that the whole time you've had it? If not, what have you messed around with?
Triumph Sprint ST 1050
Gnman123
PostPosted: 11:58 - 08 May 2023    Post subject: Reply with quote
No it’s not long started only things I’ve changed are the carb and had the wiring redone at a garage but run fine after both things had been done
PostPosted: 12:04 - 08 May 2023    Post subject: Reply with quote
Sounds like thats the problem. Why did you replace all of this?
Gnman123
PostPosted: 12:08 - 08 May 2023    Post subject: Reply with quote
I replaced the carb because the float and seals had completely gone and was cheaper to buy new one the repair and the wiring was completely gone had a new wiring harness put on
PostPosted: 12:11 - 08 May 2023    Post subject: Reply with quote
Have you ever had it running normally?
This carb. Is it exactly the same as the old one? Or have you bought a chinese ebay special and bolted it on? Did you check the jetting and choke diameter is exactly the same as the original?
Have a look at the sparkplug electrode and see how cooked it is. Post pics if you can.
Gnman123
PostPosted: 12:16 - 08 May 2023    Post subject: Reply with quote
It’ was running perfect till about a week ago had the carb on for about 4 weeks now that looks all good inside and it’s a genuine Suzuki carb it’s exactly the same as the old one spark plug is black but doesn’t look to bad can get pics later
Nobby the Bastard
Harley Gaydar
PostPosted: 12:38 - 08 May 2023    Post subject: Reply with quote
If you changed the carb and within a few weeks it's massively over fueling (black spark plug) your problem is related to the carb.
PostPosted: 12:39 - 08 May 2023    Post subject: Reply with quote
That being the case, might be worth checking the tappets to make sure the exhaust side hasn't closed up.
Did you actually check the jetting and needle position was correct before fitting the new carb.? A new carb doesn't always come with the correct jets fitted.
WD Forte
PostPosted: 15:42 - 08 May 2023    Post subject: Reply with quote
Checking the plug should be the first thing to do
just whip it out and see what colour it is to get some clues
If its black and sooty its over fuelling
but I suspect it may be white/greyish/glazed and running too lean
why may be due to wrong jetting, setting or valve clearances,
a cheap aftermarket chinese carb or inlet leak
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 15:52 - 08 May 2023    Post subject: Reply with quote
WD Forte
PostPosted: 16:20 - 08 May 2023    Post subject: Reply with quote
You dont expect me to read all this shit do you?
aint nobody got time for that
bikers smell of wee
bikenut
PostPosted: 09:17 - 09 May 2023    Post subject: T Reply with quote
Recheck ignition advance to rule that out.....
Feedback when done.
nuts about bikes
A100man
PostPosted: 12:22 - 09 May 2023    Post subject: Reply with quote
Please post a pic of the 'red hot' exhaust Shocked
jeffyjeff
PostPosted: 16:52 - 09 May 2023    Post subject: Reply with quote
Glows in the dark, dude. Sometimes spits fire! Not normal for a 125 in stock state of tune. For example, I've never seen the header glow red on me YBR, but then again, I rarely ride at night. It's running really good right now, maybe I should check it out. Cool
https://live.staticflickr.com/65535/52884293475_c6449bbb9d.jpg
WD Forte
PostPosted: 16:42 - 10 May 2023    Post subject: Re: T Reply with quote
Feedback when done.
I think its got a fixed pulser so no timing adjustment is possible
Mind you...
I do see a sensor in the parts fiche for a 2000 model which
may act as a tps and if read by the ignition control unit may give some advance when the throttle is opened
bikers smell of wee
The last post was made 3 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.53 - MySQL Queries: 15 - Page Size: 86.17 Kb
