Electrical fault? Help!!
MikeyC
PostPosted: 10:29 - 12 Apr 2005    Post subject: Electrical fault? Help!! Reply with quote
Was riding on the motorway last night, had a quick glance down at my dials... was doing around 80 Wink (honest officer!), but then as I looked down, the needles on both the rev counter and speedo just dropped, but the power wasnt affected? I f**king sh*t myself at the time though!
Since then, when I rode it again last night and even this morning, the needles are fluctuating.. one minute working fine, the next minute not working.... but at the same time the needles move, the headlight flickers on and off? So now not only are my needles playing up, as far as other road users are concerned, i'm flashing them! lol!
The bike has just had a big service, new battery is in place, so I might take it back to the garage that did the work, see if they can sort this out. Hopefully its a 2 minute job and easy to fix, but anyone any ideas as to what is causing this? Thanks!
R4nger
PostPosted: 10:37 - 12 Apr 2005    Post subject: Reply with quote
Most probably a lose connector somewhere in the front of the bike.
sychosis
PostPosted: 10:47 - 12 Apr 2005    Post subject: Reply with quote
What age is your bike? I had a similar problem on mine, kept losing the speedo, when I twisted the accelerator. Found it was the speedo sensor that was the problem, replaced it not had a problem since.
Bikes owned: Aprilia RS 125 GP1 2003 (Now sold), Suzuki GSX-r600 1997 (streetfightered), https://www.bikepics.com/members/sychosis/
psy?cho?sis (si-ko-sis),n. pl. psy?cho?ses (-sez) ,A severe mental disorder, with or without organic damage, characterized by derangement of personality and loss of contact with reality and causing deterioration of normal social functioning.
Scotsman37
PostPosted: 10:55 - 12 Apr 2005    Post subject: Reply with quote
Yes, I would remove the fuel tank and look underneath there because you'll no doubt find the wiring looms connection blocks to the front of the bike which probably haven't been cleaned out with WD40 since day one. So disconnect/reconnect them and spray the connections thoroughly with WD40 even where the wires go into the back of the connection block too to remove the possibility oil or build of crap from the road that has no doubt built up in them.
MikeyC
PostPosted: 10:57 - 12 Apr 2005    Post subject: Reply with quote
Ok, will give this a bash! This wouldnt have been triggered off by the garage when they stripped and serviced the bike though would it?
Barry_M2
PostPosted: 10:59 - 12 Apr 2005    Post subject: Reply with quote
Mike, could just be a dodgy earth, check the neg terminal on the battery is tight.
Scotsman37
PostPosted: 11:00 - 12 Apr 2005    Post subject: Reply with quote
They may have not realised that one of the wires in the connection block may have been pushed out a bit and so you're getting intermitent connection of power to your bike's guages.
MikeyC
PostPosted: 11:02 - 12 Apr 2005    Post subject: Reply with quote
Admittedly this crossed my mind, bearing in mind its a new battery...
sychosis
PostPosted: 11:41 - 12 Apr 2005    Post subject: Reply with quote
Don't know what model you have, but on mine speed sensor sender is located here (ringed)
MikeyC
PostPosted: 12:04 - 12 Apr 2005    Post subject: Reply with quote
Mines the 1999 'SRAD' model, no idea where the sensor is!
sychosis
PostPosted: 12:14 - 12 Apr 2005    Post subject: Reply with quote
It's the same then, have a look later or when you get chance, it's a small type block sticking out near the top of the clutch housing!
If you take the left hand faring off, you should find all the connector blocks.
The last post was made 21 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 68.57 Kb
