Thunderace fork rebuild
to v or not to v
PostPosted: 20:14 - 11 Jun 2023    Post subject: Thunderace fork rebuild Reply with quote
one of the oil seals has a slight leak so i thought if i replace them id just as well do the springs, one of which had reached its service limit last time i checked.
YSS and Hagon springs are what i found when searching. is one better than the other? similar in price.
also am i likely to need new bushes, if so, is it worth forking out for genuine Yamaha or will generic bushes which are near half the price be ok?
Moto Guzzi V7.
PostPosted: 21:58 - 11 Jun 2023    Post subject: Reply with quote
My experience is OEM bushes and seals or do it again in 12 months.
Again my experience is that getting the correct weight linear spring for your weight and riding style is better than a progressive or straight OEM replacement. To the extent you suddenly notice how badly your brakes and rear shock are set up.
So plug your details into the racetec spring calculator and it'll tell you what strength spring to use, what spacer and what fluid and air gap. Do that, set the sag and be amazed.
https://racetech.com/ProductSearch/12/Yamaha/YZF1000/1997
I fitted K-techs to my VFR last time, they are fine.
to v or not to v
PostPosted: 23:13 - 11 Jun 2023    Post subject: Reply with quote
looked at recommended YSS spring specs and the length is 282mm
stock spring is 297mm for the 96 year model (mine) and 287mm for 97 on.
is that correct and will it be just a straight swap?
Moto Guzzi V7.
PostPosted: 23:50 - 11 Jun 2023    Post subject: Reply with quote
CMSNL lists all years of thunderace as having the same part number.
to v or not to v
PostPosted: 14:19 - 12 Jun 2023    Post subject: Reply with quote
will a spring thats 15/5mm shorter than stock work as intended?
Moto Guzzi V7.
PostPosted: 18:40 - 12 Jun 2023    Post subject: Reply with quote
If it's the correct spring rate, then yes, providing you set the sag which you should do anyway. You may need a longer spacer if the preload adjuster can't be adjusted far enough. Blue alkethene water pipe makes acceptable spacers.
The last post was made 3 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 48.99 Kb
