What do you think of this?
Bhud
PostPosted: 20:02 - 12 Jun 2023    Post subject: What do you think of this? Reply with quote
Not too bad, eh? Spot of JB Weld and it'll be fine...
https://i.ibb.co/z61tp2T/damaged-piston.jpg
Islander
PostPosted: 20:31 - 12 Jun 2023    Post subject: Reply with quote
That'll buff out. Thumbs Up
PostPosted: 20:36 - 12 Jun 2023    Post subject: Reply with quote
I've ridden on worse but yeah, probably needs some work.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:47 - 12 Jun 2023    Post subject: Reply with quote
Can't see what the issue is.
What is the red arrow supposed to be pointing to?
Triumph Sprint ST 1050
Bhud
PostPosted: 22:13 - 12 Jun 2023    Post subject: Reply with quote
That's a QC pass mark. Only the finest pistons get that.
WD Forte
PostPosted: 22:54 - 12 Jun 2023    Post subject: Reply with quote
https://imgur.com/ghrBBJ1.jpg
bikers smell of wee
PostPosted: 23:38 - 12 Jun 2023    Post subject: Reply with quote
Pretty
Triumph Trophy Launch Edition
dave001 This post is not being displayed because the poster is banned. Unhide this post / all posts.
MCN
PostPosted: 05:17 - 13 Jun 2023    Post subject: Reply with quote
Araldite is much more superior to JB Weld (which is outdated shite)
But Belzona is vastly superior to both.
I'd go with Belzona 1111 for that repair.
Advantages:
Simple to mix.
Machinable.
Resistant to most chemicals and moderate temperatures.
Well done on catching that before it developed into something more serious.
WD Forte
PostPosted: 11:15 - 13 Jun 2023    Post subject: Reply with quote
You got that the wrong way around IMO
Araldite is fucking useless stuff compared to JB weld in my experience
of trying both.
Not familiar with Belzona, but had a shufty at the data sheet
and it looks interesting
bikers smell of wee
Bhud
PostPosted: 11:34 - 13 Jun 2023    Post subject: Reply with quote
Interesting! I think if I go all around it with Araldite, I won't need to get piston rings. That's an upgrade. I'll have to be very careful though and put on my best cake-making hat.
PostPosted: 12:33 - 13 Jun 2023    Post subject: Reply with quote
of trying both.
Belzona is the dogs bollocks for chemical metal. The bronze was wonderful. We used to buy it by the kilogramme for the older ships for pump impeller rebuilding. Laughing Pricey but good. Thumbs Up
Fullers1845
PostPosted: 12:51 - 13 Jun 2023    Post subject: Reply with quote
+1 for Belzona, used to use it in my previous job for repairs to ally machine casings. Eye-watering cost (and fumes when you mix it) but amazingly strong.
MCN
PostPosted: 14:26 - 13 Jun 2023    Post subject: Reply with quote
Araldite Powerbands are a thing.
that_impulse_guy
PostPosted: 21:38 - 13 Jun 2023    Post subject: Reply with quote
can you just put an ohlins sticker over the bad bit?
Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R
skatefreak
PostPosted: 22:56 - 28 Jun 2023    Post subject: Reply with quote
I'll raise you a valve Very Happy
PostPosted: 07:35 - 29 Jun 2023    Post subject: Reply with quote
of trying both.
Pound-shop Araldite might be, but they make many great products. I have a tube of Araldite 3013 and it's fantastic stuff. Takes a day or two to cure mind.
PostPosted: 07:54 - 29 Jun 2023    Post subject: Reply with quote
I like west systems epoxies, thickened with various additives depending on application.
A100man
PostPosted: 12:02 - 29 Jun 2023    Post subject: Reply with quote
I don't know how to break this too you, but that head may not be salvageable..
.. Chinese?
that_impulse_guy
PostPosted: 12:20 - 29 Jun 2023    Post subject: Reply with quote
I think the F401 is the genuine item on the engine case.
chinese one start with K157FM or QJ157 etc.
(k - manufacturer)
(1 - single cylnider)
(57 = bore)
(suffix = designation/cooling/havent figured it out yet)
skatefreak
PostPosted: 07:50 - 30 Jun 2023    Post subject: Reply with quote
We'll see about that...
https://www.jk-forum.com/wp-content/uploads/2017/05/JBWeld_Cylinder_head.jpg
A100man
PostPosted: 11:36 - 30 Jun 2023    Post subject: Reply with quote
you can't kid me - that's a different head Wink
jeffyjeff
PostPosted: 19:01 - 02 Jul 2023    Post subject: Reply with quote
to my untrained eye, I would guess that a piece of the piston ring broke off, perhaps due to insufficient end gap, and began working against the ring groove until the groove started to hog out. Likely to be corresponding damage to the cylinder bore to match.
Bhud
PostPosted: 00:53 - 05 Jul 2023    Post subject: Reply with quote
The piston seized in the bore and a bit of piston ring squished itself into one side of the piston, leaving the other side sticking out. The other cylinder was fine though, and spun the crank right through its revolutions, breaking the seized piston. That's what I think happened, because there's still a piece of ring lodged in the damaged piston, which is too tight to remove.
The problem is that we're end-users and not trained eyes. Then again, Kawasaki had no idea we'd still be using them 40 years on...
I'm only fixing this to show it didn't defeat me and I didn't quit on it because of laziness or gross ineptitude. Like you and everyone else here, I try to do everything as competently as possible when it comes to bikes. I follow the manuals and try to educate myself using Youtube, this forum and other forums, and by direct consultation with experts, engineers and experienced people. I didn't fit these pistons and rings originally. I simply assumed they were good. I put a good few thousand miles on them. It's possible whoever put them on didn't gap the rings properly. I have to also consider the possibility of a lean condition as some point contributing to overheating and seizure.
Ultimately, bikes are meant for riding, not fixing, and from talking to people who are well into vintage bikes, there seems to be a kind of kudos or pride in fixing them. There are also Youtube channels where people do deep analysis to the damage on piston skirts, etc. And lots of people who replace the seals on their favourite bike engines every year. I'm not really into that, tbh. I just like riding them. This is a properly defunct and obsolete technology. I get how they work, but they aren't that special to me because they all do the same thing at the end of the day. It's been a good run - lovely sounds and experiences. But from here on in, this is it for me. New bikes ONLY. I am so done. Laughing
xX-Alex-Xx
PostPosted: 14:35 - 05 Jul 2023    Post subject: Reply with quote
Depends on your POV. I have family members who will spend pretty much all weekend, every weekend, restoring vintage bikes. They ride maybe 50 miles a year total. It's the engineering challenges of restoring stuff from a box of mixed parts back into a bike that's potentially best part of a century old and doing some fab work etc along the way that they enjoy.
DILLIGAF
The last post was made 2 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 128.2 Kb
