| Downunder Wonder |
 Downunder Wonder L Plate Warrior
 Posted: 14:20 - 03 Jul 2023 Post subject: 1982 CB900F Rear Wheel Bearing Removal? |
How do I get the rear wheel bearings out? I"ve tried the Clymers manual technique of tapping them out. Doesn't work. Not even a fraction of a millimeter  |
| stinkwheel |
 Posted: 14:42 - 03 Jul 2023 Post subject: |
Make sure there aren't any circlips left in.
Then tapping out is the correct way, it might just be in there tight. You could try heating up the alloy of the hub with a heat gun which should make things looser. Obviously there's only so hot you can make it without damaging paint.
I have heard of people putting an expanding rowl bolt in the centre of the bearing and driving it out using the bolt, never tried it though.
Or you could use a slide hammer type bearing puller tool.
Probably just need a sharper punch and a bigger hammer. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
| Robby |
 Robby Dirty Old Man
| MCN |
 MCN Super Spammer
 Posted: 17:59 - 03 Jul 2023 Post subject: |
I replaced the rear bearing in my BMW. The OEM recommended method to remove the bearing is by using a bearing puller and a heat gun.
The hub can take a fantastic amount of heat.
No paint damage. But I think powder coating can handle more heat.
The trick is to get the heat onto the hub without too much getting conducted into the bearings.
It wasn't the most simplest of jobs. The bearing puller I used is a Ching-Chong Specialist tool. And just slipped out of the bearings.
Real bearing pullers are.made of better steel.
Not melted down watch cases and old pots pans and bicycles. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| sickpup |
 sickpup Old Timer
| blurredman |
 blurredman World Chat Champion
 Posted: 08:51 - 04 Jul 2023 Post subject: |
| Robby wrote: |
The wheel can corrode around them, making a tight fit into an even tighter fit. It is also hard to get purchase at first because the sleeve stops you getting a good hit on the bearing. |
Very annoying. Having to disasemble the bearing in place to be able to remove the spacer. Just have to calculate you get the right side of the wheel otherwise you'd never get the outter race out. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 52k. |
| Easy-X |
 Easy-X Super Spammer
| Nobby the Bastard |
| stinkwheel |
| stinkwheel |
| MCN |
 MCN Super Spammer
 Posted: 04:45 - 05 Jul 2023 Post subject: |
Bearing manufacturers will lose their s4it if they see you hammering a bearing in.
The material is not designed to be hammered.
Freezing the bearing, heating the housing, pressing in the bearing or clamping the bearing are acceptable methods.
It's important or they wouldn't harp on about it.
https://youtu.be/lm-OgrRd3vM
This goes on a bit but covers most points.
Mostly, bad bearing selection. Wrong loading wrong speed rating. Cheap shite.
Bad installation. Shock/point loading (hammering in)
Wrong lubrication. Wrong lube, not enough/too much lube.
Contamination during assembly or in service.
Sealed bearings are recommended for wheel bearing where service access is impossible without disassembly.
I always fit double sealed bearing in wheels. Same bearing model can be double/single or unsealed.
Single seal relies on the inner face not being exposed to external elements. More or less fail-safe in a wheel but not 100%
Double sealed eliminates that issue for not much more £ for a wheel bearing. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| stinkwheel |
| MCN |
 MCN Super Spammer
 Posted: 10:21 - 05 Jul 2023 Post subject: |
https://www.skf.com/uk/news-and-events/news/2023/2023-may-31-skf-consolidates-manufacturing-in-europe-proposes-to-close-factory-in-luton-4552163
This thread reminds me of another shower of khunts I need to add to my Blacklist of khunts who shat on British workers.
HP shut down production in the original factory and moved it all to netherlands.
Irn-Bru took the shoogir oot the irn-bru and put sweetener in. After a long battle with the eu to keep sunset yello in their secret and ancient irn-bru recipe.
(They're in bed with the Special Needs Party of Scotland.)
McVites. The Turks who we fought again their machine guns, in Feb. 1915, bought the brand and the biscuit factory in Glasgow. Moved all production to Turkey and shut the factory in Glasgow.
Sky TV Rupert Murdoch.
There are more I can't think of just now. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
The last post was made 2 years, 354 days ago. Instead of replying here, would creating a new thread be more useful? |
