| MG#43 |
 MG#43 Nova Slayer
 Posted: 14:38 - 07 Jul 2023 Post subject: High beam voltage ?? |
Hi all,
I've got an issue with my high beam. When the switch is turned on I get 11.60 volts from the connector 0 when off. This is the same as the low beam which works fine. I've tried the same bulb in the high beam and yet nothing. Is there more to this than meets the eye? Should they be higher or one higher than the other?
I've even swapped out the headlight loom on the assumption it was a gear indicator that had been spliced into the wiring, it does the same even with a standard untampered one. I've never had a need to measure voltages for bulbs in the past so don't have a good grounding (see what i did there! ) in this area...
thanks for your thoughts!  |
| A100man |
 A100man World Chat Champion
 Posted: 14:48 - 07 Jul 2023 Post subject: Re: High beam voltage ?? |
| MG#43 wrote: | Hi all,
Perhaps I'm being dim (see what I did there) but I don't really understand what you are saying (underlined) ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
| that_impulse_guy |
 that_impulse_guy Scooby Slapper
 Posted: 14:48 - 07 Jul 2023 Post subject: |
its same voltage for high and low beam.
more interested to know what problem you are trying to find and solve by doing this... ____________________ Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R |
| MG#43 |
 MG#43 Nova Slayer
| that_impulse_guy |
 Posted: 15:06 - 07 Jul 2023 Post subject: |
ok, i re-read what you wrote...so you've got two separate bulbs. low beam bulb doesnt work in high beam socket although does work in low beam socket etc.
comment1: 11.6 is a bit low...is that with bike off?
comment2: you mentioned "measured at the connector"...is that a block going to main beam, or actually sticking the probes into main beam socket? and if into socket, check what happens when you put a bulb into socket, maybe theres something physical going on shorting stuff out...if you measured 11.6v at the connector block, then also check if you have 11.6v at the socket end. ____________________ Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
| Nobby the Bastard |
| WD Forte |
 WD Forte World Chat Champion
| Polarbear |
 Polarbear Super Spammer
| Kawasaki Jimbo |
| MG#43 |
 MG#43 Nova Slayer
 Posted: 21:32 - 07 Jul 2023 Post subject: |
what I'm struggling to understand is this. Turn ignition on, connector 1: has 11.6v and bulb illumination. Connector 2 is activated by a switch, when in the off position 0 volts, when activated it also has 11.6v. Using the same bulb the is no illumination. Things we know this is a high beam v low beam. Going back to my original question what is the difference in terms of voltage, how does it know to use the high beam or low beam elements when/if both connectors have 11.6v.
so, perhaps??? 11.6v is std for low beam. If the high beam loom connection also connection has 11.6v this will not power the bulb in the same was as the low beam did, nor is it enough to power the high beam.
the only thing that makes sense right now is that all 4 of my h4 bulbs' high beam elements are shot, and that the loom/ecu knows not to power the bulb with only 11.6v in the same way as it would/does with the low beam.... because..... it wants.....????? what? 12.5v ?
You put a 12v bulb in a connector with 11.6v seemingly this is good news, but in one that's 'high beam' its not good enough?
I'll buy another new bulb tomorrow to test.... Thanks for your comments to date!!  |
| Nobby the Bastard |
| Kawasaki Jimbo |
| Nobby the Bastard |
| Kawasaki Jimbo |
| Nobby the Bastard |
| MG#43 |
 MG#43 Nova Slayer
| Islander |
 Islander World Chat Champion
| Nobby the Bastard |
| MG#43 |
 MG#43 Nova Slayer
| Nobby the Bastard |
| Kawasaki Jimbo |
| Kawasaki Jimbo |
| MG#43 |
 MG#43 Nova Slayer
| to v or not to v |
 to v or not to v World Chat Champion
| MG#43 |
 MG#43 Nova Slayer
 Posted: 11:03 - 08 Jul 2023 Post subject: |
Morning!
So, an update....
New bulb, no better.... but, I have learned that once I place the bulb in the connector the now 12v (I charged the battery over night) is gone/lost. Take it out and it's back to 12v.... So the bulb is shorting out the circuit. So what should i check next knowing its the same on x2 headlight looms and everything else on the bike is working....? A continuity check on the earth would surely be ok otherwise I wouldn't have power to the connector? I mean if I had a breakage why do i have 12v at the connector when the switch is on?
I tried redirecting the earth to another part of the bike, this was not a success but would have been a moment of true genius to go against previous remarks of my competence if it was!!  |
The last post was made 2 years, 361 days ago. Instead of replying here, would creating a new thread be more useful? |
