Vacuum gauge blunder
A100man
PostPosted: 14:45 - 07 Jul 2023    Post subject: Vacuum gauge blunder Reply with quote
Lent out (or lost) my previous 4 gauge set..
bought a cheap replacement set that looks ok.. BUT
the set came without the critical damper valves (white in pic)
https://m.media-amazon.com/images/I/51i++Uho-KL.jpg
Have complained to seller but in case of no result any idea where I could buy some?
Fat Angry Scotsman
PostPosted: 15:38 - 07 Jul 2023    Post subject: Reply with quote
https://www.demon-tweeks.com/bike-it-economy-vacuum-gauges-241350/?sku=BIKVGA6&istCompanyId=a2904180-3a7d-4e56-b876-cf81c9512180&istFeedId=6fbc4b04-fd28-4ce1-8513-835c8f118690&istItemId=wptiraalr&istBid=t&gclid=Cj0KCQjw756lBhDMARIsAEI0Agl6bzeno6DDlxt_-YPhwVF0_zJGvqxCXzNn43zEa1TERs_vdEUUheQaAhJnEALw_wcB&gclsrc=aw.ds
£8.33
PostPosted: 19:00 - 07 Jul 2023    Post subject: Reply with quote
You can kink over the hoses in a loop of a cable tie. Tighten the kink until sufficient damping is achieved.
to v or not to v
PostPosted: 19:20 - 07 Jul 2023    Post subject: Reply with quote
i bought a cheap set of these type gauges. found them too inaccurate so got mercury ones instead for much more expense Neutral
you can have mine if you like?
Moto Guzzi V7.
PostPosted: 19:26 - 07 Jul 2023    Post subject: Reply with quote
Those gauges are "OK" if you accept them for what they are - cheap and cheerful.
The feedback shows that a common complaint is the needles not being zeroed equally. This is easily remedied - just pop the front cover off and use a flat screwdriver on the one screw to adjust the needle to zero.
I checked my set by putting tee pieces between the gauges and applying the same vacuum to each of them, and they were actually very close.
sickpup
Old Timer
PostPosted: 19:08 - 13 Jul 2023    Post subject: Re: Vacuum gauge blunder Reply with quote
Fish tank airline taps do the same job. Clicky.
A100man
PostPosted: 11:20 - 14 Jul 2023    Post subject: Re: Vacuum gauge blunder Reply with quote
Nice one thanks.. As it turns out the seller came up trumps and delivered a complete new set.. but these can/could go wit the old one
Islander
PostPosted: 12:24 - 14 Jul 2023    Post subject: Reply with quote
This.
The last post was made 2 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.72 - MySQL Queries: 13 - Page Size: 58.82 Kb
