| adam277 |
 adam277 Spanner Monkey
 Posted: 17:45 - 13 Jul 2023 Post subject: rusty bits removal |
I'm curious, would wd-40 and a tooth brush remove the rust from rusty bolts and other areas on a bit with surface rust on them? i.e as in the picture.
https://i.imgur.com/Vq4WFqz.jpg ____________________ Bikes: Previous Bikes: Piaggio x8 125: 2012/2013, YBR 125: 2013/2013 BMW R1150GS 2013/2017, Honda CBR600RR 2017/2017, Honda CB500 2018/2018, Suzuiki Address 110cc 2019/2020, BMW R1200GS 2021-2023
Current Bike: Honda CBF 125: current |
| Nobby the Bastard |
| adam277 |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| Nobby the Bastard |
| stinkwheel |
 Posted: 18:26 - 13 Jul 2023 Post subject: |
If you remove the rust you'll be left with bare steel which will almost immediately rust up again. They were probably zinc plated or passivated originally but that thin coating is now gone.
You'd need to take the fittings off and either replace them or remove the rust and treat them with something to protect them from rusting again. This would usually be either black phosphate coating or zinc plating.
Or just leave it because replacing them would be very expensive as some of the fittings will be oddball sizes meaning you have to buy OEM ones. Re-plating fittings is stupidly time consuming.
You could swap some out for stainless but it's not appropriate for every fitting, either due to the materials they are going into or the mechanical properties of the fittings. So if you don't know which applications these are, probably best not to. For example, I wouldn't use stainless on either brake rotors or calliper bolts unless it was a very specific grade of stainless. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MCN |
 MCN Super Spammer
 Posted: 19:26 - 13 Jul 2023 Post subject: |
Phosphoric Acid transforms iron oxide (rust) into iron phosphate. That can be brushed off.
And leaves a bare surface ready to be oxidised again.
Strong (less diluted) vinegar works too.
Acids are corrosive so they need to be neutralised after using.
The bastirts add phosphoric acid to Cola as a 'brightener' Flavour/texture enhancer.
Since the took the Coca leaf extract out of Cola its never been the same.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| stinkwheel |
| MCN |
 MCN Super Spammer
| adam277 |
| stinkwheel |
| stinkwheel |
 Posted: 20:47 - 13 Jul 2023 Post subject: |
| MCN wrote: |
Not it doesn't.
Phosphoric acid reacts more strongly with the iron than the oxygen and deposits a thin layer of strongly adhered black iron phosphate under the rust. The majority of the rust then falls off, leaving the surface coated in black iron phosphate which does not come off very easily. This is effectively how they apply the black coating to nuts and bolts (dip them in hot, conc phosphoric acid)
Aceatic acid (white vinegar) and muriatic acid (hydrochloric acid/spirit of salts/harpic X10 toilet cleaner) react with the iron below the rust to forn a layer of iron acetate or iron chloride. These are soluable in water and so loosen off the rust allowing it to be easily removed by brushing or running under a tap leaving bare metal which almost immediately flash rusts again unless you rinse in a neutralising solution and apply WD40 prior to drying/degreasing properly and applying your chosen coating.
"electrolysis" does a similar thing to muriatic acid by causing a layer of complex soluable iron III salts to form at the point of oxidisation instead of rust, thereby loosening the rust off. |
Phosphoric Acid transforms iron oxide into iron phosphate.
"Some rust converters may contain additional acids to speed up the chemical reaction by lowering the pH of the solution. A common example is phosphoric acid, which additionally converts some iron oxide into an inert layer of ferric phosphate. Most of the rust converters contain special additives. They support the rust transformation and improve the wetting of the surface." Wikipedia
"Phosphate conversion coating is a chemical treatment applied to steel parts that creates a thin adhering layer of iron, zinc, or manganese phosphates, to achieve corrosion resistance, lubrication, or as a foundation for subsequent coatings or painting." Wikipedia[/quote]
It might do somewhat but probably not to a massive degree, iron 2 oxide is a very stable molecule which doesn't give up its electrons easily. Also turning the iron oxide into iron phosphate wont achieve anything useful in terms of preventing further corrosion or removing the existing corrosion, it'll be just as stuck or loose as it was before. At best it'll stabilise the surface of the rust but mostly it'll just change its colour. You want the iron phosphate on the surface of the metal where it will not come off easily. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
| MCN |
 MCN Super Spammer
| MCN |
 MCN Super Spammer
 Posted: 21:30 - 13 Jul 2023 Post subject: |
https://youtu.be/6-MC_ZEXQbw
Rust Eating compounds tested. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Ayrton |
 Ayrton World Chat Champion
| adam277 |
| A100man |
 A100man World Chat Champion
 Posted: 11:09 - 14 Jul 2023 Post subject: |
| adam277 wrote: | Fair enough wire wool and wd40 good?
I mean, I am just trying to sell a bike. So I mean if it rusts again a few months later that is not my problem. |
To treat in situ I'd use one of those small toothbrush sized wire brushes , the brass one might be Ok but wears quickly. use WD40 if you like then wipe down with solvent (white spirit) and put a dob of silver paint on the heads with a fine brush. Tedious but doable. ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion |
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| MCN |
 MCN Super Spammer
| Easy-X |
 Easy-X Super Spammer
| Islander |
 Islander World Chat Champion
| jeffyjeff |
 jeffyjeff World Chat Champion
| dn38416 |
 dn38416 Nitrous Nuisance
The last post was made 2 years, 357 days ago. Instead of replying here, would creating a new thread be more useful? |
