| dn38416 |
 dn38416 Nitrous Nuisance
| to v or not to v |
 to v or not to v World Chat Champion
| A100man |
 A100man World Chat Champion
 Posted: 09:52 - 16 Jul 2023 Post subject: |
I'm a bit confused..
You say they are leaking , but also say they a full of jellified gunk. If so then I guess the bike doesn't run, so where are teh leaks?
Air we talking air leaks or fuel leaks? ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
| dn38416 |
| dn38416 |
| Polarbear |
 Polarbear Super Spammer
 Posted: 13:05 - 16 Jul 2023 Post subject: |
I know it's a lot of money per se but for that job done by a professional carb restorer seems pretty good.
I suppose it depends on your free time scale between now and september. If you have plenty of free time to devote to it then carry on and follow Stinkwheels reccomendation. Just take loads and loads of photos so you have references for when you come to reassemble. PersonallyI've never liked working on carbs as they are full of tiny screws that a ham fisted ships engineer like me strips for fun and a V 4 bank looks so much fun to work on.
If time is tight and money not quite so tight then go with the profesional clean and rebuild especially if that includes overhaul. At least then you are pretty sure everything is going to be OK.
Don't even bother with cheap ultra sonic cleaners. I have a cheap small one which is utter pants. My large one which was off a ship that got scrapped is superb but I know it cost well over a thousand when new. Also you have the cost of ultra sonic fluid which isn't cheap. I've tried the home made recipies to save money but they aren't a patch on te commercial fluid. ____________________ Triumph Trophy Launch Edition |
 Posted: 13:53 - 16 Jul 2023 Post subject: |
Make sure you have JIS screwdrivers too.
The factory manual is odd because it doesn't look like much but if you start at the beginning of the table and do the things in the order it gives you, it all goes back together, there are about 8 things you have to get all jiggled into the correct position as the two halves go back together and very little space to do them in. However, it is all lovely to work on being a 90's honda so everything fits where it's supposed to.
Have a very good look at the choke valves, they can get really sticky, they've given me some problems.
Oh, and do yourself a favour and get a set of new carb rubbers if you can find them, saves a lot of ballache. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| dn38416 |
 Posted: 11:48 - 30 Jul 2023 Post subject: |
Just for the benefit of the thread, the Chem Dip has been totally useless and barely removes anything. That makes me a bit concerned about any oxidation in the passages that I can't see/scrub. Jury seems out on trying to use citric acid on porous aluminium carbs. I know you mentioned boiling, but if there are still pressed brass parts in the body won't that screw up the fitting?
Anyway in other good news, the disassembly has been pretty easy so far, (hopefully not jinxing the re-assembly ). As Mr.Stinkwheel predicted the only bugger has been the choke plungers. 3 and 4 (right side cylinders) were stuck, so got them out with heat. Got the dremel polishing bit in there and predictably now worrying that I might take out too much. I think the seal is just with the rubber part on the end though rather than the bore itself. |
| jeffyjeff |
 jeffyjeff World Chat Champion
| MCN |
 MCN Super Spammer
| Easy-X |
 Easy-X Super Spammer
| Bikebolt |
 Bikebolt L Plate Warrior
The last post was made 2 years, 193 days ago. Instead of replying here, would creating a new thread be more useful? |
