| cvoelk |
 cvoelk L Plate Warrior
| Nobby the Bastard |
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| Nobby the Bastard |
| cvoelk |
| Nobby the Bastard |
| jeffyjeff |
 jeffyjeff World Chat Champion
| xX-Alex-Xx |
| stinkwheel |
 Posted: 19:56 - 31 Jul 2023 Post subject: |
You probably don't want to park it up for that long with a full tank of higher ethanol fuel because there's a fair chance it'll split leaving you with a layer of water at the bottom of the tank. So I'd either brim it with low ethanol/ethanol free fuel and possibly a fuel stabiliser or drain it totally. Maybe stick a big silicone sachet in there to keep it dry if condensation is a concern.
Battery off the bike and kept inside somewhere. This might be a situation where a lithium battery would be a good investment.
If it gets very cold and condensation is a big problem, sticking a few drops of oil down the bore and turning the engine over a few times isn't a silly idea.
Possibly overkill but it's probably the silly things that would stop you when you arrive like a tight link in the chain so lube and adjust it before you leave. Another issue with bikes parked up can be pads sticking to the discs so it wouldn't be a stupid idea to push the pistons back in a bit. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeffyjeff |
 Posted: 20:12 - 31 Jul 2023 Post subject: |
| stinkwheel wrote: | You probably don't want to park it up for that long with a full tank of higher ethanol fuel because there's a fair chance it'll split leaving you with a layer of water at the bottom of the tank. |
I've not considered that before, but your statement makes sense. Fuel stabilizer pretty much out of the question as it's not available in Morocco, not even in Casablanca, to my knowledge. Don't know what the ethanol content of Moroccan gasoline is (Shell, Total, Petrom, Petromin, Afriquia, Oil Libya), hopefully pretty low or none. Never had an issue when turning the fuel tap to "reserve", but I suppose the standpipe on reserve is still a little above the bottom of the tank. Probably the best way to remove all water is to remove the tank and drain it completely. (I don't want to mess with removing the petcock, lest I create a leak that cannot be readily repaired; the bike is parked in a rather remote location). ____________________ History shows again and again how nature points out the folly of men - BOC |
| Nobby the Bastard |
 Posted: 20:16 - 31 Jul 2023 Post subject: |
| jeffyjeff wrote: |
I've not considered that before, but your statement makes sense. Fuel stabilizer pretty much out of the question as it's not available in Morocco, not even in Casablanca, to my knowledge. Don't know what the ethanol content of Moroccan gasoline is (Shell, Total, Petrom, Petromin, Afriquia, Oil Libya), hopefully pretty low or none. Never had an issue when turning the fuel tap to "reserve", but I suppose the standpipe on reserve is still a little above the bottom of the tank. Probably the best way to remove all water is to remove the tank and drain it completely. (I don't want to mess with removing the petcock, lest I create a leak that cannot be readily repaired; the bike is parked in a rather remote location). |
Croatia is in the EU.... ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Triumph Sprint ST 1050 |
| stinkwheel |
 Posted: 20:49 - 31 Jul 2023 Post subject: |
So where is this bike again? It's 2,000 miles, 4 countries and a ferry crossing to get to Cassablanca from Croatia. It's on a different continant. I doubt you're riding a DRZ there. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Robby |
 Robby Dirty Old Man
| MarJay |
 MarJay But it's British!
| jeffyjeff |
| cvoelk |
| stinkwheel |
| jeffyjeff |
| MCN |
 MCN Super Spammer
The last post was made 2 years, 195 days ago. Instead of replying here, would creating a new thread be more useful? |
