Rotten Frame
blurredman
PostPosted: 11:31 - 01 Aug 2023    Post subject: Rotten Frame Reply with quote
I have bike with a frame that is rotten, quite unsafe.
I bought an identical, 2nd hand (but apparently never registered in the UK) frame.
I would obviously like to keep my registration number and historic classification and noticed a 'change vin no' section in the v5.
Am I obviously wrong in thinking I can just put the replacement frame's VIN in that spot and send the paper off and life would be so easy?
I'd rather just replace the single item in one go, as opposed to chopping bits and pieces of a good frame and welding the parts onto the original VIN item. Time consuming and quite a waste of the good frame - but is it the only real legal option just for the sake of keeping the same headstock number?
PostPosted: 12:50 - 01 Aug 2023    Post subject: Reply with quote
I believe that is the only legal option.
There are a variety of illegal but not morally wrong options. For example, I bet you can use an electric drill, teep set and a pop rivetter.
https://www.themzshop.co.uk/store/es175-250-2/frame-swing-arm/replica-vin-plate-for-es250-2/
https://plaque-de-cadre.fr/en/suzuki/100-suzuki-data-plate-n2.html
blurredman
PostPosted: 13:19 - 01 Aug 2023    Post subject: Reply with quote
The bike in question doesn't have a tag- just numbers on the headstock.
PostPosted: 13:46 - 01 Aug 2023    Post subject: Reply with quote
That's where the electric drill and rivetts come in...
WD Forte
PostPosted: 14:07 - 01 Aug 2023    Post subject: Reply with quote
Rotted frame?
CX ?
Some bloke who's name I don't recall had a similar dilemma.
This person had two CX frames the original registered one was rotted to hell the other in very good condition
As he owned both frames and they weren't not nicked nor nuffin
he creatively cloned the good for the bad and nary a word was said.
The trick as I recall was not to make them look fresh but to distress them like many antique dealers have done to furniture.
bikers smell of wee
blurredman
PostPosted: 14:12 - 01 Aug 2023    Post subject: Reply with quote
Yes. CX.
I understand the subtext- but has anyone actually tried it the paper way? Or am I right in thinking the paperwork is just a red herring to hell?
WD Forte
PostPosted: 14:15 - 01 Aug 2023    Post subject: Reply with quote
As I recall the paperwork was a pain in the arse back then and Q plates were mentioned but it may have changed since.
the Honda owners club or VJMCC may have some tips on this subject
bikers smell of wee
MCN
PostPosted: 16:32 - 01 Aug 2023    Post subject: Re: Rotten Frame Reply with quote
If its a classic British bike there are clubs for most and contacting them ca help.
I had to register two auld BSAs. One was made up from bits of several bikes. So never registered.
The BSA club have records of almost every bike manufactured in the BSA factory and so can certify the bike model and year of manufacture. And even what engine should be in it. (Serial No.)
You need that cert and dvla will issue a reg cert for the machine.
If its a Jap or European bike then I will remove my paddle from the water.
WD Forte
PostPosted: 16:45 - 01 Aug 2023    Post subject: Reply with quote
Honda CX circa 1980
bikers smell of wee
PostPosted: 19:23 - 01 Aug 2023    Post subject: Reply with quote
One thing is nobody official will ever be looking at the VIN again if it's registered as a historic vehicle unless you get pulled by a particularly nosy copper on a traffic stop. I've been stopped for a lot of things over the years and that's something they never checked.
So if you swapped out the frame, it's highly unlikely to ever become an issue unless you want to sell it.
CorriganJ
PostPosted: 14:19 - 02 Aug 2023    Post subject: Reply with quote
Unless he crashed it, in which case they might look at the frame, and they could presumably say he was driving withouth MOT and Insurance and tax because those things are associated with the origional frame...
If you have the second frame, can't you go through the import process yourself? You will of course need a new number plate.
1991 RD04
Nobby the Bastard
Harley Gaydar
PostPosted: 14:24 - 02 Aug 2023    Post subject: Reply with quote
So why is the only identication mark thats on all 3 of them the number plate?
Triumph Sprint ST 1050
CorriganJ
PostPosted: 07:36 - 03 Aug 2023    Post subject: Reply with quote
Gotcha but if the registration plate doesn't match the frame number isn't that a problem?
1991 RD04
A100man
PostPosted: 09:09 - 03 Aug 2023    Post subject: Reply with quote
Agree with Stinkwheel..
If the French site link can produce one of these..
https://www.cx500forum.com/attachments/186ec302-fc7b-463a-81f3-f31ed9d158c9-jpg.31521/
Then fill (e.g. with QuikSteel)and grind/sand back the old one and fit this on top.
OR
Fill sand the old/unwanted one VIN and stamp the wanted one alongside
WD Forte
PostPosted: 12:22 - 03 Aug 2023    Post subject: Reply with quote
That pic shows the plate on the RH rear frame not the headstock
UK CX's came with both and the numbers would match of course
but the stamped headstock number alone was often referred to as the plates would often go missing/get damaged or knocked off.
bikers smell of wee
slowasyoulike
PostPosted: 16:30 - 03 Aug 2023    Post subject: Reply with quote
I couldn't say for sure, but I will never give DVLA the benefit of the doubt... if there's a technically illegal but morally justifiable solution to my problem then I'd take that if it means not involving those clowns. Every time.
A100man
PostPosted: 08:47 - 04 Aug 2023    Post subject: Reply with quote
Ah - the perils of 'googling' with limited knowledge.. correction appreciated.
sickpup
Old Timer
PostPosted: 10:20 - 07 Aug 2023    Post subject: Reply with quote
blurredman wrote:
Yes. CX.
Oh yes, it's a road to hell.
Was it MattSpratt or his mate who fell down this particular hellhole?
The last post was made 2 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 104.62 Kb
