ZZR600 mysterious green/blue fluid
BenZZR
PostPosted: 13:11 - 03 Aug 2023    Post subject: ZZR600 mysterious green/blue fluid Reply with quote
Hi,
I’m fairly new to biking and have bought myself an old Kawasaki ZZR600 (1997).
I’ve put my first 400 miles on it and it’s running smoothly, however I’ve come across some blue/green fluid strung across the rear wheel arch. (See pictures).
I can’t see where this is coming from, but it’s worrying as looks like quite a lot has been lost. Doesn’t smell of anything and isn’t exactly oily to touch.
Hoping someone can help!
Thanks,
Ben
BenZZR
Easy-X
PostPosted: 13:34 - 03 Aug 2023    Post subject: Reply with quote
The first thing I think of with that colour (and not oily) would be coolant. From what I see of that model of bike the expansion tank is around the seat area (under a fairing) and the overflow is routed roughly above where you see the liquid collecting.
I'd suggest either the coolant has been overfilled or you're having some overheating issues and the coolant is boiling.
BenZZR
PostPosted: 13:37 - 03 Aug 2023    Post subject: Reply with quote
Thanks. Not had any overheating issues so I'll take a look at the coolant levels.
BenZZR
xX-Alex-Xx
PostPosted: 14:02 - 03 Aug 2023    Post subject: Reply with quote
Or the radiator cap spring is crapping out, allowing some flow into the expansion bottle causing it to overflow.
DILLIGAF
PostPosted: 14:52 - 03 Aug 2023    Post subject: Reply with quote
Coolant tastes sweet. Up to you if you want to risk tasting it...
Coolant can also be very slippy if it gets on your tyre which is why they run race bikes with water in.
Could also be tyre slime, that's green colured? If the tyre has been pre-treated with slime puncture prevention gloop and has a hole in it, some of the stuff can fling out before it seals.
WD Forte
PostPosted: 15:12 - 03 Aug 2023    Post subject: Reply with quote
Goop is green too, got some here
pitcher for comparison
sorry for the crap focus it's windy and the fonecam gets distracted easily
https://imgur.com/FuRv6l9.jpg
bikers smell of wee
jeffyjeff
PostPosted: 16:50 - 03 Aug 2023    Post subject: Reply with quote
Whatever it is, it's on your fender and on your swingarm. It's something you ran over, not leaking from your bike. Don't worry about it.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:27 - 03 Aug 2023    Post subject: Reply with quote
I disagree.
Triumph Sprint ST 1050
WD Forte
PostPosted: 17:37 - 03 Aug 2023    Post subject: Reply with quote
Nobby the Bastard wrote:
I disagree.
that was a bit polite Nobby
You feeling ok mate?
bikers smell of wee
Kawasaki Jimbo
PostPosted: 17:44 - 03 Aug 2023    Post subject: Reply with quote
My similar era Kawasaki has an overflow tube sticking out beneath the tail unit. It spat green coolant onto the road one summer in town when the radiator fan switch stopped working. Look for the same tube on yours.
Edit: in fact, what’s that running down the back of the battery box? Is it coolant leakage getting sucked forward by the airflow behind the engine and depositing on top of the swingarm?
BenZZR
PostPosted: 07:14 - 04 Aug 2023    Post subject: Reply with quote
Thank you everyone for your help. The cause has been found!
The rear wheel had been previously plugged and is spewing out tyre slime when at speed. So, time for a new rear tyre, however annoying with the amount of tread left.
Ps. Like coolant, tyre slime also tastes sweet Embarassed I should've checked that my coolant colour was red before testing this theory
to v or not to v
PostPosted: 17:15 - 04 Aug 2023    Post subject: Reply with quote
you could always buy a repair kit and plug the puncture yourself.
Moto Guzzi V7.
sickpup
Old Timer
PostPosted: 10:14 - 07 Aug 2023    Post subject: Reply with quote
It's puncture safe tyre sealant, h=you have a hole in your tyre that it may have sealed up.
The last post was made 2 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 76.81 Kb
