| CorriganJ |
 CorriganJ Scooby Slapper
 Posted: 05:50 - 14 Aug 2023 Post subject: |
| Easy-X wrote: | Avid readers may recall mention the next door neighbour's kid's R125 well the old fella's taken it on as a project and we've got as far as taking the engine out...
Jeez Louise, it's a lot of working stripping down a modern EFI bike. All the fasteners were either barely hand tight or welded in place by corrosion. Sheared off a few rad mount bolts - easy to drill out and replace - but the worst was the bottom engine mount bolt. We tried the usual heat + hammer the ever-living crap out of it but it wouldn't budge. We gave up and cut the ends of the bolt off
The plan is to take the top end apart for scrutiny (it has near zero compression.) Hmm... while disassembling the bike we noticed a lovely high flow K&N air filter and a straight-thru exhaust  I doubt it's ever been retuned so I'm guessing hole in piston.
An engine rebuild if it's practical or a second-hand replacement otherwise. After that I'd say stock air filter + stock exhaust otherwise it'll just blow itself up again. |
Just curious, why would an air filter and an exhaust blow a hole in the piston? Too much air flow meaning there is too much compression in the cyclinder and it damages things? I would have assumed that a 125 was so under-stressed that you could do almost anything to it and still have an engine that was... well, understressed? ____________________ 1991 RD04 |
| Nobby the Bastard |
| Easy-X |
 Easy-X Super Spammer
 Posted: 07:56 - 14 Aug 2023 Post subject: |
^^ Wot 'e said
On top of that you have an engine most likely run with insufficient coolant and/or oil and ragged to hell and back.
It's a sorry looking thing. If I saw a fleck of rust on my chain I'd feel very guilty, give it a clean and re-oil. This 125 the whole chain is a brighter shade of orange than David Dickinson Oh! the wilful ignorance of youth  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| A100man |
 A100man World Chat Champion
 Posted: 10:34 - 14 Aug 2023 Post subject: |
| Easy-X wrote: | Hmm... while disassembling the bike we noticed a lovely high flow K&N air filter and a straight-thru exhaust  I doubt it's ever been retuned so I'm guessing hole in piston.
If it's a 4T I'll go for burnt exhaust valve, in this sweepstake, if the compression has gone. ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
| Pete. |
 Pete. Super Spammer
| Bhud |
 Bhud World Chat Champion
 Posted: 17:47 - 15 Aug 2023 Post subject: |
I just started my rebuilt engine (every nut and bolt came apart) and it works!
I don't know why, but I had my doubts. Still have to torque up the bolts to the frame, put the brake lever and front footpegs back on, and a couple of other bits and pieces. |
| to v or not to v |
 to v or not to v World Chat Champion
 Posted: 18:36 - 15 Aug 2023 Post subject: |
put fluid back into clutch system after rebuilding the cylinders. then the sky came over dark as i was getting ready to take it out and test it  ____________________ current bike Yamaha Thunderace.
Moto Guzzi V7. |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| recman |
 recman World Chat Champion
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
| stinkwheel |
 Posted: 16:42 - 17 Aug 2023 Post subject: |
| A100man |
 Posted: 17:10 - 17 Aug 2023 Post subject: |
Indian Balls? ____________________ Now: A100, GT250A, XJ598, FZ750
| stinkwheel |
| ZebraDriver |
 ZebraDriver Scooby Slapper
| RhynoCZ |
 RhynoCZ Super Spammer
| Nobby the Bastard |
| hellkat |
 hellkat Super Spammer
 Posted: 20:51 - 17 Aug 2023 Post subject: |
I discussed the Suzuki with its mechanic and apparently he thinks it needs to have the stator replaced.
But it might be something else.
 ____________________ Not nearly as interesting in real life. |
| Nobby the Bastard |
| hellkat |
 Posted: 21:37 - 17 Aug 2023 Post subject: |
When the engine is running, the battery is draining. When it stops running, the battery starts to recharge again.
But two out of three (somethings ... ?voltages?) are very low (3 and 4) whereas the third is 12(v, I think)
That's what [I think] he explained to me
Might be a bit of wiring, or the reg-rec but he's starting with replacing the stator and see where that takes us.
Meh. ____________________ Not nearly as interesting in real life. |
| Pete. |
 Pete. Super Spammer
 Posted: 05:48 - 18 Aug 2023 Post subject: |
| hellkat wrote: | When the engine is running, the battery is draining. When it stops running, the battery starts to recharge again.
Meh. |
It's a Suzuki GSX - it;ll be the reg/rec. They are well known for it.
The stator is easy to check, all three phases should be putting out the same about 60-70volts AC at 5k revs. ____________________ a.k.a 'Geri'
| hellkat |
| grr666 |
 grr666 Super Spammer
 Posted: 16:55 - 18 Aug 2023 Post subject: |
That definitely would have gone pop on the way over to or back from me. Glad you took the train. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off.  |
| hellkat |
| to v or not to v |
| hellkat |
 Posted: 12:25 - 19 Aug 2023 Post subject: |
Well I picked the Suzuki up, chatted with a few old coots whilst waiting for the MOT, nothing remotely marriageworthy, although their guy that does Harleys is a Kiwi (!) so I had a bit of a nag with him, but he's going home soon ...
Anyway its so sunny I am tempted to go straight back out for a ride.
The old unworthy stator (which was returned to me) was all black and grim-looking, the mechanic says its *supposed* to be a sort of goldish colour. At least now I know what one looks like
What do you guys do with old parts when you get given them back by the garage? ____________________ Not nearly as interesting in real life. |
The last post was made 2 years, 147 days ago. Instead of replying here, would creating a new thread be more useful? |
