Suzuki bandit died and won’t start
Lgarretto
PostPosted: 10:19 - 29 Sep 2023    Post subject: Suzuki bandit died and won’t start Reply with quote
Hello guys. I’m kinda in a big pickle. I have a 2002 bandit 1200n. Has 17k miles, bought with 15k, and up to now has ran great.
My ride to work is about 45 minutes. About 35 minutes in, running 80-85 down the interstate, the bike starts sputtering and lurching and loses power. Almost feels like it’s only running on one or two cylinders and missing bad. It would accelerate, but slowly. I didn’t change gears for fear of it dying. Slowed down and sputtered to my turn off about a mile more down the road. Sure enough, Clutch in was immediate shut off. Bike died like I hit the kill switch. Electrics seem fine, gauges and lights come on with the key. But the starter just spins. Visibly everything seems fine
It was running perfect. When I started it this morning it started on the second fire, no choke. Just like always.
PostPosted: 10:24 - 29 Sep 2023    Post subject: Reply with quote
Turn the fuel tap to the PRI position. It could be that the fuel tap is not getting vacuum from the small vac line. They can split where they connect to the throttle body barb (which I believe should be No2 carb but I'm not sure.
Nobby the Bastard
Harley Gaydar
PostPosted: 10:26 - 29 Sep 2023    Post subject: Reply with quote
One of your ignition coils is failing. When being used they get warm and as it warms it stops working. Once it's cooled down it starts working again. Rinse and repeat.
Triumph Sprint ST 1050
Lgarretto
PostPosted: 10:33 - 29 Sep 2023    Post subject: Reply with quote
I guess I should mention I don’t have the factory petcock. It’s an aftermarket one with regular old on/off/reserve.
Bad coil. Odd it happens now. I have ridden a good bit longer without issue.
Also, as I am sitting on the side of the road currently waiting on my wife, I may have found another problem. Looks like there’s nothing holding the starter in. Wonderful. Doesn’t surprise me though. Guy I bought it from lied about a lot
Kawasaki Jimbo
PostPosted: 10:44 - 29 Sep 2023    Post subject: Reply with quote
Carb icing maybe? What was the weather like? Cool (not necessarily cold) and humid will do it.
PostPosted: 11:06 - 29 Sep 2023    Post subject: Reply with quote
Yank the pipe off the fuel tap and see if fuel runs.
Lgarretto
PostPosted: 11:34 - 29 Sep 2023    Post subject: Reply with quote
It’s 72 degrees so I think the carbs are ok. Could be clogged somewhere. I just got home, I guess I’ll grab my truck and trailer and go get it and I’ll just have to pull it apart and see what’s going on. I’ll look into all that. Thank yall
Nobby the Bastard
Harley Gaydar
PostPosted: 11:40 - 29 Sep 2023    Post subject: Reply with quote
72 degrees? That makes you a yank. Shitty low octane fuel?
doggone
PostPosted: 11:42 - 29 Sep 2023    Post subject: Reply with quote
Ignition coils can go off and on for a while as they start to fail.
PostPosted: 12:37 - 29 Sep 2023    Post subject: Reply with quote
I think that "running 80-85 down the interstate" gave that bit away.
Lgarretto
PostPosted: 12:58 - 29 Sep 2023    Post subject: Reply with quote
Lgarretto
PostPosted: 13:07 - 29 Sep 2023    Post subject: Reply with quote
Could be bad fuel. I got it a different place than usual last.
Yeah. I’m a yank lol. Least to you fellers across the pond. Round here you watch who you call a yank though. Got a different meaning
A100man
PostPosted: 16:02 - 29 Sep 2023    Post subject: Reply with quote
'Yall' = southern states and they don't like dem damn yankees much I believe. Ol' Boss Hogg taught me that.
Easy-X
PostPosted: 17:44 - 29 Sep 2023    Post subject: Reply with quote
I've been playing RDR2 and the term "Yank" holds equal weight to the N-word (from the character's point of view) #JustSayin' Rolling Eyes
Maybe we should refer to our friends over the pond as "The Men without Irony" would that be more acceptable? Laughing
Nobby the Bastard
Harley Gaydar
PostPosted: 17:50 - 29 Sep 2023    Post subject: Reply with quote
The irony is that they wouldn't get it.
Lgarretto
PostPosted: 18:09 - 29 Sep 2023    Post subject: Reply with quote
Can’t say it’s all lies.
Well so I got the bike home. Starter clutch and flywheel were loose. Started right back up. Hopefully problem solved
Nobby the Bastard
Harley Gaydar
PostPosted: 09:56 - 30 Sep 2023    Post subject: Reply with quote
If it wasn't working and now runs fine, my money is still on a coil starting to break down when hot.
to v or not to v
PostPosted: 17:35 - 30 Sep 2023    Post subject: Reply with quote
in that case i think id want to give the bike a thorough going over before i felt comfortable riding it in public.
Moto Guzzi V7.
Chuffin Nora
PostPosted: 10:21 - 01 Oct 2023    Post subject: Reply with quote
Lgarretto wrote:
wife
Pics or it didn't happen.
Whistle
There's a fine line between integrity
jeffyjeff
PostPosted: 20:03 - 02 Oct 2023    Post subject: Reply with quote
I don't get it. Confused
blurredman
PostPosted: 08:23 - 03 Oct 2023    Post subject: Reply with quote
Not necessarily. It wasn't all that long ago it used to be the unit of choice for the empire.
Islander
PostPosted: 09:45 - 03 Oct 2023    Post subject: Reply with quote
Who's an old bastard then? We switched to centigrade/celcius in 1962. Laughing
blurredman
PostPosted: 11:27 - 03 Oct 2023    Post subject: Reply with quote
On the contrary, it's all around. You ever seen the temperature display behind the reception desk on 'Brittas Empire' ?
Even now they still occasionally state the temp in F on the weather on TV Razz
Just the other day I bought my daughter a kids doctor's set and the ear temp reader had a sticker faus display and was in F only.
When I state such things people say to me, "I want you to speak to me in English units, C". And it always strikes me as funny and it makes me wonder that one day soon after 20-30 whatever years after we finally change to Kilometer use in the UK that someone might say very similar "Why'd you talk miles, I want you to speak to me in my English kilometers".
Nobby the Bastard
Harley Gaydar
PostPosted: 20:43 - 03 Oct 2023    Post subject: Reply with quote
Ah yes. On the weather forecast. Usually when it either going to kill the elderly because its bitterly cold or sweltering hot so they dress accordingly.
Personally I use SI units so the thermostat for my heating is set to 291K.
PostPosted: 22:59 - 03 Oct 2023    Post subject: Reply with quote
I was sailing on ships with gauges in PSI and farenheight less than 10 years ago. Gauges showing 1000 psi steam pressure seem so much more fightening than ones showing 65 bar. Laughing
The last post was made 3 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 127.18 Kb
