Fast Getaway
WildGoose
White Van Man
PostPosted: 19:52 - 12 Nov 2002    Post subject: Fast Getaway Reply with quote
help
pulling away from standstill, is not fast
doesnt feel any faster than on the moped, once the clutch it out, and im into 10k, then it takes off, but im pretty sure i should be pulling away much faster than i am
the CBR250 website says you need 6000RPM for serious urge, i seem to be missing the urge
so any tips?
Ropehead
PostPosted: 20:01 - 12 Nov 2002    Post subject: Reply with quote
whats the top speed in 1st?
PostPosted: 20:10 - 12 Nov 2002    Post subject: Reply with quote
Hmmm ... I get the same on the ZX6 Smile (though it does start pulling a bit lower)
What I generally do (if you want to learn how to replaces cutches) is to 'slip' the clutch. This means revving it to say 10k (or possibly higher as it red lines at 19k.. obviously lower on the zx) and hold the clutch just past the biting point... this means that a fair bit of power gets down, but the bike doesn't wheelie or bog down.
The other thing to do is to dump the clutch at higher revs... the only problem is that it probably will just bog down on a bike without much tourque. Obviously you don't want to dump the clutch at to high a revs as the bike may well wheelie ... or flip if it happens to be a 1000cc vtwin Very Happy
Ropehead
PostPosted: 20:14 - 12 Nov 2002    Post subject: Reply with quote
the only problem with sliping the cluch is:-
- new chain
- new sprockets
- new cluch
But u will get away faster Laughing
PostPosted: 20:20 - 12 Nov 2002    Post subject: Reply with quote
Well.... fast acceleration is gonna knacker your chain and sprockets whatever....
OBvioulsy it *will* knacker your clutch... but should be better than my zx, cos you don't have 100hp to kill it with Very Happy
And you will get away faster Very Happy
WildGoose
White Van Man
PostPosted: 23:18 - 12 Nov 2002    Post subject: Reply with quote
my bike does just over 45mph in first rope, but i cant tell cos its only gay stickers on the speedo
hmmm, new clutch, new chain, new sprockets
maybe i'll just deal with being slow Razz
stevo
PostPosted: 23:43 - 12 Nov 2002    Post subject: Reply with quote
I have heard that to make the fastest possible getaway, you want to release the clutch at an engine speed just below peak torque, and keep slipping the clutch to maintain this engine speed until the bikes moving at the same speed. Sounds logical, even straightforward. But sumhow i feel that trying to pull away at 9000 on my zx6 would result in a fast getaway for the bike, but not neccasrily for me!
The Voices made me do it.
WildGoose
White Van Man
PostPosted: 23:45 - 12 Nov 2002    Post subject: Reply with quote
torque, whats that Razz
PostPosted: 00:35 - 13 Nov 2002    Post subject: Reply with quote
On the zx6 I find it's best to slip the clutch... it's lets you control the front while obviously you're gonna be on you're back if you drop it at that rpm (I have gone through a lot of cluthches though)
Goose... just dropping the clutch will probably knacker the chain and spockets more because there's a sudden jerk, while the slipping smoothes it out.
In the end, teh way I see it is that I spent a whole load of money to get a damn fast bike, so I might as well spend a little bit more to get a little bit faster bike Smile
Scotty
Scooter Boi
PostPosted: 11:26 - 13 Nov 2002    Post subject: Reply with quote
I always slip the clutch if i want to get away fast,
sometimes the front lifts of the floor, but rarely does, i know it knackers the clutch, but from what i hear there not all that expensive on the NSR.
Dunno about fitting them though, guess ill just have to learn...
But once you have got the clutch sliping down to a T for a 125 it shifts of the line fairly quick....lol
Regards
Scott
kev
I Hump Things
PostPosted: 11:33 - 13 Nov 2002    Post subject: Reply with quote
i normally just rev to about 4000 drop the clutch then crack it open its always seemed to work for me and its won me a hell of alot of races
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
Demonic69
The Pink Rhino
PostPosted: 11:37 - 13 Nov 2002    Post subject: Reply with quote
Yeah, but he has a few less HP than you Wink
I slip the clutch but don't keep the revs too high before i set-off. I find it best to bring on the power as oppose to keeping it constant
Back on a Blade. Just feels so right.
tanner18
PostPosted: 13:00 - 13 Nov 2002    Post subject: Reply with quote
i always slip the clutch if i wanna make a fast getaway, but as mentioned before ure bike will need more regular servicing/maintenance. i rev to 12000rpm on my zxr and slip the clutch so the revs stay between 12 and 13000, im pretty good at it cos i did it all the time on my nsr. i wanna do a standing 1/4 mile to see what time i could do it in.
inline 4's rule
Demonic69
The Pink Rhino
PostPosted: 13:09 - 13 Nov 2002    Post subject: Reply with quote
BdB next year then?? Very Happy
I think I need my compression looking at Sad
Guest
PostPosted: 14:13 - 13 Nov 2002    Post subject: Reply with quote
Well, I would say slip the clutch. It will put a bit of strain on the chain but then that strain is pretty much directly proportional to the acceleration you are getting. As long as it is smooth then the chain isnt getting too hard a time (whereas just dumping the clutch at high revs will be a hell of a shock to the chain, as well as to you if you try it on a bigger bike and it dumps you on the road). Clutch wear will be greater, but then clutches seem to last well
Reaslistically your bike is only starting to make power over 10000rpm, and that is at least 20mph. You can either wait for those revs to arrive or use the clutch to cheat a bit.
Anyway, clutches and chains are consumables. Your happy about using a bit more fuel to go quickly, so why not spend a bit mroe on the other consumable Cool
PostPosted: 14:15 - 13 Nov 2002    Post subject: Reply with quote
Could you please explaim that to my ZX Very Happy
Hunter
PostPosted: 16:24 - 13 Nov 2002    Post subject: Reply with quote
Hi there!
45mph on the first gear for a 4s 250 seems a little too high, check your sprockets sizes to make sure you are running stock sizes.
I have ridden a CBR250 that belonged to a mate, but that seemed to have no problem flying off on first with little or no clutch clutch slip.
My NSR SP with a tall first gear only takes me to 62kph at 10,000 rpm (powerband ends at 11,500). This requires a lot of clutch slip to help take off though!
Phoenix
Twisted Firestarter
PostPosted: 18:04 - 13 Nov 2002    Post subject: Reply with quote
I tend to find the best way to get away first and not damage anything is by positioning my bike in front of the car that wants to race then I can just pull away at a leisurely pace Laughing
PostPosted: 18:34 - 13 Nov 2002    Post subject: Reply with quote
Hardly humiliates the boy racers with his £000s worth of body kits though Very Happy
WildGoose
White Van Man
PostPosted: 20:14 - 13 Nov 2002    Post subject: Reply with quote
hmm
you are all saying slip the clutch, like its something you dont do normally Confused
i dont think ive ever dumped it, apart from once when i wanted to see what happens,
the slowness, i think is just because below 10 000 on my bike, you might as well get off and push
hunter, i have no way to tell if the sprockets are standard, but the ratio on first must be quite out of proportion to the others (at a guess) because i also get the most severe engine braking going from 2nd to 1st
but then i got no clue what im talking about so Smile
PostPosted: 20:28 - 13 Nov 2002    Post subject: Reply with quote
I have dumped the clutch a few times just to see what happens, and if it will wheelie at all. Just like I have tried clutchless shifting. I now know I can do them, but I im not interested in making bills Smile
I normally if I want to pull away fast rev it in the powerband, and letting the clutch out.
Bendy
Mrs Sensible
PostPosted: 20:34 - 13 Nov 2002    Post subject: Reply with quote
First pretty much sucks on my bike, so I just use it to get moving, then whang 'er into second and away you go. Sounds considerably less painful as well - first is all noise and very little actual movement.
WildGoose
White Van Man
PostPosted: 20:37 - 13 Nov 2002    Post subject: Reply with quote
i dont ever change into second until im well into the power, cos it wont pull at all well low down, unlike your bike
plus noise is good, i love making people turn round, cos you sound like you are doin 150mph Very Happy when you are only doin 40 in first gear Smile
Mr Lucky
PostPosted: 20:49 - 13 Nov 2002    Post subject: Reply with quote
Slipping the clutch has no adverse effect on chain wear whatsoever (unless your clutch is so knackered that it judders or grabs).
A clutch is slipped to some extent every time a gear is engaged, wether it be pulling away at sedate revs or hooking from 3rd gear to 4th gear at the redline, so it is pretty hard to avoid unless you don't use the clutch to change gear.
Chains will have an easier time if you slip the clutch at 5k from a standing start than if you just dumped the clutch at the same revs. Think about it for a second or two. Your chain is actually getting an easier time of it when the clutch is slipping as the clutch is bleeding power away from the chain, allowing the rear wheel speed to catch up with the crank speed gradually. Dumping the clutch with big revs on will 'yank' the chain and give the cush drive a hard time too.
The biggest killer of chains and chain wheels/sprockets is poor maintenance. A regularly cleaned, correctly adjusted chain will last a very long time, no matter what kind of abuse it receives. A chain with no lubrication at all simply heats up and grinds away at itself, the chain wheel/sprocket and anything else it comes into contact with (swingarm top bottom faces etc). A chain covered in old lube and grit simply has the added bonus of a grinding paste to help out with premature wear.
Been for a ride and felt your chain lately (wait until you stop Rolling Eyes) ? Is it hot to touch? Then your chain is poorly adjusted and/or badly lubricated. I can run my Hayabusa at very high speeds for a good distance and when I stop I can touch the chain with my bare hand, no problem.
I assume that you all know how to clean and maintain a chain? I am not just talking about spraying a bit of PJ1 Blue at it every other week either! remember not to just clean the chain. Look at the inside of the chainwheel sprocket casing and you will more than likely be greeted with a site like 40 a day smokers lungs. Get shot if it before you put your chain back on.
If you have a hot chain you have a problem.
Your chain needs energy to heat up. Guess where that energy is coming from? Yes it is useing energy that was destined to turn your back wheel and stealing it to heat itself up (bad chain, naughty chain! In your bed!).
You would be horrified to find out how much hp a knackered chain can sap Exclamation
A clutch that gets a lot of high revving slippage will of course wear out quicker than a one that doesn't.
When you think about it it is amazing that clutches don't need replacing every few days considering the abuse they get, but at least most of them get lathered in oil, unlike the poor chain just down the 'transmission street'. A wet clutch will benefit from regular oil changes. When fitting new clutch plates in a wet clutch assembly, leave the new clutch plates to soak in clean engine oil over night. Again this combats premature wear and also means your clutch won't soak up the precious engine/gearbox oil that was meant to lube other parts.
Dry clutch? Well, ask your resident and until recently Ducati owner. Keep them cool and free of dust is probably what he will tell you. Drilled clutch casings on dry clutches look the nads too...
https://www.labusas.org
Mr Lucky
PostPosted: 20:54 - 13 Nov 2002    Post subject: Reply with quote
Stephen.
Clutchless changing is an art which is easy to master and when mastered can give you very fast, seamless changes. It is also less of a strain on the transmission when done right. Of course, some bikes gearboxes simply are not suited to clutchless changes.
Usefull if you ride a bike with a narrow powerband and worth at least a 10th of a second per change on the 1/4 mile...
The last post was made 23 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 126.62 Kb
