cm250t custom
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2
lingeringstin...
PostPosted: 00:03 - 25 Apr 2024    Post subject: Reply with quote
If you've been inside your carb then you've probably already seen everything but one time I had a bike that would start and idle fine but the moment you opened the throttle it would die. Turns out the fecking needle had actually come loose from the slide (little clip thingy failed) and it was just sitting loose down in the main jet regardless of what I did with the throttle.
I don't know which carb you've got but on a lot of them the idle jet and the main jet are at two different levels in the fuel bowl, so the idle may be getting fuel but if the floats are out of order there may not be enough fuel in the bowl to come up to the main jet.
Also some carbs (old Honda designs as I recall) incorporate a little pump mechanism that was supposed to give a wee squirt as you opened the throttle but they were shit and if the pump wasn't working right all you'd get at initial throttle blip was a suction of mostly air and the bike would die.
vorlon
PostPosted: 22:39 - 28 Apr 2024    Post subject: Reply with quote
so update.
took the carbs off and cleaned them, put back and found the choke cable was no good. ordered a new one. carbs off again and another clean. put back on. took all the fuel out of the tank and replaced with new E5.
engine started but seemd to be on choke all the time. so off again and given a good look. it seems that i bent a tab which is part of the return spring. bent it back and back on again. success and its seems to be running ok.
vorlon
PostPosted: 18:44 - 08 May 2024    Post subject: Reply with quote
so bike runs now but a new issue. the trip meter is not working, this appears to be digital. any clues please?
lingeringstin...
PostPosted: 01:21 - 12 May 2024    Post subject: Reply with quote
I'm running near as dammit that same engine and they're basically quite reliable with not much complication. However, I have found mine to be the pickiest engine I've ever had regarding carb issues. It throws a wobbly at the slightest malfunction when most of the bikes I've ever had would tolerate with all sorts of carb shananigans.
I don't know why those particular Honda engines are like that but bear in mind that it's basically a 125 twin (exact same valves and cam) that was poked out to a 250 before they stopped making them altogether.
I don't remember if your model had one or two cv carbs setup but mine is really happy now with a single 27mm slide carb and a Quadzilla quadbike single carb intake. Never had any issue with the ignition system. It's the easiest bike to bump start I've ever had, so I wouldn't think spark was the issue.
PostPosted: 08:48 - 12 May 2024    Post subject: Reply with quote
I don't know about yours in particular but Honda went through a phase of using a flexible PCB in the back of their instrument panels. They turned out to be very prone to corrosion or delamination of the tracks. If your bike has one of these, the damaged tracks are visually obvious as a darker colour than the others or even green and corroded or broken. The tricky bit is getting to the back of it, usually requires a lot of dismantling.
If you're very good with a soldering station, you can re-flow the tracks or solder a wire to bypass the bad sections. Or you can rip the whole thing out and relace it with conventional wired connections. Both options take a degree of familiarity with building/repairing electronics and a methodical approach.
Could also be as simple as a bad or corroded connector either in the back of the clocks or at the sender. If the speedo is working, it's probably the clock end.
vorlon
PostPosted: 21:02 - 11 Jul 2024    Post subject: Reply with quote
is there a twin disc option for this bike?
PostPosted: 22:15 - 11 Jul 2024    Post subject: Reply with quote
It would probably be a case of fitting a whole front end off something else, which is never as straightforwards as it seems it's going to be. You'd need the whole lot including forks, wheel, mudguard, spindle and spacers, callipers, disc hoses and master cylinder. Pick one with the same fork diameter and length and roughly the same weight. You'll still need to fit different spacers etc unless you're very lucky.
A lot of work. So my question is have you made the brake as good as it can be? New hose, rebuilt calliper and master cylinder, fresh fluid and new pads? It's hardly a Hayabusa so I'd expect a single disc would be sufficient.
Brembo part number: 07HO0712 is your friend.
Easy-X
PostPosted: 23:57 - 11 Jul 2024    Post subject: Reply with quote
The old fella's Harley has a wet weight of 330kg... single disk up front Shocked
vorlon
PostPosted: 17:51 - 11 Aug 2024    Post subject: tank problem Reply with quote
so something new just happened. i went out to get the bike turned ready for tomorrows ride to work and i noticed a wet patch. thurns out the tank has a leak. looks like and old crappy repair job by the last owner. i will need to get this proffesionally done i feel. any recommendations please? possibly will need some paint also.
i sent a mail to a company called dream machine(got fromclassic motorcycle mechanics)
Robby
Dirty Old Man
PostPosted: 20:52 - 11 Aug 2024    Post subject: Reply with quote
Find a tank on ebay. Repairs are tricky, and if it's rusted through in one place then the rest of it won't be far behind.
Dream machine are very good, but expensive.
vorlon
PostPosted: 17:48 - 13 Aug 2024    Post subject: Reply with quote
wow no joke they are expensive 400 for the tank, 590 for tank+paint plus vat!
may try to do this myself as the tanks i have seen for sale were worse than mine. any idea what the paint is anyone? ral no or best match.
Robby
Dirty Old Man
PostPosted: 19:12 - 13 Aug 2024    Post subject: Reply with quote
If you're buying a tank, I would try to just buy one the same colour as what you have now.
vorlon
PostPosted: 21:48 - 13 Aug 2024    Post subject: Reply with quote
i would but they were all in horrible condition. when i took off all the putty it is just a coupleof small pinhole, so i think i can repair this myself
lingeringstin...
PostPosted: 21:56 - 19 Aug 2024    Post subject: Reply with quote
Oh dear, the dreaded vintage Jap tank rot. Behind the tank badges I presume?
Yeah you probably CAN repair the pinholes with something but my experience with that sort of thing is that the rest of the tank is also probably rotten in a few other hidden places and it becomes a never ending job.
Unfortunately it usually seems like replacing a tank with the correct one is stupid expensive on "vintage" Jap bikes, which always led me down the path of cobbling whatever I could find that would hold petrol. Random tanks are two a penny on Ebay but the correct one for whatever you need is always rare and expensive.
A lot of "vintage" Jap tanks will be a bit iffy by now. Old Bantam tanks are pretty good because the metal had a higher lead content so they don't tend to rust as bad. but then you have to get a bloody Ewarts fuel tap for them because nothing else fits, but they're still pretty good tanks if you can live with only a couple of gallons at a time.
Robby
Dirty Old Man
PostPosted: 09:29 - 20 Aug 2024    Post subject: Reply with quote
Cobbling something else on sounds like a good shout. I hadn't thought about old British fuel tanks before, but they are thicker. Also worth thinking about tanks from newer bikes, that have had less time to rust.
Fixing an old fuel tank is difficult. I've tried brazing one up before. Things I discovered:
1. Getting every last bit of fuel vapour out is difficult. I drained the tank, left it open in the garage for a week, flushed it through a lot with water, left it open some more. Still made little fireballs when I started brazing.
2. For the braze to stick, you need to have clean metal. This means sanding back the area in question. You will find more pinholes doing this. I thought I had 2 or 3 holes, I had more than 20.
3. For the braze to stick you need to get enough heat into the metal. This is tricky, because the tank is a big heat sink. So it doesn't stick that well, and you end up with small leaks.
4. The right way to do it is to weld in fresh metal. This means cutting back to where the existing metal is thick enough to weld, cutting and shaping the repair patches, and welding them in. I don't have the skills for that.
5. Even if this works, the whole thing needs to be repainted afterwards.
A100man
PostPosted: 10:37 - 20 Aug 2024    Post subject: Reply with quote
Lead? As part of the steel alloy? Really?
Edit.. I have though seen article of folk using plumbing solder and a spade-sized iron to flow lead into tank pin-holes
Easy-X
PostPosted: 10:45 - 20 Aug 2024    Post subject: Reply with quote
The alternative to brazing would be soldering. Silver solder you can do with MAPP gas, Lead with any old gas. Only good for small holes though.
lingeringstin...
PostPosted: 01:08 - 21 Aug 2024    Post subject: Reply with quote
[quote="A100man"][quote="lingeringstink"]Old Bantam tanks are pretty good because the metal had a higher lead content so they don't tend to rust as bad. [/quote]
Edit.. I have though seen article of folk using plumbing solder and a spade-sized iron to flow lead into tank pin-holes[/quote]
Yeah, that's a weird one but some old bloke told me that decades ago. The story was (according to him) that the fuel tanks on old Brit bikes had a higher lead content in the metal to prevent sparking on the pavement if the bike was in a crash. I have no idea if that is true but that's what the old guy said. One thing I do know is that the old Bantam tank I use has not had any paint on it for at least 30 years and it's not rusted through. It's got a weird patina but it doesn't rot. There's a small flake of red paint on it somewhere so it was either a tank off a GPO Bantam or an Ariel tank. All I know is it has never rusted like old Jap tanks do.
vorlon
PostPosted: 02:21 - 10 Sep 2024    Post subject: Reply with quote
update, so repaired the tank with solder, they were just pinholes. also covered with filler, sanded down and painted. then used wagner rust treatment and then tank sealer. that should do it.
PostPosted: 07:48 - 10 Sep 2024    Post subject: Reply with quote
Don't know about in the alloy but they used to flow lead over bodywork with a huge flat soldering iron to level the surface before paint, in much the same way we'd use filler now.
I always thought the finish on your tank was pretty cool. I force a similar patina onto raw steel by heating it up and applying oil or wax to the hot metal, almost a kind of blueing. Tends to go black with oil or brown with beeswax. I always assumed yours was a result of years of spilled fuel premix being left out in the sun. Didn't you used to run it on a mix of petrol, BBQ starter fluid and mazola?
I got a replica works trials tank for my trials bullet from India but made of steel not alloy. The steel is really thick and they do a lot of replica tanks for old brit iron over there. It was quite cheap so even when I got hit with an import charge, it was a good buy (duty on vehicle parts from India is only 2% so the "handling charge" was more than the duty).
You can get a whole variety of fuel taps with 1/4 and 1/8 BSP threads and a normal spigot. I use OMG brand ones which are cheap and effective; Although I put a pingle on my big bullet for flow-rate reasons, it's like turning a bucket upside down. Had to get an NPT to BSP adapter off ebay for it.
vorlon
PostPosted: 15:04 - 28 Sep 2024    Post subject: Reply with quote
ok, so new problem. this thing hates me.
so it was running but not well. read somewhere that this could be the coil not the carbs. checked and the right side spark was pretty weak. so got a coil (https://www.squaremotorcycleparts.co.uk/products/ignition-coil-honda-cm250-cm-250-custom-1982-1983)
and fitted it, tried the spark test and nothing on either side. re did all the connections and still nothing. put the old coil back on and the same, no spark at all. what next?
vorlon
PostPosted: 16:48 - 18 Oct 2024    Post subject: Reply with quote
so, update. tried new coil, working cdi from ebay, still the same. is not kil switch. local bike shop took a look and said stator/grenerator. where do i get one of these? cant see on ebay. is the same engine as a superdream, right. i would have thought there would be loads of options!
Nobby the Bastard
Harley Gaydar
PostPosted: 16:56 - 18 Oct 2024    Post subject: Reply with quote
Ah, the old 'throw parts at it until it starts working' trick.
Triumph Sprint ST 1050
lingeringstin...
PostPosted: 19:00 - 20 Oct 2024    Post subject: Reply with quote
[quote="vorlon"]so, update. tried new coil, working cdi from ebay, still the same. is not kil switch. local bike shop took a look and said stator/grenerator. where do i get one of these? cant see on ebay. is the same engine as a superdream, right. i would have thought there would be loads of options![/quote]
I'm running a copy of a Honda twin (CMX250 or early Rebel 250 engines) and the whole ignition system is the same as a Jinlun or Zongshen 125/250 and several other Chonda twin engines roughly referred to as 253FMI, and it's the same as the 125 versions whatever they're called.
My engine is actually an abomination made out of Honda parts and Chinky stuff but it all bolts together just fine. I've had no problems with the Chinky ignition system I use
But here's something weird: I once bought an actual Honda rotor for a 250 Rebel off Ebay to use on my Chinese copy electrical system and it would not make electricity. No idea why. The rotor was identical looking and fit right on but there was nothing happening. I eventually got another Chinese rotor off something else (Quadzilla 250e is the same engine) and that worked.
Someplace like CMPO might be a source for new stuff if you're not keen on Ebay unknowns.
The last post was made 1 year, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 124.96 Kb
