| lingeringstin... |
 lingeringstin... Spanner Monkey
| vorlon |
 vorlon Derestricted Danger
| vorlon |
| lingeringstin... |
| vorlon |
 Posted: 22:15 - 11 Jul 2024 Post subject: |
| vorlon wrote: | is there a twin disc option for this bike? |
It would probably be a case of fitting a whole front end off something else, which is never as straightforwards as it seems it's going to be. You'd need the whole lot including forks, wheel, mudguard, spindle and spacers, callipers, disc hoses and master cylinder. Pick one with the same fork diameter and length and roughly the same weight. You'll still need to fit different spacers etc unless you're very lucky.
A lot of work. So my question is have you made the brake as good as it can be? New hose, rebuilt calliper and master cylinder, fresh fluid and new pads? It's hardly a Hayabusa so I'd expect a single disc would be sufficient.
Brembo part number: 07HO0712 is your friend. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
 Easy-X Super Spammer
 Posted: 23:57 - 11 Jul 2024 Post subject: |
The old fella's Harley has a wet weight of 330kg... single disk up front  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| vorlon |
| Robby |
 Robby Dirty Old Man
| vorlon |
| Robby |
 Robby Dirty Old Man
| vorlon |
| lingeringstin... |
| Robby |
 Robby Dirty Old Man
 Posted: 09:29 - 20 Aug 2024 Post subject: |
Cobbling something else on sounds like a good shout. I hadn't thought about old British fuel tanks before, but they are thicker. Also worth thinking about tanks from newer bikes, that have had less time to rust.
Fixing an old fuel tank is difficult. I've tried brazing one up before. Things I discovered:
1. Getting every last bit of fuel vapour out is difficult. I drained the tank, left it open in the garage for a week, flushed it through a lot with water, left it open some more. Still made little fireballs when I started brazing.
2. For the braze to stick, you need to have clean metal. This means sanding back the area in question. You will find more pinholes doing this. I thought I had 2 or 3 holes, I had more than 20.
3. For the braze to stick you need to get enough heat into the metal. This is tricky, because the tank is a big heat sink. So it doesn't stick that well, and you end up with small leaks.
4. The right way to do it is to weld in fresh metal. This means cutting back to where the existing metal is thick enough to weld, cutting and shaping the repair patches, and welding them in. I don't have the skills for that.
5. Even if this works, the whole thing needs to be repainted afterwards. |
| A100man |
 A100man World Chat Champion
 Posted: 10:37 - 20 Aug 2024 Post subject: |
| lingeringstink wrote: | Old Bantam tanks are pretty good because the metal had a higher lead content so they don't tend to rust as bad. |
Lead? As part of the steel alloy? Really?
Edit.. I have though seen article of folk using plumbing solder and a spade-sized iron to flow lead into tank pin-holes ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Easy-X |
| lingeringstin... |
| vorlon |
| vorlon |
| vorlon |
| Nobby the Bastard |
| lingeringstin... |
The last post was made 1 year, 312 days ago. Instead of replying here, would creating a new thread be more useful? |
